Nico6868
Everything posted by Nico6868
  1. Thanks to both of you
  2. Hello, I would like to check if there is a way to delete a cue which is record in a playback on my flxs48 for example I created 10 cues in the master playback, and finally I want to delete cue #6... how can you do that? then if possible how is,it,going to,impact the others cues number? #7 will go to #6 or will remain number #7 and you have a hole in between #5 and #7? thanks for,your help best regards
  3. excellent thanks
  4. Dear all, is there a way to copy a record scene or chase from a playback to another? thanks Nico
  5. Hello, i’m using My FLX S48 since few weeks and I have a question basically I want to know if it’s possible to mix two playbacks. for example: with simple leds pars l’m creating a red playback and another one with the blue color. when I use individually both playbacks no issues I have either red or blue color. i wanted to know if there is a way to mix both colors to have purple (in this case) when both playbacks are at 100%?? because today if the red is full and I increase the blue, then the par switch directly to the blue and the effect is not nice during a show. i tried to play in the playbacks settings but I found nothing. thanks for,your help
