EwenA
EwenA last won the day on July 19 2024
EwenA had the most liked content!
EwenA's Achievements
Newbie
Newbie (1/14)
  1. That's great - thank you Edward:)
  2. Thanks Ed - this fixture file has solved the rig sync problem.... see attached show files for the other modes this fixture has. Yes, RDM does get complicated. I usually do a manual patch and disable it, but if I can get it to work with my various fixtures it could be handy to speed up set up on events. Many thanks. f2fc 1ch dim.zos f2fc 2ch dim.zos f2fc 2chan cct.zos f2fc 3ch.zos f2fc 4chan cct.zos f2fc 4chan direct.zos f2fc 6chan.zos f2fc 8chan.zos f2fc 10chan.zos f2fc 16chan.zos
  3. Hi, I am experimenting with rig sync, and have found it is loading the wrong fixture profile for my Cameo F2FC units. Rigsync patches them as a CLF2-FC, and does not give me control of the fixtures. If I disable RDM and manually patch the fixtures I cannot find the option for CLF2-FC in the fixture library. The correct unit shows up in the fixture library under Cameo fixtures as F2 FC. If I patch them in manually and disable RDM everything works as expected. If I then enable RDM rig sync adds in two new fixtures with the total CLF2-FC, and updates the dmx address on the two units. If I change the address back on each unit (using the menu on the fixture) I get control back, but still have the two new, incorrect fixtures patched in. Any suggestions as to what is going on and how to resolve this so that rig sync is usable? Show file attached. test.zos
  4. Is it possible to edit a single playback live, and exclude other active playbacks from being incorporated into the updated cue?
