84
Hello, If you have tried these fixture files in the library, and can confirm the address and mode on the star cloth matched those on the console, it sounds like your star cloth is slightly different to the one in the library. Do you have a manual that came with this Star Cloth, or are you able to find one online? If so please send this to FixtureSupport@zero88.com, and one of the team will be able to make you a fixture file. Hope this helps, if you have any questions let me know. Edward
Hi Olly, Really glad to hear you have the console back and the issue has been resolved. They're very solid PSUs, so as you say, that is very unusual. If you have any questions as always feel free to get in touch. Edward
Great! Glad to hear it. If you have any questions just let us know. Edward
Hi Louks, It sounds like you are trying to install the console software using the old installation method. For instructions on installing ZerOS 7.9.5 from 7.9.4, see the article below... http://support.zero88.com/1518910761 Hope this helps, if you have any questions let us know. Edward
Hi Eric, No problem, let us know if you have any questions. Added to the knowledge base article... http://support.zero88.com/1011707631 Cheers, Edward
Hello, That's correct - Fader Controls, can be enabled per attribute of a playback. In channels function, the faders will only ever control a channel's intensity. All the best, Edward
Hi Eric, If you hold SHIFT and press RECORD, this will give you a snapshot - "Record All" is written in the command line to show you this. This will therefore turn SmartTag off, but it will record every fixture, and every parameter, irrespective of whether they're tagged or not. Therefore doing this you would need to be careful to ensure all other fixtures are at the values you would like them to be in for their defaults. Whereas if you simply manually turn SmartTag off at the point of recording, only tagged information would be stored. Hope this helps, Edward
Zero 88 operator 4 Small Awards London
Edward Z88 replied to Tristan Mac's topic in General Discussion
Hi Tristan, Welcome to the Zero 88 Forum, hope you find someone to cover this. Just so you're aware, I have deleted your duplicate thread under General Discussion, to keep this in one place. All the best, Edward -
Hi Simon, On FLX consoles, only one playback can be viewed at a time, so in your set up for the MIDI Notes to work you will need to be viewing the macro playback. By viewing, this means the playback has been chosen by holding VIEW and tapping the playback's button, so that it is brought into the cue list window. You can then continue to use the other desktops. If you would like to remotely see what cue you're in, you could move your main playback to an empty playback on the multi-function faders. You could then remotely view the Faders desktop, which indicates the current and next cue number for each playback. You would need to re-record your macro with the new playback go button if you wished to do this. Hope this helps, Edward
Hi Eric, The default values, are the values your fixtures go to when no playbacks are running, and there is no information in the programmer. If you would therefore like to default the positions of your moving fixtures on stage, move them to the location you would like them to be in, tap RECORD HOME -> Default. You will need to ensure SmartTag is disabled whilst doing this. Anything in the programmer will then be stored as the defaults for the tagged fixtures. If you simply select your fixtures and turn them on, you will now see them in their custom position. If you look at the Pan/Tilt grid, you will also see how they are no longer in the middle of the grid. If you record the Default value using a palette, the default position will reference the palette, and therefore if you update the palette, the fixture's defaults will also update. Hope this helps, Edward
Hi Eric, The Fader Controls option allows parameters of the enabled attributes, to be scaled manually from their current value, to their programmed value, rather than snapping or fading as soon as the playback is triggered. If you have a playback where you would like to enable Fader Controls position, go into the playback settings, and choose position. Now this fader will control the intensity, but also the position of the recorded fixtures. Hope this helps, Edward
Hi Serge, Welcome to the Zero 88 Forum, glad to hear you’re using FLX S. There is a known issue changing playback fader functions to one of the manual fade options, and then back to default again. You are correct, the best way to rectify the issue is copy the playback to an empty playback, and then copy back over the top of the original. This will be repaired in a future software update, but there is no date on this yet. If you have any questions just let us know. Edward
As of today, we have ZerOS 7.9.6 running on our consoles in house. We are working on finishing manuals and release notes, and we will then be able to release. Edward
Hi Martin, Yes, unless we find any issues with the software in the next week, we are happy to release ZerOS 7.9.6 very soon. Internally we have had minor revisions since the ZerOS 7.9.5.10 release candidate. Entirely up to you whether you’d like to wait for ZerOS 7.9.6. If you are happy with ZerOS 7.9.4 for now, you may as well stay on that software version, and upgrade straight to 7.9.6 when released. If you have any questions let me know. Edward
Hi Roger, Is the strip blinder patched as a single fixture on your Solution or as 10 individual dimmers? If patched as 10 individual dimmer channels, you can use the automatic Chaser effects, and apply an offset. If you have a single fixture patched with each Lamp under the "Beamshape" attribute, you will need to go to the Waveforms tab of the Effects window, and apply a Sine wave, speed, size and offset for each lamp. To open the Effects window, hold SHIFT and tap EFFECT. Hope this helps, if you have any questions let us know. Edward
Hi Roger, If you are running the latest release software, when you press "Automatically Create Effect Palettes" 45 auto effects should be created. ZerOS 7.9.5 is the latest release software for Solution. If only one effect palette is created, please try installing ZerOS 7.9.5 again. ZerOS 7.9.5 can be downloaded from our website here... Installation instructions can be found here... http://support.zero88.com/1518910761 Hope this helps, if you have any questions let us know. Edward
Great! If you have any questions just let us know. Edward
Article updated, let me know if there's anything else you feel would be beneficial... http://support.zero88.com/990063141 Edward
Hi Kevin, Macros are only required if you want a single Note command to emulate a Go button press. In most uses of MIDI Notes as the article describes, the Note number you send to the console, will trigger that cue number on the viewed playback. I will however add this information as a tip under the Note's Cues section. Edward
Hi All, Apologies for the lengthy delay on this. Due to the delay in getting the manual out, we have taken the decision to release the manual alongside ZerOS 7.9.6, to help future proof it. ZerOS 7.9.6 has been in release candidate stage since mid-July. We are planning to release this month. If you have any questions let us know. All the best, Edward
Hi Simon, With MIDI Notes, each individual Note command triggers each individual cue. For example when the console is set to Notes triggering Cues, and it receives a MIDI Note On 10 command, the console will trigger cue 10 in the currently viewed playback. If you wanted to simply emulate a Go button press with the same MIDI Note command, you could do this, however via programming a Macro. Firstly, program a macro that presses your Go button. You can do this by tapping RECORD MACRO x ENTER (where x is an empty macro number) -> Keys -> Press your Playback's Go button -> MACRO. Now, view an empty playback, and program an empty cue. Go into this cue's settings -> Macros... -> Macro Add -> Choose your Macro -> OK -> OK. Now, whenever you send a MIDI Note 1 command and you are viewing this single cue macro playback, it will emulate a Go button press of your main cue stack. Hope this helps, if you have any questions let me know. Edward
Hi Neil, No problem - just send us a copy of your show file when you get a chance and we'll take a look. Edward
Hi Simon, There are 3 different MIDI Protocols FLX supports. These are MIDI Timecode (MTC), MIDI Show Control (MSC) and MIDI Notes. All three can be used to trigger cues on the Master Playback. The article below goes through each of these, and how they can be configured on FLX... http://support.zero88.com/990063141 Hope this helps, if you have any questions just let me know. Edward
Hi Joe, Hope you're well. No date on Stage Sizing yet. We require a new fixture library for this, to gain more information such as Pan and Tilt ranges. The current plan for the road-map is the new fixture library will be released as ZerOS 7.9.7, and so Stage Sizing will then be able to be released after ZerOS 8. Edward
Hello, Yes, for this I'd program a new playback. Record 50 cues, each one turning each pixel from your chosen blue, to your chosen orange. I'd recommend using palettes for this, so that if you wish to change your night time blue, or your sunrise orange, you can update the colour palettes and all 50 cues update automatically. As you step through each fixture and change it from blue to orange, you may find the SHIFT + Right Arrow key shortcut helpful, for selecting the Next fixture. Then for each cue set a colour fade of 30 seconds, and an Auto With trigger, with a wait of 6 seconds. I'd recommend temporarily changing the console fade time defaults, to save you having to change 50 cue's fade times. To do this tap SETUP -> Defaults -> Cue Colour Fade. You can then trigger this playback from a cue in your Master Playback if you wish, whenever you need to use this sunrise effect. Hope this helps, Edward
