85
software crash - unable to reinstall software on leapfrog 48
Edward Z88 replied to Pollefeyt's topic in Leap Frog 48 & 96
Hi Nick, If you have experienced difficulties getting the console to accept the software installation, have you tried configuring the Master Boot Record of your bootable USB drive, as per the information below... https://zero88.com/manuals/zeros/software-updates/zeros-usb-creator/mbr-2 If you have and you are still unable to update your console's software, please drop us an email to support@zero88.com, and we'll be able to advise on the best option to get the console up and running again. If you have any questions let us know. Edward -
Bug with DMX IN timings set to trigger playbacks
Edward Z88 replied to delicolor's topic in Solution & Solution XL
Hello, Improvements to flash triggers from the DMX Input are logged as reference number ZOS-7827 on our system. I have raised the priority of this issue following your findings. If you have any questions let me know. Edward -
Thank you! Now I'm back, normal forum service will resume... Cheers, Edward -
No problem, glad that solved the issue. If there's anything else we can help with let us know. Edward
Hi Gerran, Welcome to the Zero 88 Forum. Please tap the Z button, to open the Quick Access functions on the internal touchscreen. The fourth encoder wheel is the programmer fade time control. Tap the middle button of the encoder wheel to disable this fade time. For more information see the link below... https://zero88.com/manuals/zeros/z-key/z-encoders Hope this helps, Edward
Hello, To achieve this, you can disable Release On Lower. To do this you can hold SETUP, and tap the button of your playback. Then choose "Raise and Lower" from the top, and disable Release on Lower. For more information, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower Hope this helps, Edward
Hello, Welcome to the Zero 88 Forum. As @delfine mentions, the easiest way to do this is by copying your original cues, and pasting them into the new cue numbers you require. For more information on copying cues see the link below... https://zero88.com/manuals/zeros/cues-playbacks/copying I hope this helps, Edward
Hi Nick, I would recommend installing ZerOS 7.9.9 software on your Leapfrog 48. ZerOS 7.9.9 can be downloaded from the link below... https://zero88.com/zeros#download Please follow the instructions below for installation instructions... https://zero88.com/manuals/zeros/software-updates/zeros-usb-creator If you have any questions let me know. Edward -
Yes, you will be able to patch onto any of the 64 universes, and then route this universe from port 2 for example, on a 1 universe FLX S24. You won't be able to patch more than 512 channels across the available universes on a 1 universe FLX S24. Edward
Hello, If a DMX Input is raised quickly, and is mapped to control a playback, this will emulate a flash button press for that playback. Raising the DMX input slowly with give you intensity control over the playback from the DMX input value. Hope this helps, Edward -
Manually releasing playbacks with programmer time active, by pressing and holding CLEAR and tapping a playback's button, will fade the intensity over the programmer time. Attributes will then snap-release at the end of the fade. For maximum control, you may wish to have a separate playback, which just controls the Zoom. All your other playbacks could then have no information for the Zoom. This way, you know the Zoom will only move when you adjust your Zoom playback, allowing you to control it at a rate you know will be quiet. Edward
Hello, Fixture macros cannot be created. These are included in the Fixture Library, and are generated upon pressing "Automatically Create Macros" after patching your fixtures. If you wish to access the original version of the Mac 550 with the Lamp On macro, please see the fixture file below... https://zero88.com/fixtures/legacy-library/Legacy library (gft41.0)/MARTIN/Mac 550.ift Hope this helps, Edward
Issue resolved here...
Hello, What was the DMX input connected from? If channels on the DMX Input are raised or lowered quickly, this will display Press and Release on the status display. The six buttons bottom left of the Front Panel display, show the Remote Switch inputs. If a remote switch is pressed they will highlight. Hope this helps, Edward
Hi Ceri, You could still achieve this using the Remote Desktop method. If you are using a PC running ZerOS Monitor, you could use your now surplus touchscreen connected to the PC, to give you an additional touchscreen. By default, desktop 1 will have the Outputs and Cues Windows on the top and bottom half of the external monitor respectively. You can also view these Windows on the internal touchscreen if you wish. More information here… https://zero88.com/manuals/zeros/desktops-windows/external-display Glad to hear it, and no problem at all. If there’s anything else you need let us know. Edward
Hi Tim & Kevin, It is not as easy as just calculating a BPM for a given Speed value. This is because if you look at converting a waveform to BPM, you would have to factor in both the Speed and Offset - this therefore is also affected by the number of fixtures the effect is running over. For example, automatic effect 4 "Chaser 1/8", with speed of 20, offset across 8 fixtures, gives you 120 BPM. The same effect offset across 4 fixtures at the same speed would give you 60 BPM. The ability to give effects a BPM, and for them to calculate the required speed, is logged on our system as reference number ZOS-8694. I have raised the priority of this following your request. A possible way of dealing with this if you are recording effects into cues, is to get your speed roughly correct, record the effect into a cue, and then on playing back the cue, use a Speed Override fader to boost up or slow down the speed slightly on the fly to suit. See the link below for more information... https://zero88.com/manuals/zeros/cues-playbacks/special-playback-functions#override If you have any questions let me know. Edward
Hi Ceri, Welcome to the Zero 88 Forum. FLX has a single DVI-D output for an external monitor, which can be a touchscreen. To add additional external desktops, you can connect tablets, PCs or laptops over the network, running the ZerOS Monitor apps. For more information see the link below... https://zero88.com/manuals/zeros/setup/devices/remote-apps Thanks @kgallen for the lightning fast response! Appreciate it. If you have any questions let us know. Edward
Hello, That is correct, Solution consoles will continue to receive software updates. If you have any questions let me know. Edward
Hello, Yes it does. Booting Solution/Leapfrog consoles with the SETUP key held down will boot into Test Mode. That is correct, the best route to go down first is compressed air spray. In the meantime, to avoid channels being brought into the programmer, resulting in cues not playing correctly, you could switch the channel faders to HTP mode. This will mean the levels will mix HTP with cues, rather than "LTP catch". HTP channel values are displayed in yellow in the Output window. Alternatively you could enable the Preset control, meaning the channel faders can only output if the A or B master is raised. These options can be found on the MFKs by tapping SPECIAL. I hope this helps, if you have any questions let me know. Edward
Hello, As @kgallen says, you simply need to make sure your White chase releases. This will then allow your Red/Blue chase to resume. For example: Record your fixtures at 100% in red on playback 1 Record your fixtures at 100% in blue on playback 1 (choose Create Chase) Record your fixtures at 100% in white on playback 2 Record your fixtures at 100% in black* on playback 2 (choose Create Chase) Configure the button function of playback 2 to be latch This will allow you to raise playback 1 to start your red/blue chase, then tap the button of playback 2 to trigger the strobe, and then tap playback 2's button again to resume the red/blue chase. *In this example, by black we mean the intensity of the fixtures is at full, however their RGB(W) values are at 0. This means that you won't have to worry about intensity mixing options between playback 1 and 2. I hope this helps, if you have any questions let us know. Edward
Hi Nathan, No problem at all, glad that solved the issue. We have received your email to support, and will advise on the procedure to get the battery replaced. If you have any questions let us know. Edward
Hi Nathan, Welcome to the Zero 88 Forum. Is the Speed Override fader at 50%? This is the fader that can change the speed of your cue transitions, which is the right-hand fader in the Master Playback section. If this is at full, your cues will snap. If you’d like guidance on replacing the battery, please drop us an email to support@zero88.com. If you have any questions let us know. Edward
Hello, Thank you for confirming. If you tap Z/Shift -> System Information -> System Text, and scroll through, are there any lines of text displayed that are not white? If so could you email me a picture of these? If you have any questions let us know. Edward
Hello, Thank you for the description of the issue. Sorry to hear you have experienced this issue with your console. When the issue occurs, do you have any USB devices connected/is the console connected to a network? If so, what devices are connected? If you disconnect these, do you still experience the issue? If you have any questions please let us know. Edward
Hi Emrys, ZerOS now uses an entirely new fixture database. This database change was introduced in ZerOS 7.9.8. Therefore even though the new ZerOS Library (.zlbr format) contains almost twice as many fixtures as the "legacy" Zero 88 Library (.ift format), there's no guarantee fixtures in the legacy library are in the new ZerOS Library. If you have therefore programmed your show file in ZerOS 7.9.7 or earlier with the old library, and then loaded this show file into ZerOS 7.9.9, you may find you are unable to convert your fixtures to the new library version, if the fixture was in the old library, and not the new library. In these cases, please drop us an email to fixturesupport@zero88.com, detailing the fixtures missing from the new library, and we will make sure these fixtures are included for a future ZerOS Library release. In the meantime you can continue to use the "legacy" format fixtures in your show file. See the link below for more information... https://zero88.com/manuals/zeros/patching/fixture-schedule/change-fixture#convert I hope this helps, if you have any questions let me know. Edward
