Edward Z88
  1. No problem - we're proud of our history and have no plans to remove all the great content. There are some gems, especially the "Eclipse" console manual!... https://zero88.com/storage/downloads/cdaf1417-1dac-4a61-a588-71e98cfb3444/Eclipse-Operating-Manual.pdf https://zero88.com/control/eclipse Edward
  2. Hi @aaronh2 If there are individual fixture files you need for Frog consoles, these can be found and downloaded from the link below... https://zero88.com/fixtures/legacy-library/Legacy library (gft41.0)/ If you have any questions, please let us know. Edward
  3. Good spot!! There you go... https://zero88.com/control/alcora Time pot caps are correct, and it keeps @kgallen happy - win win!! Edward
  4. Hi Ian, You'll be pleased to hear no information has been lost. All non-ZerOS information, is now available as a download to each legacy product page... https://zero88.com/a-z https://zero88.com/control/jester https://zero88.com/control/frog https://zero88.com/control/alcora If you have any questions let me know. Edward
  5. Hi Mac, For information on configuring the Remote connection on FLX, please see the link below... https://zero88.com/manuals/zeros/setup/devices/remote-apps For information on using the Remote Apps with FLX, please see the link below... https://zero88.com/manuals/zeros/networking/using-the-remote-apps For information on configuring your PC's IP address, please see the link below... https://zero88.com/manuals/zeros/networking/windows-ip-configuration I hope this helps, please let me know how you get on. All information from the knowledge base articles, now fit into the relevant section of the ZerOS Online Manual... https://zero88.com/manuals/zeros The support.zero88.com has now been retired. If you have any questions let me know. Edward
  6. Hi Joshua, Thanks very much for the update. Really glad to hear this works with the Jester. If there's anything else we can help with, just let us know. Edward
  7. Hi @drscoop Thanks for confirming - same watch as me 🙂 Edward
  8. Hi @drscoop Great news - thanks for confirming. Out of interest, could you confirm which model of Apple Watch you are using? Many thanks, Edward
  9. Hi @REDBEARD Welcome to the Zero 88 Forum. Interesting question - I guess “disco lighting” could be subjective. On Jester 12/24 consoles, you can program any of your 24 control channels into “chases”, to allow you to flash and fade channels on and off one after the other. For more information on chases, please see page 16 of the Jester manual… https://zero88.com/storage/downloads/7d3249f0-bde3-471d-8830-d4253ff0dc06/Jester-Manual-3.4.pdf If you have any questions let us know. Edward
  10. Hi Joshua, I haven’t used this device in the past, and haven’t heard of any Jester users using this device. It appears to be designed for MIDI Notes, but it may work with MIDI Show Control. Apologies I can’t provide any further guidance than that! Edward
  11. Glad to hear that has solved the problem. If there’s anything else you need let us know. Edward
  12. Hi @Jooj Please let me know how you get on. I would also agree that it sounds like the console is used in a very dusty environment to exhibit these symptoms. FLX S24 consoles were launched in 2017, so it can only be 4 years at the oldest. @kgallen Contact cleaner can be used VERY sparingly on these self-greasing faders (just a minute drop), which can bring them back to life if they are not registering correctly. Use air duster if you want to be on the safe side. If this doesn't solve the issue, the faders will need to be replaced. Edward
  13. Hi Eric, Thank you very much for continuing to make updates and improvements to your French translation of the manual. Edward
  14. Hi Joshua, Welcome to the Zero 88 Forum. As per the link @Jon Hole posted, devices that look like this rarely work with the MIDI Show Control protocol. Any MIDI interfaces from reputable manufacturers should be compatible with the MIDI Show Control protocol. For testing and demonstrations, we use a MOTU MIDI interface. If you have any questions, please let us know. Edward
  15. Bonjour Bienvenue sur le Forum Zéro 88. Merci pour la description détaillée de vos résultats en mode test. Je recommanderais d'injecter du "nettoyant de contact" dans les faders et de les travailler de haut en bas. Cela éliminera toute saleté pouvant causer un enregistrement incorrect des faders. Veuillez n'en utiliser qu'une très petite quantité dans chaque fader - une trop grande quantité causera des dommages permanents aux faders. Une fois que vous avez appliqué un nettoyeur de contact à chaque fader, redémarrez la console en mode Test, pour vous permettre de voir comment cela a affecté les faders. Si vous avez des questions, s'il vous plaît laissez-nous savoir. Hello Welcome to the Zero 88 Forum. Thank you for the detailed description of your findings in Test Mode. I would recommend squirting some "contact cleaner" into the faders, and working them up and down. This will clear out any grime that may be causing the faders to register incorrectly. Please only use a very small amount in each fader - too much will cause permanent damage to the faders. Once you have applied contact cleaner to each fader, boot the console into Test Mode again, to allow you to see how this has affected the faders. If you have any questions, please let us know. Edward
  16. Hi Tony, You shouldn't need to do anything else - connect your audio feed, enable Sound to Light on a chase, and then run the chase... https://zero88.com/manuals/zeros/cues-playbacks/chases/chase-settings You may find it easiest to set the Chase's speed to 1 BPM - that way you can see the Sound To Light triggers more easily. If there doesn't seem to be any audio reaching the console, you can boot the console into Test Mode. For information on accessing Test Mode, please see the link below... https://zero88.com/manuals/zeros/trouble-shooting/test-mode If you choose the "Other Test" tab at the top, this will then show you the audio levels being received. If you have any questions let me know. Edward
  17. Hello, Thank you for checking. Please find the updated fixture file attached... B1R Beam UPDATE.ift Please try this, and let me know how you get on. If you have any questions let me know. Edward
  18. Hi @kinous Can you confirm the address and mode set on the fixture match the settings on the console? Edward
  19. Hi @pierotec & @drscoop, I am pleased to report that watchOS 8, solves the compatibility issue with the ZerOS Remote app for Apple Watch. Therefore, Apple Watch Series 3 and later can now use the ZerOS Remote watch app again. If you have any questions, please let us know. Edward
  20. Hi @kinous The fixture file for the Stairville B1R Beam can be downloaded from the link below... https://zero88.com/fixtures/legacy-library/Legacy library (gft41.0)/STAIRVILLE/B1R Beam.ift The fixture file for the Varytec Hero Wash 715 HEX LED can be downloaded from the link below... https://zero88.com/fixtures/legacy-library/Legacy library (gft41.0)/VARYTEC/Hero Wash 715 HEX LED.ift For information on loading these fixture files into FLX S consoles, please see the link below... https://zero88.com/manuals/zeros/setup/load/fixture-files-2 If you have any questions let me know. Edward
  21. Edward Z88
    Copying Cues
    No problem. Suggestion logged as reference number ZOS-10847 on our system. If you have any questions let us know. Edward
  22. Edward Z88
    Copying Cues
    Hi @Gafferted It is not possible to copy a cue and paste it to multiple locations at once. You can however copy multiple cues, and paste them to a location. For more information see the link below... https://zero88.com/manuals/zeros/cues-playbacks/copying Hope this helps, Edward
  23. Hi Dave, Fat Frogs can control a total of 12 fixtures, using the 12 fixture keys. These can’t be paged. For information on the Fat Frog, including the manual, please see the link below… https://zero88.com/control/frog If you have any questions let us know. Edward
  24. Hi @kinous Sorry to hear this, could you confirm the address you emailed this to? I have forwarded your fixture request to fixturesupport@zero88.com, and we’ll be able to get back to you next week. If you have any questions let us know. Edward
  25. Hi Steve, No problem. Glad to hear it. I believe this is already logged on the system as a future enhancement. I can check next week. If you have any questions let us know. Edward
Ă—
Ă—
