LLuk
LLuk last won the day on February 7
LLuk had the most liked content!
1,867 profile views
LLuk's Achievements
Explorer
Explorer (4/14)
  1. Hello is your Grand Master Fader set to Grand Master? (Hold Setup - press Blackout Button - tab Grand Master in the Fader Function)
  2. hey my FLX crashed too a couple of time with Zeros 8. While playing around a little during a practice(mostly in Programmer, few simple playbacks) the console just rebooted automaticly...no idea what commands/actions was the problem. it seemed randomly (??). the support team reacted to the debug i sended: "my" issue is now logged on zos-12707... i went back to 7.14.3 loading the showfile back into 7.14.3 was no problem (but it was mostly just the patch, setup, and few simple lightstates, no "complex" programming, MoD, or custom-paletts). good evening luk
  3. denks @kgallen and @Davidmk for taking the time to answer. Just to complete if anyone is interessted; to get different fade in times for different lamps i did following (with the exemple my post above): Programming channels 1 thru 6 with fade time 10sec on MasterPlayback. Programming an empty cue on PB1 and a second cue with channel 7 and 8 with fade-time 3sec. with the cue on MasterPlayback it auto-trigger a macro (recoded as -go PB1-) befor i trigger the cue on MasterPlayback, raised the Fader on PB1 manually so the empty cue is active. (did this even befor the show started, so i didn't had to worried about anymore) easy. good evening
  4. Hey @kgallen i tried it with your describtion...it works fine and easy to do. But what when its over different Playbacks? For our Production i will trigger the other Playback with the faster Fade-In Cue manually. This works fine too and does not affect my Move-on-Dark-Worries on MasterPlayback. Denks...Luk
  5. Hey denks @kgallen and @Davidmk for the responds. I will try on phantom later. In my situation i would like to do it in different Playbacks. Cause the Production is allready in Play, and i am to scared to programm it i my MasterPlayback cause there is also some move on dark action with some scrollers in the cues i would like to change. i don't trust so much Move on Dark with my scrollers, or maybe i dont trust my programming skills with Move on Dark and my scrollers. its all the time struggles until they scroll when i wanted them to scroll. (its probably my programming way) i dont wanna mess this up again. Anyway thanks and i will give a try. Luk
  6. Hällöü Everybody i recorded a Cuelist on Master Playback. Several times i would like that the Lights Fade-in in a different Fade-time. Lets say Channel 1 thru 6 Fades-in in 10sec.(recorded on Masterplayback) and Channel 7 and 8 Fades-in in 3sec. (recorded on PB1). Now i changed the Cue-Settings in Masterplayback to also trigger PB1. When i trigger my Cue on Masterplayback it triggers (like expected) also PB1, but ignores the Fade-Times on PB1. So all Channels Fades-in in 10sec. So i played around a little and i get following; It only works when the Cue(MPB) who triggers PB1 have a faster Fade-In then the PB1 who get triggered automatic. With a slower Fade-In on MPB then the PB1 have, it ignores the Fade-time on PB1 Why? Does someone has a clue about this? Sorry my english, i hope its understandable. denks and good evening Luk
  7. hey denks for the answer. its a pity, that there are no plans for it anymore. good evening
  8. or is it technical just not possible..??
  9. Hey Edward... i am a little confused now... in a former post of mine about an active Go-button within "manual fade" option, you wrote: ...and now you guys implement ZOS-5803 but it seems like its just the same as ZOS-8363. so is an active Go-Button just a dream or its something it will come.?? have a nice evening Luk
  10. denks a lot for all this helpful informations, edward. good evening luk
  11. Hello Edward thanx for your fast answers... Aahaa...yes, its very understandable. But still, when i think about this, it should be possible again, when i desable RigSync or not..?? uuaaarrrrgg...🙂 yes for sure...i didn't thinked about this possibility... many thanx for your support and have a good evening... L
  12. Hello everyone Today i helped a friend with a small set-up for a theatershow. He uses a flx s24. we updated to zeros 7.14.2. We wanted to patch some fixtures together (ad as additional adress) but there was no button for it in the menu where you can change the adress. also no unpatch-button (usually in the top-right corner of the menu). We tried again with an old showfile and the buttons where there. We reset the desk, patched some fixtures and again the two buttons missed. We loaded old zeros softwares (7.13 and 7.12) cause we was thinking its maybe a bug of 7.14.2. But the same problem, the two buttons missing. Again load an old showfile and again the two buttons appears. So, finally we went back on Zeros 7.14.2 and loaded the old showfile as basic and deleted some fixtures and repatch some others. Like this it worked. I saved the showfile without buttons and load it in to my flx (fullsize) to see how my desk will manage it. Also no buttons. But after reseting my desk, all the missing patch-possibilities shows up again. Does anybody have some ideas what happend?? ...and all this brings us an other "problem". After loading and reloading and loading again different Zeros-Versions and Showfiles we forgot sometimes to disable Rig-Sync(completly our fault..;) And in the old showfile was a couple of Led-Fixtures with same adresses like the wallmountet dimmers(RDM) of the venue. So the console automatic "messed-up" the adresses in the dimmers. (it took a while to figuered that out cause the dimmerstartadresses stayed correct) so i am wondering if it would be friendly if the console could ask first, befor messing around with adresses, or nice would be Rig-Sync disable by default?? after struggling with the missing buttons in the patchmenu, and finally get the patch done with old showfiles, and then the patch is still full of faults cause of the messed-up dimmeradresses, simply a day to get drunk... i hope all this is understandable even my not so good english... good evening.
  13. Thanx a lot... this sounds logic to me. i will give a try with -update-(smarttag/track forwards enabled)-enter-. good evening Luk
  14. hi denks for the replays. maybe its important (maybe not..??) to know that not all the values of a cue get blocked. (if its important i am very sorry to not mention it clearly.) point (b) is my guessing too... yes, i am sure about this. i will do in the next days a small cuelist to visualize. denks a lot for taking the time for answers... good evening Luk
  15. hellö everybody sorry it took a while...but with the informations i get from your answers, i played around a little and i figered out what happend: when i have blocked values in a cue (for exempel cue 10) and i want them unblocked, i press update - (smarttag enabled) - enter, and they change to tracked values(when its possible). BUT...then the next cue(cue 11) changes to blocked values. i do the same (update - enter)with cue 11, and then again cue 12 get blocked values. and so on... thats why i was confused about still having cues with blocked values after ("empty")updating cues. when i think about this, i am not shure if its logical to me or not(its a bit a head scratcher to me🤔) It makes tracking kind of funny, if you dont do a general unblock for the cue (setup - PB button - advanced - block/unblock). (denks @Kgallen for this hint, i think i will start to use this function often in the future...) Luk
