81
Done - https://www.zero88.com/manuals/zeros/controlling-fixtures/tagging
Thanks, Kevin You can clear a single fixture from the programmer, meaning it won't get recorded in cues when SmartTag is disabled. To do this, hold SETUP and tap an empty UDK. From the Normal dropdown, choose Clear Fixture, and click OK. Now, you can select fixtures, and tap the Clear Fixture UDK, and those fixtures will be completely removed from the programmer. I cannot think of a reason why you would want to leave a whole fixture in the programmer but untagged. If you wanted to do this, you would have to hold CLEAR, and tap each attribute key, and then tap the Intensity wheel's encoder button to untag intensity too. Personally if I had fixtures in the programmer, but only wanted some of them to get recorded, I would select the fixtures first, and then tap RECORD > Selected Fixtures. Hope this helps.
Hi @Amy Worrall As usual, @kgallen & @Davidmk have done an excellent job of responding to your points. Do let us know if you have any outstanding questions. Just to add a couple of extra comments on the points below... You are correct - you will definitely want to work with SmartTag disabled, coming from Eos. With SmartTag disabled, you are forced to build the next cue from the last cue, which is a workflow you'll be more familiar with. Personally I always program cue stacks with SmartTag disabled. Yep - all ZerOS palettes would be "by-type". Please see the link below for more information... https://www.zero88.com/manuals/zeros/palettes/advanced-palettes You'll see you'd be hard-pushed to do this by accident! On FLX, there isn't TIME syntax. Therefore, you will need to edit individual attribute timings for each cue. Note - if you tap on a fade time cell, you can hold SHIFT and tap the Up/Down arrow keys to increment/decrement by a second, which will speed things up, saving you having to type into each cell. FLX does not feature fixture-copy. You therefore cannot say "Fixture 15 copy to fixture 18". If fixture 15 and fixture 18 are the same type, you could do this via a palette. Please see the link below... https://www.zero88.com/manuals/zeros/palettes/advanced-palettes If you have a USB keyboard connected, you can use @ CUE syntax. 2 @ 0/10 ENTER would set fixture 2 to the values it is at in cue 10 of the Master Playback. I hope this helps. If you have any questions, please let us know.
"Black"-Fader ONLY for certain Groups/Lights
Edward Z88 replied to Jakob Klucke's topic in FLX S24 & FLX S48
Hi @Jakob Klucke Welcome to the Zero 88 Forum. To do this, you could record an Inhibit playback, to create a custom intensity master fader: First, set all of the fixtures that you would like to be controlled by your custom master fader to full. Then tap RECORD, and tap an empty playback's button. Hold SETUP, and tap the button of the playback you just recorded, to open the Playback's Settings. Under "Intensity Mixing" choose Inhibit, and click OK. Now, this playback fader will act as an intensity master control, just for the fixtures recorded to it. Please see the link below for more information on Inhibit... https://www.zero88.com/manuals/zeros/cues-playbacks/playback-settings/general#intensitymixing Let us know if you have any questions. -
Hi @DALX ZerOS will not map the DMX Input universe to a DMX output and merge the console output. DMX Input is not designed to provide full remote control of fixtures patched in the console. DMX Input can be used to control individual fixture intensities, or playback levels. Please see the links below for more information... https://www.zero88.com/manuals/zeros/patching/fixture-schedule/dmx-in https://www.zero88.com/manuals/zeros/setup/triggers/dmx-in-2 There are currently no plans for this functionality. What would be the real-world scenario where this could be useful? Let me know if you have any questions.
Hi @Harold Welcome to the Zero 88 Forum. No. ZerOS 7.14 includes a significant change to how colour mixing is processed internally, which means show files saved in ZerOS 7.14 cannot be loaded into earlier versions of ZerOS. Where possible, we aim to make show files saved in the latest version compatible with the previous version, however in this instance it is not possible. We never guarantee that show files can be loaded into earlier versions of ZerOS. We do always guarantee show files from earlier software can be loaded into the latest version. The console's software will need to be updated. Software updates only take a couple of minutes to do and are straightforward. Once updated, you will be able to load in your show file without issue. If you have any questions, please let us know.
- 1 reply
- 1
Makes sense 👍 OK great. If you would like to send over your show file first I would be happy to investigate. There's nothing obvious that comes to mind, so a show file would be helpful.
Hi @SCE If you would like ONLY the rainbow effect to be recorded, without intensity, you will need to ensure that SmartTag is disabled in the Record Options window. When SmartTag is enabled, the console will only record fixtures that are on. If you can share your show file, I would be happy to take a look to see what may be preventing the effect from outputting. If you do share your show file, please detail the fixture numbers you are using, the effect you are applying, and the playback you are attempting to record to. I will then be able to investigate. As a side note, the latest software for Solution consoles is ZerOS 7.14. If you would like to update your console's software, please let me know, and I can share installation instructions.
Bonjour, Heureux d'apprendre que vous êtes en mesure d'utiliser la console comme prévu. FLX n'enregistrera JAMAIS automatiquement un cue en appuyant sur RECORD. Vous devez définir où vous voulez stocker l'état après avoir appuyé sur RECORD. Si la mémoire enregistrait automatiquement sur la lecture 1, cela suggère que le bouton de la lecture 1 était enfoncé ou que quelque chose appuyait sur les touches d'un clavier externe. Hello, Pleased to hear you are able to use the console as expected. FLX will NEVER automatically record a cue upon pressing RECORD. You must define where you want to store the state to after pressing RECORD. If the cue was automatically recording to Playback 1, this suggests either playback 1's button was stuck down, or something was pressing down keys on an external keyboard.
The "White Strobe" playback would need both intensity information and colour information stored, to ensure that whatever the fixtures were doing, you would achieve an intensity strobe in white when played back. Therefore, if the colour of the fixtures is currently in the programmer, this playback would take that data out of the programmer when it is triggered. So, you would either need to store your look to a palette (SHIFT-RECORD to include everything in a single palette), and apply this after using the strobe playback, or as you say, you would need to record the current state onto a fader, trigger it, and that way upon releasing your white strobe playback, the fixtures will go back to the state in the active playback. Hope this helps.
If you trigger playback 7 again, this then becomes the latest instruction for the fixtures, and so playback 7 takes control over the fixtures. If these fixtures were the only things in the programmer, and playback 7 has taken control of them, the programmer is emptied - you'll notice that the LED in the CLEAR button turns off, because playback 7 has taken control, and so there is nothing left in the programmer. Therefore, lowering the playback fader, results in the fixtures going back to default. This is where you could disable release on lower to prevent the fixtures going back to default.
Hi Mil, Correct - based on your original description I wasn't sure whether you were looking to sync to an audio track or live music. It is not possible to trigger a Global Tap Tempo playback over OSC. It is possible to send a Playback Go x message, where x is the playback you wish to trigger. Each time this command is sent you would step through each cue on playback x. If you sent these commands to a chase that was running, you would end up with a mixture of the chase automatically running using Tap Tempo, and jumping cues when OSC GO messages are received. I hope this makes sense.
These are the exact steps I'm following: Load show file Raise playback 13 ENTER ENTER (to select fixtures and see parameter table in the Output Window) The fixtures are in colour palette 12 (Blue) by default Raise playback 7 - the fixtures go Warm White as programmed Press playback 7's button - the fixtures go Red as programmed Apply colour palette 6 - the fixtures go Yellow as programmed Release playback 7, by either lowering its fader or hold CLEAR and tap playback 7's button - the fixtures remain in yellow, as colour palette 6 last changed the fixture's colour (LTP) If I DON'T apply colour palette 6 in step 6 above, the fixtures DO go back to default as expected upon lowering playback 7 in step 7. This is because if a playback has control of fixtures, and that playback is released, the fixtures then go back to the values of the playback that previously had control of the fixtures. If no playbacks that have values for the fixtures are currently active, the fixtures go back to their defaults. It is possible to prevent a playback from releasing when lowered, meaning it will remain in control of the fixtures until something else on the console takes control of the fixtures. To configure this, hold SETUP and tap the playback's button to open the playback's settings. Choose Raise & Lower from the top, set Release On Lower to disabled, and click OK. Hope this helps.
Hi Mil, FLX S consoles do not have Sound-to-Light functionality, so there is no way of automating a chase to follow the beat of an audio track. When a chase is programmed on a playback, the playback's button automatically becomes a Tap Tempo, allowing you tap the playback's button to synchronise the chase to a beat. You could program a sequence of cues on a playback. Theoretically, you could then send repeated OSC GO messages to trigger the cues on this particular playback one after the other, essentially resulting in the cue stack on the playback behaving as a chase. To do this you would need to come up with a way of a software package taking an audio track, and then repeatedly sending a particular OSC message on each beat. Alternatively, you could use more of a "timecoded" approach, where you start an audio track in a software package, and automatically at certain points in the track the software package sends OSC messages to FLX S, which then trigger certain cues at different points in the song. Hope this helps,
Salut @jeansted Bienvenue sur le forum Zéro 88. Pour voir les cues sur le Master Playback dans la fenêtre Cues, maintenez enfoncée la touche VIEW et appuyez sur le bouton GO du Master Playback. J'espère que ça aide. Hi@jeansted _ Welcome to the Zero 88 Forum. To view the cues on the Master Playback in the Cues window, press and hold the VIEW key and tap the Master Playback's GO button. I hope this helps.
Solution XL - General Views & Lifetime Expectancy
Edward Z88 replied to Uriahdemon's topic in Solution & Solution XL
Hi Mac, The core functionality and workflow of Solution XL consoles is similar to FLX, as they both run ZerOS. In many ways Solution consoles are more similar to FLX S than FLX - there is no syntax numpad, and you are limited on the number of fixtures you can patch. There are a handful of features introduced in recent versions of ZerOS, that have not come across to Solution consoles, due to Solution consoles featuring older processors. Solution consoles were discontinued in 2021, and so the warranty of the very last Solution consoles will be running out in early 2024. If you have any questions, please let us know. -
Hi @PJRichards Intensity values in the programmer have the highest priority on the console. The CLEAR key is required to remove high-priority intensity programmer values, to allow cues to playback as programmed. All other attributes (Colour, Beam, Shape, Position) mix LTP, irrespective of whether they are being controlled manually or by a cue. You shouldn't be seeing this behaviour. If you have fixtures in red on a playback, you select them and tap your blue palette, lower the playback fader so it releases - the fixtures should stay blue, because nothing has told the fixtures to change colour. Therefore it sounds like there could be a setting in your show file that is affecting this behaviour. Please feel free to attach your show file, and detail which fixtures, playbacks and palettes you are using. We can then investigate further. Please let us know if you have any questions.
Lock parts of the FLX S Desk for simple users
Edward Z88 replied to discover's topic in FLX S24 & FLX S48
FLX S consoles can be locked to prevent programming from being edited and prevent settings from being changed. Whilst locked, cues can continue to be played back. @Davidmk has helpfully linked to the relevant section of the manual that provides more detail. If you have any questions, please let us know. -
Hi @Jakob Thank you for the feedback. If you would like to see OSC Output functionality added to ZerOS, please vote for "Trigger Outputs" here... This poll allows people to vote for features they'd like to see in ZerOS. Please let us know if you have any questions.
Hi @Malvern I have just replied to your support email regarding this.
The ZerOS Online Manual PDF can be found here... https://www.zero88.com/storage/downloads/manuals/zeros-en.pdf?230718
Hi @discover FLX S consoles do not have an internal battery, which means there's no way of keeping time. FLX consoles do have an internal battery. FLX S consoles have a different processor to FLX consoles. Hope this helps.
To be clear, FLX S consoles do not have an internal date/time clock. Therefore files saved from FLX S will appear to have erroneous dates/times when viewed in Windows File Explorer for example. If you would like to keep track of when your show file was saved, you can of course add the current date/time to the end of the file name.
MIDI Timecode is ideal for triggering the console in applications like this... https://www.zero88.com/manuals/zeros/setup/triggers/midi-timecode Any USB to MIDI interface that is compatible with Windows and supports MIDI Timecode can be used. Show Cue Systems is a Windows software package that can trigger audio tracks and MIDI Timecode. However, I don't personally have any experience of using this.
Hi @LIGHTING I believe you have been emailing Keith regarding this. Let us know if there's anything else we can help with.
