83
How to control the FLX S Buttons remotely from ZerOS Monitor?
Edward Z88 replied to MatthewD's topic in FLX S24 & FLX S48
Hi Matthew, Thank you for your comments. We have had a couple of requests to remotely change the fader function. This is possible on the larger FLX console through programming a macro. This is already logged on our system. We haven’t currently scheduled which version of ZerOS this will be included in. All the best, Edward -
Hello, As Kevin has explained, it sounds like the MACs have accidentally been recorded into your Smoke machine Submaster. There are a couple of reasons this could have happened. Firstly, the console maybe in Full Programming mode. When in this mode, if you tap the Program button, a snapshot of the console’s output will be captured. When in Partial Programming Mode, only tagged parameters will be stored. Tagged parameters are parameters you have adjusted manually, indicated by a white background in the encoder LCDs. You can change the programming mode by holding SHIFT + MODE to enter Setup, and then arrow down to <Record Options>. Partial is the default. Therefore to solve this, ensure the console is in Partial Mode, ensure the Smoke machine is the only fixture tagged, and program onto a submaster. The reason you’re seeing this is as Kevin says, pushing that submaster up is the latest command you have sent to the fixture. This is due to LTP (Latest Takes Precedence) behaviour. If you lower the submaster, a new command is not sent to the fixtures, and therefore they remain doing what they’re doing until they are given a new command. Hope this helps, if you have any queries let me know. Edward
Hello, I haven’t personally used FLX with W-DMX G5 products. I would have thought if the DMX signal is fine from FLX over wire, this same signal will be transmitted wirelessly, and so you should in theory receive the same quality of data. If the TX box has a DMX out port, have you tried plugging in a terminator? Are the W-DMX products on the latest firmware? All the best, Edward
Hi Eric, We definitely agree. We think it’s very important to support customers to ensure they can get the most from the products. An updated manual and more videos are definitely something that will be released in future. In the meantime, you may find the knowledge base a useful resource... http://support.zero88.com/Consoles/FLX/ Edward
Hi Eric, Thank you for your comments. Noted. This is something we are working on. In the meantime, you may find the FLX area of the knowledge base a useful resource... http://support.zero88.com/Consoles/FLX/ All the best, Edward
Hi Eric, Software updates usually take less than a minute to install. Show files are forward compatible, and therefore you are able to load your show file from previous software into new software. However, it is always good practice to perform software updates after a show run has finished plenty of time before the next, just to give you time to get used to any changes. If you would like to become a beta tester, please drop us an email to support@zero88.com, and we’ll be able to add your forum account to the group. If you have any queries let me know. Edward
Hi Eric, Thanks for the post. Glad to hear you’re enjoying Zero 88 Lighting Controls! If you have any questions just let us know. Edward
Hi Wolfgang, You won’t be able to create a fixture where the intensity switches. This functionality is available with a Relay using the Beamshape attribute. If you wish to use a fader to switch for whatever reason, patch a relay, turn it on, and record to a playback. Then go into the playback settings, choose Raise and Lower, and then set the trigger level to the percentage you’d like the fader to trigger the relay. Hope this helps, any queries let me know. Edward
Hi Nigel, Great, glad to hear it. Edward
Hi Nigel, This is all the information required to create a fixture file. Please drop us an email to FixtureSupport@zero88.com with all of these images, and one of the team will be able to send a file across to you. Let me know if you have any queries. Edward
Hi Mark, Hope you're well. This hasn't been created yet, due to ZerOS 7.9.5 development. I haven't forgotten, and will look to create this when the next software version has been released. All the best, Edward
Hi Peter, If you are going through these cues in order, these fade times are not required, as there is no intensity information changing from cue to cue. If you do wish to see these fade times, simply go into a cue, add a fixture intensity into the programmer and update the cue. You should find the fade time values appear again. Hope this makes sense, Edward
Hi Pete, As Kevin says, this is due to these cues not having any intensity changes from the previous cue. Any queries let me know, Edward
Hi Dan, Thanks for posting. We are still looking into this. Are you still finding that FLX is ignoring MIDI Timecode after a period of time? Do there seem to be any common traits each time? For example, does FLX seem to stop listening at a certain timecode? If there’s any further information you can provide, that will help us to recreate and find the cause of the issue. Edward
Options for cost effective control/visualisation setup?
Edward Z88 replied to drscoop's topic in FLX S24 & FLX S48
For on site training, please drop us an email to training@zero88.com for a quote. The Chauvet Ovation F-415 FC is included in the latest Zero 88 Fixture Library. Version 37 was released this week, and a list of fixtures included in this release is available here... http://support.zero88.com/975072641 To download this Fixture Library, see the link below... https://zero88.com/forum/files/file/8-fixture-library-full/ To load this into the console, download and extract the files, and copy them into a USB stick. You can then plug the USB stick into the console, tap SETUP -> Load File, and choose the Fixture Library. You will then need to power cycle the console. To load this into PhantomZerOS, copy the Fixture Library to the file directory that PhantomZerOS looks at, and again tap SETUP -> Load File, and choose the library. All the best, Edward -
Hello, Great. We have just released Zero 88 Fixture Library v37, which contains over 9500 fixtures. If you do however come across a fixture that isn't in the list, you can either make the file yourself using our free to download fixture tools, or drop us an email to fixturesupport@zero88.com, and one of the team will be able to email the file across for you to load in. To access each individual parameter of a fixture, this is done using the encoder wheels. You can control these in Phantom ZerOS by viewing the front panel of FLX S, and clicking and dragging on the encoder wheels. In Phantom ZerOS you may also find it useful to use syntax to set the parameter levels. You can do this by holding SHIFT and clicking on the parameter name displayed above the encoder wheel, and then type @ followed by the percentage you wish to set the parameter to, and press ENTER to confirm. If a fixture has more parameters within an attribute than there are encoder wheels, you have to page through. For example on FLX S24 controlling a fixture with 5 colour controls, you will only access four of these parameters at a time on the encoders. To page through, click the Attribute tab at the top of the touchscreen. You will see the parameters on the encoders change. Looking at this fixture file, it has 2 sets of RGB control when in 9 channel mode. Currently, FLX S can only handle 1 set of RGB within a fixture to give access to the auto palettes, colour picker and LEE Filters Mood Boards. If a fixture has multiple colour mixing elements you instead can use the encoder wheels directly, and then of course record your own custom colour palettes if you wish. Hope this helps, any queries let me know. Edward -
Hi Keith, Glad to hear the desk is now running at 100%. For advice on obtaining spares, feel free to drop us an email to support@zero88.com, and we'll be able to point you in the right direction. All the best, Edward
Hi Alex, No, it won’t. However if all the user fixture files are now included in this latest fixture library release, you can tap SETUP -> Clear Options -> Clear User Files, to ensure you don’t have duplicate library entries. It is worth mentioning a Factory Reset will leave this library installed, but remove all show data, settings, and user files. Hope this helps, Edward
Hi Vijay, Welcome to the Zero 88 forum. This forum will give you the best responses for queries regarding Zero 88 Products. I would therefore also recommend posting your query on a general lighting forum such as the Blueroom technical forum, which is regularly checked by many knowledgeable people who I'm sure will reply promptly. See below for the Blueroom technical forum... https://www.blue-room.org.uk/index.php?showforum=2 All the best, Edward
Hello, When enabled, PhantomZerOS will talk to Capture on a 127.0.0.1 IP address, without the need for a PhantomZerOS unlock dongle. This IP address basically means that PhantomZerOS can communicate with another peice of software on the same PC. I believe that a Capture package will only be able to be installed on a single PC. I don’t believe they use USB unlock dongles. In theory though, if you were to buy multiple packages for multiple PCs, you would then be able to have an instance of PhantomZerOS running on each one. That’s correct, you could simply plug your PC and FLX S24 into a wireless router using standard Ethernet cabling, and then communicate to Capture on the PC and use the Remote app wirelessly. This also gives you the added benefit of using DHCP (automatic IP address assignment) on the router to configure all the devices without the need to worry adjusting IP addresses. This will give you a single universe of console control over Capture. FLX S24 consoles come in 1 or 2 universe variants. No problem at all, totally understand! If you have any queries let me know. Edward -
Hello, Whilst we wait for any responses from users with their experiences, I’ll just provide a little information on the subject. Virtually all visualisation packages allow for either Art-Net or sACN (DMX over Ethernet protocols) input, and therefore work with consoles with this functionality. FLX S consoles support both Art-Net and sACN, however also support the CITP protocol. Capture visualisation software can be controlled by CITP, which allows for 2 way communication between the console and visualiser - this therefore allows you to create a look using the visualisation software without the console being connected, and then when you link the console, you can record this lighting state into a cue. It also allows for selecting multiple moving fixtures in Capture, right-clicking on stage where you want them to focus, and you can then record that as a position palette on the console. Another benefit of Capture, is it can be used on the same PC as PhantomZerOS, allowing you to program with visualisation without the need for a console or Unlock Dongle. For information on how to link Phantom ZerOS and Capture on the same PC, see the article below... http://support.zero88.com/988883201 Hope this helps, if you have any queries let me know. Edward -
Hi Nigel, Yes, to Record just the UV parameter onto a playback, it is exactly the same process as RGB, as noted in the article here... http://support.zero88.com/1014413041 All you’ll need to do, is ensure the Intensity and UV parameters are at full, and are the only parameters tagged (indicated by having a lighter blue encoder background, and a red intensity value in the output window). You’ll then be able to record this to a playback, ensuring SmartTag is disabled. Dont forget you can download PhantomZerOS onto a PC, so that you can practice this beforehand by emulating a FLX S. PhantomZerOS is available to download here... https://zero88.com/forum/files/file/17-zeros-794/ If you have any queries just let us know. Edward
Hi Keith, No problem. If you have any queries just let us know. Edward
Happy to help! Let us know if there’s anything else we can do. Edward
Hi Carsten, A Red Step On Effect means that by default, Red is at 50%, and Green and Blue flash on from 0%-100%. These levels can of course be adjusted by changing the colour parameter levels in the Colour attribute. Red Step off on the other hand, means that by default, Red is at 50%, and Green and Blue flash off from 100%-0%, again intensities of each colour can be adjusted. You can best see this happening by tapping Z/Shift -> System Information -> DMX Outputs for the fixture's RGB levels. Hope this helps, if you have any queries let me know. Edward
