thierry
Everything posted by thierry
  1. Hi everybody, and happy new year for all of you... Since i'm in 7.9.6, the desk has a strange behaviour when i change the pages of the playbacks... There's a big delay between the display of each page, and if i switch too fast too many times, the desk is completely "lost" unabled to display anything right in time
  2. I did the update, Everything seems to run correctly... You're right, i 've used the "boot method" to install the previous Zeros 7.9.5... I've just plugged the USB drive this way and load the os live as you recommended , and so far so good... Thank's a lot, as always, you rule
  3. Only the : n°1 mfk button "1E [No Effect]" is generated... I'm still in 7.9.5... It could be the issue ?
  4. Perfect, thank you
  5. Hi everybody, Strange behaviour of the desk today, the auto effect generator is not working anymore... I can generate auto colour, auto beamshape, but there's nothing to do with the " automatically create effect palettes " button... I just have a n°1 mfk button "1E [No Effect]" and a mfk n°36 "Effect 36"... ?????
  6. Hi everybody, 10 cues in one playback, i'm in cue 5 and want to go back to cue 4 or another number of cue.... I've tried this but it doesn't work : "Jumping to a cue (Go To cue) Goto cue allows you to jump to a specific cue. Simply hold down the playback’s GO button, type the cue number to jump to, and then release the playback’s GO button."
  7. Of course, as simple as described... Thanks, Thierry
  8. HI everybody, An other "basic" question, but how can i insert a cue between two others ? I've tried the old "memory"way but it doesn't work
  9. Thanks a lot, it's all right now. I've done so many manipulations that i must have been "colour enabled" in my submaster an "colour fade time" in my cues, or "colour disabled" in my submaster and "no colour fade time" in my cues.... All the best, Thierry
  10. Hi everybody, here is my problem : i record a cue with 4 fixtures intensity 100%, colour red i record the 2nd cue on the same submaster with the same 4 fixtures intensity 100%, colour blue when i switch from cue 1 to cue 2, the red become blue instantaneously, which is so far normal because the two intensities are 100% and only the colour is changing But i would like the colour to fade from red to blue, and it doesn't seem to work even if i specify the colour to fade i'm doing something wrong for shure, or the settings of my fixtures are wrong Something strange is that when i specify a fade in the beamshape area (strobe for example) with the same fixtures, that's ok, the strobe runs after my fade time Any idea ?
  11. Hi Edward, i know what the "Load button" does, but i was talking about that: I didn't know that i had to type "Special" again to reach the second digit page, I did try everything but not that
  12. Hi Edward, Firstable, thank you for your answer. But did i miss something, is it written somewhere ? or is it another super user secret ?
  13. Hi, i'm back again. I must be stupid, but i can't load any cues named 65, 87, 23 ... How can we load cues with names superior to 9 ?
  14. OK, my channel MixMode is HTP, i think i must set it to LTP, and only keep HTP for my submasters. Now, i can make a device disapear by decreasing it's intensity, then updating the cue...
  15. Hello everybody, how to edit a particular intensity of a particular projector in a cue ? i can increase without any problems and update the cue when it's about automatics and with traditionals pebbles or profiles, but i can't decrease an intensity with traditionals (something to do with htp/ltp ?) how to delete "live" a standard fixture in a cue ? i can manage my cues when it's about automatics fixtures, but with a profile or a pebble convex ?
  16. Okay, so it's about the device's functionality... I will have a look at the manual if the ROBE Robin600e is doing the job or not Thanks for all
  17. Sorry, i was wrong, nothing to do with the "MOD" option. I've read the page 75 of the manual and i understand now what it means . I just want to have a full black between cues, i don't want the intensity to raise, i want CUE1(position, effect, intensity level x) then BLACK before CUE2(position,effect,intensity level x). I just want to see my moving heads moving from CUE1 to CUE2 in dark an then... FULL CUE2 Is it possible, or do i need to record cues with the intensity appart ?
  18. Hello, I have many cues with 4 Robin Robe (different positions, effects, focuses, ...) I would like to have a "dark state" during transitions between these cues in a playback, i think it should be the job of the "move on dark" (or something else...) option but i don't know how to manage it . Any idea ?
  19. Of course i think that it's better to set up correctly the desk & the power rack when we need a direct "on/off". i have my first 28 circuits plugged on a old Solution28 rack, an all the rest on ADB racks, so working with the SolutionXL is not a problem because ADB racks support the option of managing dimmers (curves, on/off...). But my "past" ADB Cantor desk used to do the job as well, but my "new" SolutionXL not, so if i need an on/off patched from 1 to 28, i can't have it unless i do what i explained before...
  20. Ok, i've plugged the device i needed to an adb rack where i can set up the dimmer to on/off... But i've tried something before with my old solution28 power rack : patched my fixture as a dimmer , then recorded this fixture as a cue in a submaster, then i told that submaster to have the trigger release level at 100% (raise & lower menu)... it seems to do the job without damaging the fixture...
  21. Hi everybody, is it possible to patch a fixture as an on/off switch, because i can't specify that i want an on/off circuit in my power rack ?
  22. Everything fine with my "record" tries, thank you
  23. No, it's just a question of copying everything in one time without returning back each time to the playback i'm copying from. But you're right, if i put correctly at the right place the "Key" cues that i often use (ex 1 to 5, page 1), "Page Lock" can help keeping it in other pages (1 to 5, every pages used) Thank you, i'll make a try and let you know Regards, Thierry
  24. Hi everybody, two questions today : - 1 : is it possible to copy several playbacks of one page at same time, and then paste in another page ? - 2 : is it possible to record scenes from playbacks ?
  25. Hello TomM, here's what Edward answered to me about the same topic, but on 7.9.3 : To update a cue/step of chase, you need to go into it using GO Snap. You can do this by holding SHIFT + tapping the chase's button. You will find that rather than acting as a tap tempo, it now acts a GO Snap and pauses the chase from running. This allows you to go to the step you need to edit, make your changes, tap UPDATE, and then tap the chase's button. You can then tap the chase's button again and the chase will resume to run automatically. Hope that helps, any queries let me know Edward Regards, Thierry
