1
Everything posted by martin-144
Hi, very interesting questions indeed. Unfortunately I am not able to answer most of them, lets wait for the Zero88 guys. Regarding your question 7: There is "Blind Mode". You can access it by pressing Shift+Z Key. Then press and hold the go key of your desired playback and type the cue number while holding it. This takes you to the cue and you can edit without changes on stage. Use Update to save the changes. Press Z Key again to exit. Martin
Switch between FLX / Mac OS (Capture) / Wifi hotspot
martin-144 replied to van den abbeele Eric's topic in FLX
Hi Eric and Jon, does not every Ethernet switch nowadays have a auto-negotiation function and can detect if there is a cross or not cross cable connected? I work a lot in this topic and I think it does. So in my opinion it shouldn't matter which cable you use. Please correct me if I am wrong. Martin -
Hi, Appuyez sur Record, 2.5, Enter ou sur le bouton Go de votre pile de mémoires spécifique. Press Record, 2.5, Enter, or the Go button of your specific cue stack. Oh, je viens de voir qu'il est sur un FLX S, quelqu'un pourrait peut-être lui indiquer comment taper le numéro de repère. Je soupçonne la touche "Shift"? Oh I just see he's on a FLX S, maybe someone can point him in the direction how to type the cue number. I suspect the "Shift" Key? Very weird things are happening when inserting text from Google translator. Is it just me? Martin
Hi folks, I have tried to reproduce this on Phantom. If I select a patched Sunstrip and try to apply an effect like described, my output window looks like in the attached picture. I can see there is something going on in the DMX output view. But you cannot see any effect applied in the channel view (here it is channel 51). Is this how it's intended to be? Martin
Hi Eric, you can use Programmer Time to do this. I can not look at the moment how you access it, but it should be written in the manual. Something like press Z key and use encoder wheel to set the fade time. Martin
Thanks Edward for your advice. It worked. It was not a big problem at all, but I was confused why it displayed something different than usual. Seems I touched this part of the monitor without noticing it. (good vs. bad for touch monitors 🙂) Martin
I don't have any fixtures at the moment which would require pixel mapping. So, honestly I don't have a need for it. And I think there are other things that need to be fixed first. Martin
Hi Edward, I will try this the next time I get to the console, which will be on Friday. But thanks for pointing me to this. I have not found anything similar in the manual. Thanks, Martin
Hi everyone, since yesterday my FLX console displays something different on the external Monitor, where the time used to be shown (lower middle of the screen). Now it displays "MIDI: <No Input>" or something similar, I don't remember exactly right now. Just to mention that I am not using MIDI in any way. Any Ideas? Regards, Martin
Hi, slowly going to understand things: I added a new file in /etc/network/interfaces.d/wlan0-artnet with the following content: This creates a new wlan0 interface on wlan0 with the required IP address. Adjust to your own IP adress. Works for me at home. Lets see for my theatre setup tomorrow. Martin
Hi, Today it seems a lot of Artnet Questions arise. Here is mine: I tried to control a Raspberry PI configured as a Media Server running OLA through Artnet without luck. The FLX is attached to an Access Point which delivers IP adresses in the Range 192.168.0.* to its wifi clients through DHCP (which includes the PI). The FLX is cabled to the AP and has a fixed address in the 192.168.0.* range. In the Manual I read that Artnet can only be delivered to IP addresses ranging in the 10.* or 2.* address range. Does that mean I have to configure the PI to additionally listen on and having configured an IP address on the 10.* range to receive Artnet? May this be correctly routed through the Access Point if not configured explicitly? Regards, Martin
Hi Edward, I already expected something like this. But is there a maximum resolution the FLX does support? I don't think I can connect a 4K monitor or something like this. I think at some point it would be just down-scaled? Martin
Thanks Edward, I am glad to hear that something like this is "on the road". The option using an UDK on latch and an inhibitive fader sounds also reasonable, but I think doesn't prevent recording house lights when they are supposed to be on, but not to be recorded. Another question, and totally unrelated to the others, which I mentioned already in another thread: What is the maximum supported screen resolution for the FLX? I am looking for a touch monitor to buy and don't want to "overshoot". Thanks for your help, Martin
Hi, it's me again, to follow up today's premiere performance, all went quite well, but a common problem reappeared. Please add this an feature request: Make Submasters or Playbacks to be not recordable in the main cue stack. Somehow the 'Inhibitive' or 'Park' solution does not work out for me, unless maybe someone creates a macro which can do this. I tried, but somehow failed doing it... @Edward: Thanks for your instructions for removing fixtures from a cue. This worked out really well. Thanks, Martin
OK, understood. Can you please tell me how to remove a fixture completely from a cue in live mode? I didn't really get the hang of it. Thanks, Martin
And another question in advance, somehow related to the previous one: Is it possible to delete a fixture's intensity information from a cue in blind mode? Thanks, Martin
Oops I did it again... Programmed house lights into a cue... Not that I have been doing this before, but this time it was tricky. In a break, when the houselights were switched on using two Submasters, I changed a scene (working light on stage) in Playback 0 using update cue. Of course the houselights were recorded too, but I didn't notice because they were supposed to be on. After the break I continued to the next scene, but the houselights kept tracking and staying on because they were on in the last scene. Turning the lights off in the scene before didn't change the tracking behaviour. It seems when it's tracking, it's tracking regardless if you change something before. How am I supposed to turn the lights back off in such a case? I could turn them off using the programmer and not touching it until until the end of the play. If I had to change something else using the programmer, what could I do in such a case? Martin
Hi Edward, thanks for your quick reply, I already knew the SHIFT + (Z) shortcut for blind mode. I hoped there was something comparable for preview mode. The next time I will be on the console I will try your suggestion for recording a blank cue using the tips you gave me. Unfortunately today I had to do this while another live cue was active. I am not always focused to the screen to see which options are there. Used to an old strand console where you did not have an 'interactive' screen at all. But I had the same problems with it. You say "no information will be stored in the cue". Does this mean 'all zero' or 'no change'? At the moment I am talking all about intensity values. Thanks so far, Martin
Hi again, today I had my first serious rehearsal using our new FLX. In general I have to say that the handling and doing changes to the lighting on the fly was very convenient and intuitive. On the other side I came up with some questions I want to ask here: - I found myself very often changing between Live, Preview and Blind mode to do stuff either online or offline or checking what the next scene would be. Is there a way to change between these modes without using touchscreen or mouse? I would like to use the keys to do this. - In blind mode (or any other), is it possible to create a new 'blank' cue with a certain cue number? For example, I know I want to have a blackout at cue 26, which doesn't exist yet. It it possible to create it without disturbing the running cues? So far and and a few rehearsals to go... I might add some new questions here. Regards, Martin
glad I could help...
Hi Steve, for 4 and 6 channel mode you should be able to use the built-in generic fixtures. Generic Fixtures - LED Unit 4ch (RGB W) or 6ch (D RGB W A) whereas amber would work as your strobe channel. Martin
Just to add my question here: What is the maximum supported screen resolution for the FLX? I am looking for a touch monitor to buy and don't want to "overshoot". Thanks, Martin
Do you want to make the changes "blind" or "live"? In a theater environment and during rehearsals I assume live. After doing your changes you can just press UPD and GO to have the current cue updated with the new state. Don't forget to clear your programmer afterwards 🙂 Martin
Hi Jon, actually I just want to see which cue I'm in, and maybe the next/previous one. Having the functionality in Z Remote would also be fine. Thanks for your efforts, Martin
Hi, why not tell my wishes right now, as its maybe easier to implement in an earlier stage. The problem in our house is that we dont have a FOH lighting place. We do it from behind the scenes using a monitor to see whats going on on the stage. This is ok for playback, but for rehearsals I like to be in front of the stage to see what the lighting actually looks like. For now what I found out, I would have to use Z Monitor on a tablet to have the cue list in front of me, and on the other hand running Z Remote on my mobile to have a go/pause/back button. Would it be possible to implement a page in Z Monitor, where you have a cue list and the mentioned go/pause/back buttons. Then using only one device would make rehearsals much easier. Thanks, Martin
