van den abbeele Eric
11
Everything posted by van den abbeele Eric
Touch Screen Monitor Recommendation
van den abbeele Eric replied to nbaldwin's topic in General Discussion
Hello Edward, Do you see differents between your previous Touchscreens display (Prolite T1731SR) and your new Prolite t2236msc-b2 ? thank for your help, eric -
Hello since I received the FLX of repair (Party of your loaux) and which seemed repaired, I had not had spectacle nor had the occasion to be able to try it in situation. I had just turned it on with the use of the internal screen and only with 1 wing. And everything seemed fine. I thought everything was working without worries. Being in a show this weekend, I wanted to connect the external touch screen, (the one you recommend) I could not calibrate it so impossible to be able to use it in touch ... In fact sometimes I manage to make a cross to touch, sometimes two crosses to touch, sometimes, Three but impossible to be able to draw the screen. What poses another concern is the access to the playlist "MAster playback" to modify the fades in and fade out ... Wing 1 OK Wing 2 Problems But the second concern is on the side of wings 2, where the display of pages is bumpy, and where the button for choosing "channels / playback" does not work and the leds of certain chanels remain lit whatever do. Given the short time I have left I only had time to try other USB sockets .... But nothing else ... The rehearsals arriving this evening I try to manage by wishing that other Bugs do not arrive. I tried to go from version 7.9.7 to 7.9.6 which is the version that you had installed when the FLX was at your home in repair, and I said to myself that maybe some things could have caused problems in the last update. In view of the number of shows arriving in the coming weeks, I am really very upset, because playing with two wings, without a functional touch screen !!! the ideal being bought another functional FLX ... But the price is there ... Thanks for your help PS sorry I can't access my emails from here ...
Yes exactly. I m thinking about the community ... Thank and have a good week.
exactly. The importateur have find a solution. He did for me a 10 CH mode try, and it's working. I try now to have a complet version (6ch/10ch/18Ch) And he tell me that was really a factory problems... So When I will a good version I will send you for complete the Fixtures files. (Version gtf40... ) Thank a lot Take care !
Unfortunately it does not work better. In 6ch mode I have a little fader light at the bottom, and the only way to turn it off is to lower the intensity again in the color option touch screen. in 10 ch mode, I have nothing that lights up and there to have something you have to go to RGBW Dim, but it's not magic ... I do not access the Zoom or strobe ... I gave the link of the fixtures page to the importer to see if maybe he can find a solution ... (He creates the fixtures for the Sunlite environment.) Thanks for your help...
I going to try and telling you in few minutes. Thank a lot
I had indeed confirmation that it is preferable to have the values at 0% at the level of the Dimmer Level. ch 6 on 6 ch mode, CH 10 on 10CH mode and ch 18 on 18CH mode. This channel will go on an up / down time in 8 and 16 bit mode. When I put it all at 100% it's chaotic. With Jester 24/48 So I tested in mode 6, 10ch and 18 ch I confirm indeed that while being at Zero, the projector behaves in the best way. Then if in 10 CH and 18Ch mode there is an "All Dimmer" channel which behaves like general, in 6ch mode, there is no general setting. So the only way to increase or decrease the intensity is through channels 2, 3, 4, 5, (a bit like on the "Martin Rush Par2") défaut mode on "speed" is "0" (CH 9 on 10 ch mode - Ch 17 on 18 ch mode) Defaut mode on "dimmer level" is "0" (Ch 6 on 6ch mode - CH 10 on 10 ch mode - Ch 18 on 18 ch mode) défaut mode" strob" is "0" (CH 7 on 10 ch mode - Ch 15 on 18 ch mode) défaut mode on "Fonction" is "0" (CH 8 on 10 ch mode - Ch 16 on 18 ch mode) Do you need more info? Normaly it will be work like this. Thank Edouard
By pushing things further. I realize that this Level dimmer mode also plays on fade speed depending on where the value is. And depending on where you put the value or everything hangs. I try to have more info to know between 0 to 255 what it does at the projector from the French importer which is very affordable. But I think that channel 6 must be able to be set to 0% even if it means being able to modify this setting by means of a rotary button. To be continued .... and see how to find solutions.
Hello overall I can not operate in manual mode with 1 fader per channel. Because with 10 projectors, in 6ch mode, I would need 60 fader. Either have 3 more FLX wings ... Unless I will find abandoned wings at the roadside, will be a solution... But going through the purchase is complicated for now ... this is how I tried it. on FLX as on Jester 24/48: Fader 1 = ch 1 Zoom 50% Fader 2 = ch 2 Red 0% Fader 3 = Ch 3 Green 0% Fader 4 = Ch 4 Blue 0% Fader 5 = Ch 5 White 0% Fader 6 = Dimmer level (8 Bit-16bit) 0% In this case, everything is fine. I did the test in 10 ch mode, with all channels at 0% like the zoom at 50% and everything was fine. I imagine that this dimmer level mode (6 in 6ch mode, 10 in ten CH mode, and 18 in 18 ch mode) was not well informed more maybe than all the other fader to Full by default, so that nothing is under control except to do as I could find it go on color and go to the intensity of the touch screen, impractical way to have a black. I will send the manual (little information now on the fixture email ...) Thanks for your help...
Hello I have a problem with a fixture (newly made by you) From Ledstage - Zoom Led Par: 6ch - Zoom Led Par: 10ch - Zoom Led Par: 18ch When I connect the projector to work with, (In 6CH, 10CH mode, as in 18ch) the MFF fader at 0% the projector work on in white at 100%. Going to the colors nothing change, only white dominates everything. And even when I lower the Fader General, the PARZOOM is always on ... The Zoom is fine in control . So the only possibility I have to do something is to turn off the intensity through the touch screen. and still the fader at 0%, I can then play on the colors. I looked in the FLX menus, (Colors, Beam, Shape) if there was a solution somewhere, without finding anything. In order to see where the problem comes from, I try with my JESTER 24/48, to command the LedStage PARZOOM in 6 channel mode, and in 10 mode channel. And all was OK. I put again the PARZOOM in 6CH mode on FLX using 6 faders (6 dimmer on 6 fader) and everything was fine. Everything being at 0%, (Each color and the white as well as the general dimmer) I can mount each color manually and everything works well. So I think that when the projector is connected to the FLX, in the PARZOOM fixture, there must be something that plays at 100% automatically. So for the moment I am unable to use the projectors... Is it possible to update this fixture, and so if it's something you can do, is it then possible to replace this fixture in FLX that is causing problems with an updated fixture? Thanks for your help. PS I will still try to see by acquaintances around me, if I can find someone who can help me in the creation of fixture ... Thank you Eric VDA
OK top ! Thank a lot. So I will try to see If I can have possibility to buy iPad and use it into further performance... And If I can do it, I will can back to you for having help. Take care, Eric
but if I don't use wifi network and coming directly from iPad to FLX (ethernet/lighting), what I must configure ?
Je pensais pas que cela soit possible FLX > ethernet > Ethernet lightning > iPad, is it Right ? And on iPad you use IOS application ?
I asked the question to Axente few month ago, and there wasn't in this direction... But If there doing it, I can wait... I will try to ask to Axente if they're doing one or not. They did a FLX S manual, older version...
hello Edward, yes it a possibility. I m looking fur further month to have a WIFI hotspot and to go to iPad. But I know that external device aren't work as easily as something that is included. I can often see during shows, tablets connected to the sound management, and no longer work, because the WIFI hotspot falls in the harbor, or that the console has a bug (Yamaha, Berhinger, Midas, and so an...), or by an overloaded network, etc etc ... So for my part I tend to look for solutions that are incused at and without too much difficulty in connection and disconnection. Then it is obvious that adding a screen requires to increase the electronics and therefore a blow which increases ....
two display will be really good...
Hello, I create this topic for talk about external controls from iPad, iPhone and other tablets. What do you use ? iPhone ? iPad ? Other ? For create WIFI connection, what do you use ? Problem to create your network ? And FLX/FLX S, problems bethween tablet and FLX ? Thank for sharing yours experiences, Eric VDA
Hello, I started to doing the French traduction, the last manual, 7.9.6. (FLX/FLX S) just for helping people which can understand English. I wish to finish it in few weeks... take care Eric
hello Again, I forget a other possibility, to have a way for recording many show inside FLX/solutions/etc. Having for exemple a external SSD disque (We find now easily some correct things for little price) and having the possibility to call and recording quickly different show. Also to doing some quick backup.... So You ve your Server professional solution, (that can play a show, without FLX/Solution/ZerOS+PC) but perhaps to have a second light SSD Backup solution can be interesting. At this time, perhaps to keep this SSD disque with FLX/Solution/etc... THank Eric
Undo/Redo - to restore e.g. a lost position or colour and so an.... (yes good idea too !)
Hello, in the wish list, some are indeed rather on the software and the evolution of future versions. I come back to the fact of not having an infinite time when encoding during a show ! It is certain that what would be good to have stronger aids for the operator on : - more "effects" included to enhance a show in a very limited time. - Can also be rated Différents "positions" to also have some choices. Assuming that we will have minimum of 4, 6 or 8 spots or much more. apart from the Home position, to have maybe all the spots / Wash at 45 °, 65 ° / 70 ° and 90 °,. Also have cross positions (Pair/impair) at 45 °, 65 ° / 70 ° and 90 °. I think a good thing would be to put yourself in a show condition. Start from scratch in the morning, add fixture, make the settings, then record 50 to 100 effects to see what is effective or not in terms of quick functions and see on the contrary what is wasting time ... Fixture: The other thing is that some consoles allow you to create fixtures without having to go through a computer. Is this possible in future updates? I take the example of a console that I saw yesterday, a "LightShark LS1 Work" some things are much lower than ZerOS, but other things seem interesting as functions allowing the operator to work quickly and especially to compensate for a small library of projectors ... Mac OS..... hey.... Out Zeros OS FLX By dint of doing shows in different places every week, I can also see other things that could help. A marking for example on the 24 faders of the FLX and the Wings. 1 to 24, 25 to 48, 49 to 72 and so an... Have a self-adhesive option that you can put between the fader and the selection button. when you have the FLX and several wings, it is easy to know where you are listed number. Anyway, we must also mark over the fader, what it is (Front PC, side PAR, backlight LED, Spot, etc) Knowing that now more and more console we have below the fader an LCD indicator that lets you know where we are. And motivated faders (Berhinger sound Mixing, Yamaha, Midas, etc ...) Visibility : The principal buttons (recorded, colour, beam, shapes, group, name, position, ...) on the FLX and Wings, being in black and the inscription of the functions in white but in reduced size, we see a little bad ... So I was able to put on the FLX and the wings, thanks to a Brother little print, a marking in yellow next to the buttons and main faders. So with limited lighting I can finally see the name of the buttons and gain efficiency. Indeed in show or rehearsal time is limited and you have to be efficient to allow the show to be done at best. Second Monitor Here's the last thing, I still think it would be nice to have a second monitor. Maybe it would be too much for the processor ... But in visibility to have the palettes on a large screen and to have the Cuelist on the second screen, it would be a great comfort. Thank you so much.
It will be good to have it for Mac OS. Now it s possible with Grand Ma 3 (MA Lighting) also Chamsys And little Software solutions try now to go on window and Mac OS.... There is more and more people who are going on Mac Book Air, Mac Book Pro... Thank to giving us a solution in the future
Thank a lot Erics for your answers I will do it this week and see the différents améliorations. For the future performance, I need stability for giving to the différents choreographer tranquility for their creation... take care Eric
Hello Kevin, you speak about coprocessor update... Is it including the 7.9.7 update ? Or must I download something more ? thank for your help Eric VDA
