85
Effect changes when i record it to the playback
Edward Z88 replied to sossy's topic in FLX S24 & FLX S48
Hi Kay, The default fades for Intensity, Colour and Position are 3 seconds. However, the first cue in a playback will always default to a 0 second fade on intensity. This therefore gives you control of the intensity using the fader, rather than a fade automatically running. Therefore when @sossy stored this effect as a single cue on a playback, intensity was 0 seconds and position was 3, so they became out of sync. He could therefore dial out the fade time for position in that playback, or he could have changed the position defaults before storing. Hope this helps, Edward -
Hi Kay, That's great to hear. Thanks very much for the feedback. Edward
Hi Kay, To change the fade time defaults, tap SETUP -> Defaults -> Cue Fades. You can then set them to be the same if you wish. Edward -
Hi Kay, Yes, that is correct. Right clicking a button on the front panel holds it down, until it is right clicked again. Edward
No problem, as you can see on the Legacy area on the ZerOS page there are versions still available from the past few years if you do wish to roll back. If you have any questions let us know. Edward
Hello, You can roll back the software on ZerOS consoles if you wish. ZerOS 7.9.4.3 is not currently on our website, however ZerOS 7.9.5 is... https://zero88.com/zeros#legacy Out of interest, why do you wish to downgrade? Edward
Hi Zulu, Yes, the fixture tools software was written before FLX range consoles were launched, however files made in this software are compatible with FLX range consoles. If you have any questions regarding creating fixtures, or would like us to write any files for you, send us an email to FixtureSupport@zero88.com. Edward
Hi Theirry, Thank you for your feedback. The software team are currently still investigating the cause of this. In the meantime if you have any questions let us know. Edward
Hi Jakob, No problem, yep, makes is much easier to see what fader does what, without needing to get your tape out and write on it! Edward
Hi Jakob, Yes, both playbacks and channels can be named, and their names can then been viewed in the faders window. To name playbacks, press and hold SETUP and tap the playback's button to open the Playback Settings. Then tap Advanced, and tap playback name to give it a name. You can either use the onscreen keyboard or an external USB keyboard. A shortcut to access the playback settings, is to view the faders window on the touchscreen, and then press the on-screen fader. To name a channel, press SETUP, and then tap the channel button you wish to name. You can then tap Change Names to give it a name. You can select multiple channels at once if you wish, and change all of their names at the same time. Hope this helps, Edward
That's great, glad to hear it. If you have any questions let us know. Edward -
Hi Chris, No problem, really glad to hear this solved the problem. Any questions just let us know. Edward
Hi Chris, Have just replied to your email. Edward
Hi Eric, I have taken a look at the LEDSTAGE Zoom Led Par fixture. Correctly, Red, Green and Blue are defaulted to full, as there is a dimmer channel. However from your description it sounds like the dimmer channel on the fixture is not scaling these correctly. Are you able to email us a copy of the fixture's manual to FixtureSupport@zero88.com? If so we'll be able to check the fixture matches the personality for FLX. If you wish to use the fixture in 6 channel mode, I'd recommend patching 6 dimmer channels on FLX as you have done, and making a note of what each channel does. Make sure the address of the fixture matches the address of the first channel fader. Hope this helps, if you have any questions let us know. Edward
Hi Ian, yep, this is exactly what it sounds like. FROG2 consoles use the same encoder assembly. Edward
Hi Chris, Importing a .ift file would not cause this issue. It sounds like it just happens to be a coincidence. From the description it sounds as if it is a hardware fault with that wheel, and therefore a software update won't solve this. Event monitor will show you the signals the console is receiving from the various controls. The difficulty of the repair depends on the exact cause of the issue. If you are happy opening the console, it would be worth checking the wheel assembly is seated correctly. Usual caveats apply with regards to opening consoles up - don't do this if you are not confident. Happy to continue discussing this over email, please drop us an email to support@zero88.com. If you have any questions let us know. Edward
Hi Jakob, Welcome to the Zero 88 Forum. When using this effect, make sure both intensity and position fade times are the same. Otherwise one element of the effect will lag behind the other, and they won't be in sync. Therefore when you have recorded this onto a playback, press and hold VIEW and tap the playback's button, and then edit the cue fades so intensity and position match. Hope this helps, Edward -
Added to the article below... http://support.zero88.com/1011404471 Edward
Hi Kay, After applying multiple effects, to remove one of them, tap the Effects tab, until you see "Exx Size", on the second encoder wheel, where xx is the number of the effect you wish to remove. For example "E21 Size" for the Auto Rainbow effect. The effect numbers are displayed in the auto effect palettes. Then dial the size to 0. The effect is then removed. To find out which effects are running, select your fixtures, tap Effect, and the active effects will be displayed on the wheels. Tap the Effect tab to cycle through the active effects. Hope this helps, Edward
Hi Kay, When renumbering a cue stack, most people use this for 1:1 numbering, and so isn't an issue. However adding a number pad in this window is logged on our system as an enhancement (reference number ZOS-8681). Unfortunately this currently isn't scheduled to be included in the next software version. If you have any questions let us know. Edward
Difference between Solution& LeapFrog
Edward Z88 replied to loui013's topic in Solution & Solution XL
Hello, Not really, you are correct, Solutions are a refresh of LeapFrog consoles. Internally newer Solution’s have larger storage and more RAM, but operationally they are identical. Therefore the Solution manual and training material is applicable for LeapFrog consoles on the latest software. Hope this helps, Edward -
Hi Oliver, Welcome to the Zero 88 Forum. The way this is typically done is using Beam palettes. To do this, turn each light on, and individually set their focus to the value you need to make your Gobos sharp in your chosen position. Then tap RECORD, and tap an empty Beam palette on the touchscreen, marked with an asterisk. Now whenever you select any of your fixtures, you can simply tap this Beam palette, and they will recall your custom focus. Hope this helps. Edward
Hi Kay, That is correct, on FLX S, the renumber function is for 1:1 renumbering, unless you have a USB keyboard connected. That is correct, renumbering cues will not renumber Next jumps. If you have any questions let us know. Edward
Hi Sam, Welcome to the Zero 88 Forum. Are you trying to control a group of fixtures (each or which being the individual parts of your whole fixture) by a single channel fader? If so this can’t be done. You can however record your multiple parts as a group. You can then select the group, press Z, and control the intensity with the intensity wheel on the first encoder. If you simply want to control their intensity from a fader, set all the parts to full, and then record this to a playback fader. Hope this helps, Edward
Not back to default, it will clear the patch for that address. You can see this when you’re doing it on the console, as the channel number disappears for that DMX address. Edward
