van den abbeele Eric
11
Everything posted by van den abbeele Eric
Hello, After the previous traduction (ZerOS 7.9.6/7) I did also the traduction about the last ZerOS, 7.9.9. So It's not perfect traduction, but It will be a good help for understand many things that are not so easy to understand... Take care Eric
Comment about last Update ? Good things ?
van den abbeele Eric replied to van den abbeele Eric's topic in FLX
Thank Edward for your message. I m not hurry -
Hello, I didn't do the last Update 7.9.7 to 7.9.8. and I wish to do it on fews days... So for all of you, that going to 7.9.8, what are your good surprise ? Still easy to use and separate things form Bean and shape are easy to use ? Thank a lot for sharing your first sensations Eric from France
Hello, I work with traditional projectors and also Leds + automatic in a Theater configuration. Work with a Conduct that begins from the start of the show until the end. (I do dance show) The FLX seems really well designed for this, theater and Culturel center. Clear display, quick access, either by fader, numeric keypad or groups. (I chose because I having many projectors from many direction and during Dance rehearsal a reduced time to have 2 more wings that giving me 72 faders) But so I work1 universe on the traditional light and 1 universe on the Wash LED and Spot + Wash which are motorized and all is well. Easy to correct, copy and delete modify and so an... The exterior touch screen is of great help when. And guys from ZERO88 are reactive and tireless to help and support ... I think that some have no family life and must stay at work all days and night (especially Edward ) because we can even have answers in the evening like the weekend. Then there are as said above videos and manual (Version 7.9.6 / 7) which already helps really well. So I would say it's a console that has great possibilities and capabilities. And our user community is active to support those who have concerns. So have Ă good night. Eric From France
Thank Edward, I will speak with this guy to giving him this information. I see some different between the two consoles that is not very important for his show, it's number of Cue 999 on Leap Frog and 10.000 on solution... SO If using ZerOS Phantom he can recording the Show on USB key (in solution XL standard) and all we be OK ? I think that a good idea to know which ZerOS version this theater use for the LeapFrog... to be OK for recording things on window and having no problems on LeapFrog... Thank Edward
Hello, there is a Theater, Between Metz and Nancy, that having LeapFrog 48/96. So someone I know must be doing light on this theater but he doesn't know ZerOS and Zero88 light devices. So if he had window computer, is it possible for him to to training on Window computer to understand ZerOS, and perhaps having possibility to recording thing, If he can doing things without emulation.. (he will not have money to buy "Capture"...) So I Downloaded LeapFrog manual. So I see many things that looking like FLX. (and some other différents... evolutions....) So I can also having a little training with FLX, for the commun things between the Two consoles ... Thank for your help Have a nice Monday, Eric
like Zero88 tells in http://support.zero88.com/990063141 link, it's important to have a correct USB/midi device that giving a good protections (opto-isolator) for FLX devices and also the computer and also having good conception.
OK it's looking clear for me. So I would not add a projector normally in a show and I will not use this possibility, but It's good to know. Have a good night Eric
so if I understand correctly: 1/ I am using a Quantum MAC. I make adjustments on it. With copy option, I can use the same parameters for another MAC quantum using Shift + record> new palette and thus select the second MAC quantum and so an, if I've add other Mac quantum. 2/ On the other hand, if I have a MAC Aura, I cannot use the settings in question if I understood everything ... 3/ Last case, if I have a device that has the same settings as a mac quantum, then I reuse the settings after copying the settings to a new palette. (I used the "MAC quantum" which may not be the right example, but some Chinese machines are visual and software copies of branded devices, this is the third exemples) Is it right ? Thanks
Bonjour, Je te conseille en effet si cela peut se faire coté budget de passer en effet soit sur la FLX 48, soit sur FLX. Tu as quand meme pas mal de choses qui sont superieures comme par exemple l'écran externe tactile. Et des fonctions que tu vas avoir sur FLX 48 et FLX et qui ne sont pas possible ou plus limités sur FLX S 24. Et l'on trouve de temps en temps des FLX S 48 ou FLX en occasions, (certainement des utilisateurs qui étaient sur ZerOS en 7.9.3/7.9.4 qui étaient plus limités en terme de capacités et autres...) Ensuite la FLX est quand meme très interessante pour travailler rapidement avec le clavier numérique pour utiliser la syntaxe... J'ai pu vraiment voir les améliorations quand je suis passé en 7.9.7... Et le futur 7.9.8 a venir dans quelques semaines semble vraiment encore plus interessant... Une bonne fin de journée Eric
Bonjour, oui ensuite il est possible de faire cumuler plusieurs console ensemble. FLX 1 Univers 1 Ă 16 FLX 2 Univers 17 Ă 32 FLX 3 Univers 33 Ă 48 FLX Univers 49 Ă 64. Cela fait deja pas mal de choses possibles...
Hello Edward, For using this possibility to : You're speaking about "using fixtures same type" what do you mean ? using exactly same fixture ? Or this to use fixture that use same parameter and use same values ? Thank a lot Edward, Eric
Salut espere que tu vas bien ? Tu utilises depuis longtemps ta FLX ? Tu travailles dans un lieu ou tu es plutôt sur des tournées ? Une bonne journée à toi Eric (situé en Lorraine, Metz)
Hello Edward, when you said : So currently the library has more than 12,000 fixtures ... When we are going to work with 7.9.8, how will it be? Will the new library consist of only new projectors map that arrive at your home and are transformed into fixtures? What about the 12,000 existing fixtures? Will it be updated as it goes? OR should this be requested from zero 88 (third party company)? - If a RGBW projector haven't a complete colour mixing in fixture library, is it possible to update the fixture for use this possibility ? - When RGBW + A will be allowed in ZerOS, Fixture which have RGBW+A possibility will be automatically update for using all the capacity of the colour picker, or we must ask to you to do this update ? Thank for your answers Edward have a nice day PS : Monday video presentation was great ! To have possibility to see you and other guys on Zero88 presentation, is very interesting ! Good moment !
Hello Fixture Library evolution a question concerning the evolution of fixture libraries. Will all fixtures change over time? you are going to modify the elements for each brand and each type of projectors? If indeed this new OS 7.9.8 evolves to use new fixture formats to take advantage of use Beam separately from shape, that means that to fully benefit from it, each fixture must be able to benefit from all the parameters ...? The load for the processor and the memory are already planned to take more parameter? RGB + White + Amber led colour picker Other questions which concern more the shows of Theater, it is the inclusion in Led RGB projectors, the White part (when it is present in the projectors) as well as the Amber part in the color picker? Indeed when we work on the Color picker it is a mixture of the 3 primary colors, something that does not always succeed on all projectors ... On the other hand when we mix a color with white, the pastel colors are much prettier . Likewise, when amber is used with white, it is easier to have beautiful shades ... thank Edward and have a good week end
French Manual FLX-FLX'S & ZerOS / ZerOS 8
Hello So French version continue to evolve. (Errors correction, Texts addition and, Images additions / modifications for helping news users) Even if for the moment it is not yet perfect, in any case, I continue to develop the different sections over the versions. The idea being to be able to best help users who do not know too much about the ZerOS environment and who start on an FLX. The most complicated for me being to keep the pages as on the English version to allow any user to be able to compare the two versions in case of doubt, or translation error on my part. A good day to everyone. this manual is available at Zero88 as well as at Axente France. -------------------------------------------------------------------------------------------------- Bonjour, la traduction du manuel continuer a évoluer. (correction d'erreurs, ajouts de textes et conseils, ajouts ou modifications d'images.) Meme si pour l'instant elle n'est pas encore parfaite, en tous les cas, je continue de faire evoluer les différentes sections au fil des versions. L'idée etant de pouvoir aider au mieux des utilisateurs qui ne connaissent pas trop l'environement ZerOS et qui demarent sur une FLX. Le plus compliqué pour moi etant de conserver les pages comme sur la version anglaise pour permettre à tout utilisateur de pouvoir comparer les deux versions en cas de doute, ou d'erreur de traduction de ma part. Une bonne journée a tous. le manuel est accessible chez Zero88 ainsi que chez Axente. -
touch screen not working 17" iiyama T1731SR-B5
van den abbeele Eric replied to stepan s's topic in FLX
Hello, So I remember with the older firmware, 7.9.4 having also problems to connect my previous T1731SR-B on FLX. after starting a new show having often problems to connect my monitor. But after this fist part (started new show) all the problems were solved. but once set off for a new show, it is often difficult to calibrate the screen. With 7.9.7 having no problems. So now I change for a bigger Monitor with multitouch. (Also forgetting "Update" option for exemple...) -
Hello, French manual version is still progressing. I did some texte and picture amelioration, for giving more help for Frenchs users which need help and that are not having a good understanding. take care Eric Bonjour, la version Française avance bien. Je continus à améliorer les différents parties de cette notice avec l'ajout de quelques petites choses cotés texte et image, histoire d'aider les français qui ont du mal a bien comprendre l'anglais. Si vous avez besoin du manuel, n'hésitez pas à demander à Zero88, ou bien me laisser un message ou encore de demander à l'importateur Français Axente. Une bonne journée à tous Eric -
Touch Screen Monitor Recommendation
van den abbeele Eric replied to nbaldwin's topic in General Discussion
Hello for all, have you experienced other external monitor ? Having good experience with other brand and models ? Thank a lot Eric
