Jason Brameld
Jason Brameld's Achievements
Thanks for the update. I can go looking under prolight, but from a user perspective picking up a fixture, or being told that the venue has some LEDJ or Equinox fixtures, many wouldn't necessarily know that they are distributed by Prolight, and may struggle to find them as a result. Elumen8 are also distributed by prolight, but they are listed as a manufacturer in their own right, so what's the logic for not doing the same with LEDJ and Equinox?
I updated our demo desk to 7.9.8 the other day. I noticed that the new improved expanded fixture library doesn't have ledj in it as a manufacturer, but the old library did. I saw on a post from Edward that there is an update due very soon - will this be included in the updated library? On a related note, can the existing fixture editor (2.6) be used with the new library or will there be a new editor along at some point? Thanks, Jason.
We have used the FLX for a variety of conventionals, LED and movers in a small studio theatre - so probably a similr setup to yours - for about 3 years now. We have a variety of users from highly competent techs doing complex full-scale shows and musicals, through to users who just want a couple of faders to push and the FLX does the full range easilt - I would recommend it for your set-up fron what you have said. We do most shows off a cue stack, bit we have busked some as well. The other thing I really like about dealing with Z88 is they are close to their user community and the support is great. Jason.
Hi Ed, That all makes sense, and using colour fades only was my method as described in my original post - I was just using changes to colour values (no change to fixture intensity throughout) so my sequence was: Full reds to start (red at 100%, intensity at 100%) Fade red colour values 100% to 80% over 1 minute (minute 1) Crossfade red 80%-0 and blue 0-80% over 4 minutes (start at end of Q2) (minutes 2-5) Fade blue color values 80%-100% over 1 minute (starting at the end of Q3) (minute 6) I could do all of this with Smart Tag on and no tagging/untagging of different colours, but I had to do the maths (admittedly not difficult!) to split the fades up, and your method can do it with one fewer cues. There's always more than one way to skin a cat! Thanks again for the excellent contribution to the debate.
This has been a great thought experiment for me. Thanks for all your input Ed. I was after the straight line performance in the graph without a significant intensity dip. Here are some more graphs: If the intensiity values are run on an HTP basis with a 5 minute down at minute 0 and a 3-minute up at minute 3, then I think you get what's shown on the intensity graph below If you then add in a 4-minute colour crossfade, and multiply the colour values by the intensity values to arrive at the fixture output for each colour then you get (with a slight approximation on the resultant intensity values) the output in the second graph below. The actual output values are not very linear and there is quite a dip in overall brightness at the 3 minute point. The eye doesn't really see the non-linerity, but the brightness dip is noticeable. Your last post above however did cause me to and figure out how to add a delay to a fade on a cue which i hadn't done before - very handy to know. Lastly, in programming your cue sequence I couldn't use Smart Tag for all the cues as cue 2 has the fixtures 'off' and cue 3 has no brightness information in so to program the color fade I had to use 'selected fixtures' to program that cue otherwise it didn't take any information into it - would that be right? Thanks again for the brain exercise! Jason
OK - Thanks - I'll have a play. Given that we seem to need 3 cues to do this by your way or mine, would my way described at the top of the thread also work? Thanks! Jason.
Ah - but the red fade out should finish at minute 5, and not minute 6.....leaving the blues to continue from 80% to 100% in the last minute. The actual time they spend cross-fading is only 4 minutes - in the first minute at the beginning only the red is coming down and in the last minute at the end only the blue is going up. Good brain teaser huh?
Hi Ed, Your summary of the problem about separate PARS but in the same fixture is spot on! This is what we want to achieve: I think your first example is closer to the mark. - I may give this a try as an exercise So in your cue 2 - that is the fixture intensity at zero and the red colour remaining at 100% (G and B at 0) In your cue 3, fixture intensity 100%, R and G at 0, B at 100% So the question in my head on this one is would the colour crossafade in Q3 effectively slow down the red fade out in Q2, as the red fade down should be competed 5 minutes after the GO on cue 2, and not at the end of the 5 minute colour crossfade started when Q3 starts (If that makes sense?!) Also if you have the intensity dip and the colour crossfade do you end up with the brightness dropping more in the middle doing it this way? I'll have to go and play tonight now to satisfy my curiousity! Jason.
He knew what he wanted, which was non-time-aligned fades that didn't finish together - hence it was tricky - but he was rubbish at explaining it. I had programmed it completely wrong first time based on my initial understanding of his confused explanation! Anyway - hopefully Ed will be along with some sanity soon..... Jason.
That's part of the problem - they don't time align - it's a 5 minute fade out of the reds, a 5 minute fade in of the blues, and a minute gap between the starts of the 5-minute fades. so: At time T+0: Start 5 minute fade down of reds @T+1 min - start 5 minute fade up of blues @T+5 mins - red fade out complete @T+6 mins - Blue fade in complete This was the subject of much confusion as it was being asked for by the designer (who wasn't very good at explaining things) as well!! Jason.
So I had an interetsting request for a Fringe show yesterday that I couldn't figure immediately so can I pick your brains to see if there's a better way than the one I subsequently came up with? The requirement was for a split colour fade on an RGB fixture as follows: <GO> Start with general FOH wash (tungsten) <GO> Add in red from side LED fixtures on a 5 minute fade up time (so far so good....) <GO> Start a 5 minute fade out of the reds (still easy.....) <AUTO 1 min after start of Q3>, start a 5 minute fade in of blues on the same fixtures as the reds (accepting that this will pass through various lovely shades of purple on the way (now I'm stuck.....red fade would then finish 1 min before the blues did). Eventually we compromised on a 6 minute colour fade between red and blue and that worked fine. The only workaround I came up with in my head afterwards was: <GO> Start with general FOH wash (tungsten) <GO> Add in red from side LED fixtures on a 5 minute fade up time <GO> Start a 1 minute colour fade of the red leds to 80% of full value (lose 1/5 of value in 1/5 of the fade time) <AUTO after end of Q3>Start a 4 minute colour crossfade to take reds out and bring blues to 80% of full value (bring in 4/5 of blues in 4/5 of the time - take out remaining 4/5 of reds) <AUTO after end of Q4) Start a 1 minute colour fade of blues from 80% to 100% of full value Leaving fixture intensity at fixed level through Q3-5. Is there any smarter way of doing that? Thanks, Jason.
I loaded the new library file and the problem is fixed. It asked me if I wanted to replace the existing library file and I said yes, so all good. Still a mystery as to the cause though. You have our show file so could it be something funny in firmware and/or hardware versions. Can you access historic system text, or just from the last boot? Jason.
Thanks Edward, I've downloaded the file and will try and load it on the desk tonight. I'll let you know how I get on. Looks like the library may be missing/corrupt on the release package maybe? Did your test desk get the software loaded by the distributable you are providing, or by some other means? As an aside (that may or may not be relevant) I did notice an error of some form flash past (in green text) when I first re-booted the desk after installing the software, I didn't quite catch what it was and subsequent boots (that I filmed so I could catch it!) didn't show it. Will update when I have more news. Jason
Thanks - I'm glad it's not just me!
Thanks Edward, What you did to re-create is exacty what I did. It worked fine in Phantom. Will try re-loading the show file but may need to wait until the current show is done before I can do that. Thanks for clarifying on the clear options and the UDK options - All will undoubtedly become clear with the new manual! I'll let you know how I get on - could be another 'only happens at the Pump House' Issue!! Jason.
