van den abbeele Eric
11
Everything posted by van den abbeele Eric
Hello Ed75 see you are using showtec and LightShark nodes. You say everything works really well. In terms of configuration and operation, are you really satisfied? Regarding the power supply of the LightShark, to have an external current adapter, does this not cause fragility? How do you position nodes? Next to the control room or do you deport everything to stage level? concerning the uses of the projectors, do you have many machines and models of Lyre & Led? Thank for your help Eric
FLX - fixture goes to zero when programmed into a cue
van den abbeele Eric replied to Ian_p's topic in FLX
Hello, It will be interesting to have news about this problems... Just for having solutions on old ".ift" fixture... Even if ideally it is to no longer use the old "ift" files, it is to know how to react in case the problem arises.... "Actually had to have a show this past weekend and I had a stroke and ended up in the hospital...." thank a lot Eric -
Hello, I systematically use splitters (2-way, 4, 6 and 8-way) generally having around 70 LEDs (Moving & Static projectors) plus traditional lighting. This on a relatively large stage for "Moselle" department. Stage of 15m X 9m, dance floor (with in fact backstage included 26m X 10m) So it has long DMX lengths. The grill being between 6 to 7m high. So to limit the worries of lengths in DMX, I have to use some DMX Splitters (4, 6 and 8 DMX outputs) and indeed I do not put a cap on each free output of the splits with only DMX 3 as with those that have DMX 3 and DMX 5 outputs. normaly all is working good. thank ----------------------------------------------------------- Bonjour, J'utilise systématiquement des splitter (2 voies, 4, 6 et 8 voies) ayant en general en alentour de 70 Leds (projecteurs Moving & Statique) avec en plus tout ce qui est éclairage traditionnel. Cela sur une scène relativement grande pour le département de la Moselle. Scène de 15m X 9m, tapis de danse (avec en fait coulisses comprises 26m X 10m) Donc il a de grandes longueur DMX. Le gril étant entre 6 à 7m de haut. Donc pour limiter les soucis de longueurs en DMX, je suis obligé d'utiliser un certain de Splitters DMX (4, 6 et 8 sorties DMX) et en effet je ne mets pas de bouchon sur chaque sortie libre des splits avec uniquement le DMX 3 comme avec ceux qui ont des sorties DMX 3 et DMX 5. Normalement tout va bien ainsi. Une bonne fin de journée Eric
Hello, Good thing this update seems to be working well. It's positive and reassuring. Then concerning the use of old programs from 7.11 to 7.13, I will therefore avoid. Seeing indeed that the new library 3.3 seems to contain 95% of my projectors. Which was not the case with 7.11, where I had to use a lot of "ift" fixtures that Edward had been kind enough to make... So there I have a show at the end of the week, and I'm going to try to use the 7.13 with the 3.3 library. See what gives... And so if I ever have a problem with a fixture, there is now the "creator" and "editor" fixture, it will allow to try that and I hope to solve the problems. In the same way I will follow this show, see for the operation of a node (Swisson XND-4R5 ENode 19 "4 Port 5-pol) that I have had for a few weeks. But not being used to how IP addresses work, I will have to test things a bit... And if it seems to work well, provide a duplicate... (maybe a showtec node) So except big problems, I think to come back at the end of the week for a feedback... Good evening ---------------- Bonjour, C'est une bonne chose, que cette mise à jour semble bien fonctionner. C'est positif et rassurant. Ensuite concernant l'utilisation d'anciens programme provenant du 7.11 vers 7.13, je vais donc eviter. Voyant en effet que la nouvelle lirairie 3.3 semble contenir 95% de mes projecteurs. Ce qui n'etait pas le cas de 7.11, ou j'etais obligé d'utiliser pas mal de fixtures "ift" qu'Edward avait eu la gentillesse de faire... Donc là j'ai un spectacle en fin de semaine, et je vais essayer d'utiliser le 7.13 avec la librairie 3.3. Voir ce que cela donne... Et ainsi si jamais j'ai un soucis avec une fixture, il y a maintenant le fixture "createur" et "editeur" , cela permettra d'essayer cela et je l'espere de resoudre les soucis. De meme je vais suite à ce spectacle, voir pour le fonctionnement d'un node (Swisson XND-4R5 ENode 19" 4 Port 5-pol) que j'ai depuis quelques semaines. Mais n'etant pas habitué au fonctionnement des adresses IP, va falloir que je test un peu les choses... Et si cela semble bien fonctionner, prévoir un doublon... (peut etre un node showtec) Donc sauf gros soucis, je pense revenir en fin de semaine pour un retour d'experience... Bonne fin de journee
Hello, I come back a little on this 7.13 update, because I finally did not have time to install it. What can you say about this new version? Apart from those mentioned earlier in this post, are there any other concerns? Indeed we can imagine what Version 7.14 will give given the satisfaction index of 7.13... A good end of the day to all Eric Bonjour, Je reviens un peu sur cette mise à jour 7.13, car je n'ai finalement pas eu le temps de l'installer. Que pouvez vous dire de cette nouvelle mouture ? En dehors de ceux evoqués plus haut dans ce post, y a t'il d'autres soucis ? En effet on peut imaginer ce que la Version 7.14 va donner au vu de l'indice de satisfaction du 7.13... Une bonne fin de journée à tous Eric
French Manual - Manuel en Francais-FLX&FLX's
van den abbeele Eric replied to van den abbeele Eric's topic in FLX
Bonjour Jean Philippe, J'ai vu qu'Edward t 'a fait parvenir le précédent manuel le 7.9.9. Je peux aussi te faire parvenir une version plus ressente 7.11, qui n'est pas finie d'être traduite correctement... Mais qui prends en compte certaines choses non incluses dans la version 7.9.9. Je vais tenter de faire évoluer les versions 7.11 vers 7.14... (Il y a pas mal d'évolution sur les versions de Zer0S. A savoir que la dans la version 7.13, il y a une grosse évolution. La possibilité de pouvoir créer ses propres Fixtures directement dans la console. Ce qui n'était pas possible avant... Une belle journée Eric V.D.A -
Good news for us. I will Download this new ZerOS and try this Fixture editor... This new 7.13, is really a good thing. thank for All of You Eric (France)
Hello, thank for information Edward. limitation or problems with SSD or Hard disk usb device ? is it better to keep usb device connected on FLX ? Or better to eject ? Thank for your help & advice eric
Hello Edward & Jon, Can you explain a bit how "SETUP" works and the "Save" and "Load" options concerning the "USB keys", "SSD disk" and "Hard disks" media? When using this kind of support on Windows as on Mac, it is important to properly eject everything that is connected to avoid problems & having crash... What about ZerOS when using media through the FLX's USB ports... Is it possible to use SSD disk or HDD Disk without clean Eject ? Have you some other Advice ? Thank you for the info... Eric
Thank for your answers Kevin. It is clear that if on MAC and PC Window, there is a mechanism which allows to properly eject a USB medium and others. On the FLX, this ejection mechanism does not exist like PC/MAC... But maybe the simple fact of leaving the Save or Load menu, finally makes it possible to consider ejecting the USB keys or SSD disk... Without risking major worries... It would be interesting to ask the question to Jon, or Edward to find out more more about the possibilities of backups when we don't have ZerOS server...
I See some différents notice about USB Keys & SSD... "Yes, it's normal to have the impression that USB keys snap faster than other flash memories. On the one hand because we abuse them by savagely removing them from computers, on the other hand because they are for many equipped with the most economical, slowest and most unreliable type of memory over time (TLC), and that they do not benefit from the write optimizations of their SSD cousins. These are sort of poor quality SSDs, which we are sure will die prematurely. They should therefore absolutely not be used as a permanent backup medium. They have the advantage of being compact and economical, but in terms of security over time, nothing still beats a good old external hard drive.
Thank for your answers dear Kgallen… so I will continue to use USB key… I didn’t know what was the problem & I did n’y have a phone near me for taking photo ! so one key was impossible to use & second key was ok I don’t know if it was a internal problem or perhaps only this USB keys that was suddenly corrupted …. but after Mac cleaning all was ok ! i will see this afternoon if it s ok or not …. performance tonight & tomorrow
souhaitons qu'un jour cela arrive...
Hello, I've been on 7.11 almost since it was released on FLX. I did a lot of shows. At least two a week, sometimes 3 or 4... And until yesterday I never had any particular worries. Often used the same configuration by deleting the Cues, adding or removing some fixtures... Made backups so as to always have on USB keys, the state of things and when a show was encoded, to make another backup to avoid starting all over again. Yesterday during the USB backup (before the show of this weekend) I had the impossibility of being able to record on the USB keys, message in red on the screen (Key Zero88 supplied having my first FLX) Fortunately for a few weeks, I had taken the habit of having a second USB key which worked without worries. After cleaning, and removing a certain number of files from the Zero88 Keys, I was able to use it again... (And the messages in red indicating on the FLX screen, the impossibility of recording on the USB keys have disappeared... So I have some questions and advice to ask. In fact I avoid leaving the face front key base, because always afraid in a bad gesture too fast, to tear it off. But on the other hand there remains a port available on the right side of the FLX. I'm thinking of using this one... maybe safer... Then on futur month I had the idea of using a USB HUB (I don't know which brand... Having direction ?) But already to limit the wear of the connector on front panel or on side, to use a 50 cm USB extension to remove and replace the keys on the female part of this extension... But my question is about the backup, maybe using SSD disks which would be more reliable... What do you think ? More reliable than USB keys? Of course, ideally, I would like to have a backup with ZerOS Server, but often the installation of the FLX, projectors and all the hardware is often already done in a hurry, and configuring an additional server seems to me to be complicated to do it calmly... Then it's yet another expense... And for the moment there is already the change of the projectors... How long do you do your backups? On the FLX side, do you often find yourself in trouble? Show unusable? In any case, my experience apart from this problem of backup with USB keys, since 2019, in 7.9.7, then in 7.10, and recently 7.11, I have never had any problems. I find that there is a general stability and everything works well. Have a nice day and thank you all.
Good thing indeed to have a more sustained update rate. Everything is despite the security for users to have enough people in your teams to check that everything is going well with the FLX and FLX'S... I can remember chaotic updates with Apple and multiple crashes around the world... For my part, I had always taken the habit of waiting a good year before moving forward and very often that also saved me from big crashes... Yesterday (with 7.11) I had problems, impossible to save on USB keys (Zero88 Key). for the past two months, I have been systematically recording on 2 different keys. And the second key worked. I had my Mac with me, did a little cleaning on the Zero88 keys, did a little vacuum and was able to do the recording again... The red lines of code indicating that the recording on the USB key in question was impossible then disappeared... But I had a heat stroke... beautiful end of the day Eric
Very good thing and thank a lot. Three Update in 8 month... Great for us. So I will have a last performance before holidays. So I Did every performance with 7.11 and having no problems. I use since June the same configuration (just changing some DMX address and Erasing CUES when I was making a new show. ) But all was stable and I having no Bug ! Using 2 universes with Leds, Moving Wash & Spot, using traditional projector... And all was working good ! So I well try 7.12 in August (after hollydays) & I will continue French traduction & wishing to continue to doing French Video Helping... So take care & good things for you dear Jon & also for Edward too, Eric from France
USB HUB & Ethernet Booster for FLX ?
Thank Iank99 & Edward for the Answers. So for Ethernet Cable, I must think about this. Using Fibre Optic, It s sure that I will no use this for instance... Price & I think that a bit more fragile than RJ45/ethernet.... Have a nice day, Eric -
Hello Question 1 About USB Hub that I want to add for use with my FLX, Two wings, one 22 inch screen Monitor and I want to add 1 mouse & 1 Keyboard... Have you a recommended brand ? Most of USB Hub are working now in USB 3.0 ? Is it a problem ? Question 2 I think in few week about using Ethernet Link and using a Node on stage... So I know that the Ethernet Cable have limited distance... Less than 100 meter, (DMX is Less than 400 m...) Have you some information about Ethernet signal Booster ? What do you do with long section ? For instance for DMX, I use Splitter/booster and the signal look to be OK.... But having other solution can be good... Thank a lot Eric Eric
Programmer Time is really good to use. I use This option since 2019 and it's giving a good way for making manual change during performance...
good thing to know too ! have good work !
What would you like to see in ZerOS?
van den abbeele Eric replied to Jon Hole's topic in General Discussion
good thing to know... Thank a lot Jon, have a nice day -
Hello, For instance some part looks to be ahead : - Improve effects engine - Rig plan layout - Custom desktop layouts on FLX / FLX S - Undo functionality - Fixture builder within ZerOS - Dimming curves When do will stop this topic and start to add some popular choice on futur ZerOS ? Thank Eric -
Good to know ! I Would like to be a official tester !
- 1 reply
- 1
Hello, Any idea when 7.12 will be released? Thank Eric
I have also noticed the problem that when I program the last cue, whatever the number, it automatically offers to return to Cue 1. What would indeed be practical is to be able to decide that the last active Cue is the Cue with the highest number OR to be able to return to CUE 1 if there is a need to make a loop. In any case, it's still nice to have this functional 7.11 that allows you to work wisely. But I will certainly have more precise comments with the big show which arrives at the beginning of June. Lots of fixtures and lots of CUEs in sight... This is going to be a big test of stability and operation.
