82
Hi Joe, If you select the fixture, and open the "Shutter, Strobe, Control" parameter details by tapping the middle encoder button, try tapping the last "Macros" detail, which will set the parameter to a DMX level of 251. Leave it there for a few seconds, and see whether the fixtures respond. If they don't, it sounds like DMX Lamp Off is disabled in the fixture menu. If you have any questions let me know. Edward
Hi Joe, I have just taken a look at the Martin Mac 250 Entour fixture. The new library has a "Fixture Global Reset", and a "Lamp Off" macro available for the fixture. In the new library, if a macro has been created to control a function of a parameter, that parameter's detail will instead display "Macros", to indicate the fixture macros can be used to access this function. There are two fixture macros for the Mac 250 Entour. If you are seeing more these will be from other fixtures currently patched in the console. Lamp On can be accessed by selecting the fixture, and tapping the middle encoder button of the "Shutter, Strobe, Control" parameter, to view the details. You can then tap "Lamp On", to send the command. After selecting the fixture, and applying the "Lamp Off" macro, the first parameter is taken to full, and then lowered again. This can be seen in the DMX Outputs window, and so the macro seems to be working correctly. Can you confirm the DMX lamp off function hasn't been disabled on the fixture (PERS/dLOF)? More information on page 14 below... https://cdn01.usedlighting.com/products/files/f58c30c67693da.pdf If you have any questions let us know. Edward
Hi Joe, Great, glad to hear it. Ah interesting. I am guessing, that you have come to FLX from an older ZerOS console, and therefore this is the method you have always been used to? Loading the software application directly into the console like a show file, is the recommended installation method, and is the method detailed in the release notes. Performing the software update via the bootable drive method, is more of a recovery tool now. If you have any questions, please let us know. Edward
Hi Jason, Yes there certainly is! No problem at all! Edward
Hi Jason, Here's another thought - we could just look at doing this with colour fades, and no intensity changes. This would mean we'd need to be careful with tagging as Kevin mentioned earlier. The cue stack would look like this... In cue 1, my fixtures are at full, in red. In cue 2, my fixtures are at full, in black. You can create black quickly by using the slider in the colour picker window to pull all colour mixing down. When cue 2 is triggered, I therefore have a 5 minute fade out of red. In cue 3, my fixtures fade up to full blue, a minute after cue 2 was triggered. The key however, is ensuring that only blue is tagged in cue 3. You can do this by creating blue, but then tapping on the "Red" and "Green" parameter displays so they have a dark blue background rather than light blue, which will display "Untag [Red]" and "Untag [Green]" in the command line. If red is tagged, it will not continue being controlled by cue 2, and so its fade out would slow, so that red would be out at the same time you reach full blue. If SmartTag is enabled, the console decides what gets stored. When SmartTag is disabled, you decide. Therefore for all of this, I have had SmartTag disabled, as I need to be specific about what does and what doesn't get included. I hope this helps, let me know your thoughts. Edward
Hi Jason, Yes 3 cues is easiest here, as we turn lights off, change their colour, then turn them on again. You could probably get rid of “Cue 3” in my latest example, and also have the colour change from red to blue in cue 2, with colour having a 4 minute fade, and a 1 minute delay. My cue 4, would then need an Auto With wait time of 3 minutes. In many ways though, it is easier separating it out into separate cues for each part. This works, however the fixtures will be halted at 80% for the duration of the colour fade, rather than dipping in intensity, however this may be what you’re after. Edward
Hi Jason, The intensity of red, as shown in your graph, will have completed its fade to 0 at minute 5. This is true of cue 2 in my image above, due to the 5 minute fade down. Red fading down between minute 3 and 5 is theoretical in this instance, as the intensity will have begun to rise again at minute 3 (cue 4 starts). However when red is at "0", there is still a minute of colour mixing left to complete, due to the 5 minute colour fade in my cue 2. If the colour needs to be full blue at minute 5, then simply change the colour fade in my cue 3 from 5 minutes, to 4 minutes. As cue 4 is set to "Auto With", not "Auto After", changing the timings of cue 3 will not affect cue 4. This would then give in my example: In cue 1, your red lights are up. In cue 2, your red lights are fading down to 0% over 5 minutes. No colour information included, therefore no colour times are shown. [Minute 0 in your graph] In cue 3, your lights then begin the 4 minute cross fade from red to blue, which begins 1 minute after the reds started fading. There is no intensity information included, therefore no fade up/down times shown. [Minute 1 in your graph]. In cue 4, your lights then begin to fade back up to full over 3 minutes, 2 minutes after they started to change to blue. This starts when they are magenta - 50% red and 50% blue, mid colour cross fade. There is no colour information included, therefore no colour fades are shown. [Minute 3 in your graph]. Result once cue 4 has completed - a minute after completing the fade to blue, the fixtures hits 100%. [Minute 6 in your graph]. Hope this helps, Edward
Hi Jason, Thanks for the graph, that is great! Bet you wish your designer could have shown you that at the start! In that case, we'll be looking at this... In cue 1, your red lights are up. In cue 2, your red lights are fading down to 0% over 5 minutes. No colour information included, therefore no colour times are shown. [Minute 0 in your graph] In cue 3, your lights then begin the 5 minute cross fade from red to blue, which begins 1 minute after the reds started fading. There is no intensity information included, therefore no fade up/down times shown. [Minute 1 in your graph]. In cue 4, your lights then begin to fade back up to full over 3 minutes, 2 minutes after they started to change to blue. There is no colour information included, therefore no colour fades are shown. [Minute 3 in your graph]. Result once cue 4 has completed - red to blue fade ends at the same time as blue hitting 100%. [Minute 6 in your graph]. In theory the intensity of the colour will remain the same (assuming the red and blue LEDs are equally intense, which is unlikely), as you will go from one LED colour at full, to both LED colours at half (equaling the same intensity as one LED colour at full), to the other LED colour at full. In your graph though of course, you are dipping to 40% of the overall intensity mid fade. Hope this helps, Edward
Hi Jason and Kevin, Ultimately, it sounds like the designer was trying to explain what he wanted as if there were red PARs and blue PARs, not taking into account that for you, a red PAR and blue PAR are the same fixture when they're LED! Maybe I have misunderstood this, but it sounds to me this should look like this... Your reds are up in cue 1. Your reds start to fade down in cue 2. After a minute, cue 3 fades your lights back up again, taking 5 minutes to get to their intensity, whilst they crossfade from red to blue, also over 5 minutes. Remember as far as the console is concerned, there are no lights fading down in cue 3. In terms of your output window, you will see them dip to 80% over a minute, and then raise to full over 5 minutes. If after a minute of the reds fading down, you needed the fixtures to halt at 80% for 4 minutes, then raise to 100% over a minute, it could have looked like this... Your reds are up in cue 1. Reds fade down to 80% in cue 2 over a minute. Cue 3 runs once the fixtures are at 80%, and the fixtures then start to change to blue over 5 minutes, however remain at 80% for 4 minutes, due to cue 3's delay time. They then raise back to full over a minute. Unless I have misunderstood, I therefore don't believe this is down to tagging. Worth mentioning, "Keep Parameters Separate" is set to "No" for colour, to ensure that with SmartTag disabled, if you move a colour encoder, all colour parameters will be tagged, to ensure all parameters are stored, equating to your desired colour. I hope this helps and makes sense, if you have any questions let me know. Edward
Hi Edden, Welcome to the Zero 88 Forum. I have replied to your Facebook message, however I’ll reply to your query here too. It is possible to trigger Solution XL consoles, by adding an optional triggers card. This card has MIDI connections. SCS will be able to output MIDI with an appropriate USB to MIDI interface, which you can then use to trigger cues on the console. The ENTTEC DMX USB Pro MK2 can be connected to one of the Solution’s USB ports, to give you another DMX output. I hope this helps, if you have any questions let us know. Edward
Hi Laurent, Welcome to the Zero 88 Forum. That's great, glad to hear you chose FLX S. These are the steps to take if you cannot see your fixture in Add Fixtures... https://zero88.com/library#support If you would like us to make the fixture file for you, please email us a copy of the fixture's manual to fixturesupport@zero88.com, as mentioned in "Option 3" in the link. Yes you can, for more information, see below... http://support.zero88.com/996119181 Unfortunately, Phantom ZerOS is currently not available in a native Mac version. If you have any questions, please let me know. Edward
Hello, Unfortunately the ZerOS Remote Apple Watch app is not compatible with watchOS 7. We will release an update to the app in future that supports watchOS 7. If you have any questions let us know. Edward
Hi Stan, OK thanks for the update. Keep me posted if you have any queries. Edward
Hi David, Sounds like a nice neat set up. Thanks for sharing. Edward
Bonjour, Les applications ZerOS Remote & Monitor sur iPad ne peuvent pas se connecter à la console via USB, mais si vous souhaitez utiliser une connexion filaire, vous pouvez utiliser Ethernet à la place. Quel modèle est votre iPad? Selon le modèle, vous pourrez utiliser soit un adaptateur Lightning vers Ethernet, soit un adaptateur USB-C vers Ethernet. Lorsqu'il est connecté à l'iPad, une nouvelle option «Ethernet» apparaîtra dans l'application Paramètres sous l'option «Wi-Fi» habituelle. En appuyant dessus, vous pourrez alors configurer les paramètres réseau de votre iPad. Si vous utilisez un serveur DHCP sur le réseau, l'iPad se verra automatiquement attribuer une adresse IP. Si vous souhaitez brancher l'iPad directement sur la console, vous devrez configurer une adresse IP statique sur l'iPad qui se trouve sur le même sous-réseau que la connexion à distance de la console. J'espère que cela vous aidera, si vous avez des questions, faites-le moi savoir. Hello, The ZerOS Remote & Monitor apps on iPad cannot connect to the console via USB, however if you wish to use a wired connection, you can use Ethernet instead. What model is your iPad? Depending on the model, you will be able to use either a Lightning to Ethernet adapter, or USB-C to Ethernet adapter. When this is connected to iPad, a new "Ethernet" option will appear in the Settings app under the usual "Wi-Fi" option. Tapping this will then allow you to configure the network settings of your iPad. If you are using a DHCP server on the network, the iPad will automatically be assigned an IP. If you wish to plug the iPad directly into the console via Ethernet, you will need to configure a static IP on the iPad which is on the same subnet as the remote connection of the console. I hope this helps, if you have any questions please let me know. Edward
Hi Ian, Rather than being able to record playbacks directly onto the channel faders, you can use spare channel faders to control playbacks on other playback pages. This can be done using DMX In, by linking one of your unused DMX outputs on the back of the console to the DMX input port, on Leapfrog or Solution consoles. The topic below mentions this, which may be the one you saw... The instructions above are as per software versions ZerOS 7.9.2 - ZerOS 7.9.4. If you are running the latest software (ZerOS 7.9.7), the options are found in slightly different Setup menus. To configure this, firstly readdress the channel faders you wish to use to control some of your playbacks. To do this, tap SETUP -> Fixture Schedule, and then tap the channel buttons you wish to edit, in order. You should then just see these fixtures in the Fixture Schedule. Then tap "Address" at the top, and assign these onto a free desk universe you are not using, starting at address 1. Then, tap Universes within Setup, and scroll down to the Desk Universe you just assigned your channel faders to. Under DMX for that Desk Universe, you can then configure an unused DMX port number on the back of your console to output this universe. You can then use a short DMX cable to come out of this port, and then into the DMX input. Then, tap Triggers within Setup, and under DMX In, you will be able to add playbacks that you wish your incoming DMX channels to control. I hope this helps, if you have any questions let me know. Edward
Hi Ian, It sounds like in that case your non-library fixtures are not included in the new library. You can therefore either continue using your legacy fixtures, which will work fine, or you can send us an email to fixturesupport@zero88.com with a link to your fixture's manual, and request it gets added to the new library. There are no plans to update the Fixture Editor software yet. You will still be able to use this to create fixture files in the old Zero 88 library format, which you will still be able to load in. As the current Fixture Editor just has the Beamshape attribute, not separate Beam and Shape attributes, upon loading these ".ift" files into ZerOS, any gobo parameters will automatically be pulled into the Shape attribute, leaving the remaining Beamshape parameters under the Beam attribute. I hope this helps, if you have any questions let us know. Edward
Hello, Yes that is correct. As Solution XL and Leap Frog 96 consoles are different console types, ZerOS will give you a warning. However as Leapfrog 96 and Solution XL operate in the same way, you will not lose any show data. The Dockhouse Capture project file (Project.zip) is available to download from the article below... http://support.zero88.com/1004254221 You will then be able to open this in your licensed version of Capture. On universe 1 in the demo file you will have 10 Clay Paky A.leda Wash K20 moving washes rigged above the stage, and 8 ADB ALC4 LED cyc lights. Edward
Hi Stan, Update the software and let me know how you get on. It sounds like your dimmers are RDM as they are discoverable by RigSync in the current software on your console. Therefore the exact model of Chilli shouldn't make a difference. Edward
Afternoon Kevin, RigSync will see multiple single parameter "sub-devices" under the Chilli, and so as long as that model of Chilli supports RDM, which it sounds like it does as they are discoverable, FLX S will be able to patch it. If you have any questions let me know. Edward
Hi Stan, Great thanks for confirming. We have of course tested these thoroughly with FLX S and know they work correctly. Since FLX S was launched we have made many improvements to RigSync to allow it to use RDM effectively as possible. ZerOS 7.9.7 was released in December 2019, so if your console has never been updated you may be 1 or 2 versions behind. If so I would recommend updating. If you have any questions let me know. Edward
Hi Stan, OK thanks for the information. What dimmers are you using? What software version are you running? You can find your current software version by tapping Z/Shift -> System Information, and in this window will be a line of text displaying the Software Version. Currently the latest software is ZerOS 7.9.7. If you are not running this version, I would recommend updating your console. ZerOS 7.9.7 is available from the website below... https://zero88.com/zeros#download If you have any questions let me know. Edward
Hi Stan, Welcome to the Zero 88 Forum. When you boot FLX S48 for the first time, it will boot with no fixtures patched. This means that your channel faders will not control any fixtures, as your console doesn't yet know what lights you have. If you have RDM dimmers and fixtures, the console will be able to discover them and patch them for you, automatically assigning them to faders. If you don't have RDM fixtures, and you would like to patch dimmers to the 48 channel faders, you can tap SETUP -> Add Fixtures, and then tap Next, as dimmer will be preselected. You can then press and hold the first channel button, and tap the last, which should light all 48 channel buttons. You can do the same on channel faders 49-96 by using the page button. If channel buttons don't light when you tap them, there is already a fixture assigned to that fader. You can then tap Finish, and the console will patch those in. You can then tap SETUP to save and exit, and your faders will then control your dimmer channels. I hope this helps, if you have any questions let me know. Edward
