81
Hi Nes, Currently ZerOS Remote apps cannot remember passwords. Unless you have other devices on the same network, in most cases you can get away with disabling this level of security, as someone would have to know the router’s password first, before connecting to the network. Full filter lookups are only available on the full size FLX console. FLX S only has the ability for Mood Boards by LEE Filters. What you could do to cheat, is load your show file into PhantomZerOS running as FLX, select your fixtures, choose your filter and record it as a palette. Then resave the showfile and load it into FLX S, and you’ll be able to use the palette. Edward
Hello, Yes that is correct, FLX uses an internal CR2032 3v coin cell battery for the clock. This is a quick and easy replacement, if you feel happy you can open the console up yourself. If your console is still within warranty, you may want to get this replaced under warranty by your chosen Zero 88 distributor. If you would like access instructions or would like to see if your console is still in warranty, please drop us an email to support@zero88.com, along with your console's serial number. Any queries let me know. Edward
Hello, The latest public release software is ZerOS 7.9.4. New FLX S consoles are currently being manufactured with ZerOS 7.9.4.3, which allows for hardware compatibility. ZerOS 7.9.5 will be the next software version to be released. If you would like a preview of this software, please send us an email to support@zero88.com, requesting access to the beta version. Any queries let me know. Edward
Hi Glenn, There is not a master effect rate control, however Speed Override will control the rate of your effects. Speed Override is found on the second encoder wheel by tapping Z/Shift, and can be used to slow down or speed up the running effect on the currently viewed playback. Therefore to choose which playback you wish to control, hold VIEW and tap your playback's button. You can also configure Speed Override to be controlled by a fader as well as an encoder, by holding SETUP and choosing an empty playback button. You can then select Speed Override from the options. Hope that helps, any queries let me know. Edward
Hello, FLX S consoles do not have any DMX In functionality. The option is shown inside the Fixture Schedule to aid show file compatibility with other ZerOS consoles that do have DMX In. The DMX XLR ports can be configured by tapping SETUP -> Inputs & Outputs. Hope that helps, Edward
Hello, Software updates can only be loaded in via SETUP -> Load File if you are running ZerOS 7.9 or later. As you are running ZerOS 7.8 you will have to boot into the software on a USB drive. The thread Kevin has linked to above should help you out. If you have any issues just let me know. Edward
Hi Harry, To program a submaster (which in the new software is referred to as a playback containing a single cue), create your lighting state, tap RECORD, and then tap the playback button to store to. SHIFT + FADER FUNCT will open your Faders Window to show you what they're currently doing. SHIFT + SUB will open your Playback directory. It is worth mentioning the SUB and STACK keys in the latest software both have identical functionality. Holding SETUP + tapping a playback's button will enter the playback's settings. You may find the document below useful, which goes through the software changes... http://support.zero88.com/988876801 Hope that helps, if you have any queries just let me know. Edward
Hi Harry, Great, really glad to hear it! For future software updates, it will be as simple as plugging in a USB stick with the downloaded software on, tap SETUP -> Load File, and load it in. Any queries let me know. Edward
Hi Martin, FLX will auto detect when a monitor is connected, and choose the best resolution for that monitor. You can manually force your own resolution if you wish from the list of options FLX displays in SETUP -> System Settings -> External Display. Edward
Hi Nes, To delete a playback, tap DELETE, and tap the Playback's flashing button. You will then be asked to confirm, as deleting playbacks cannot be undone. From your description, an Inhibit playback will achieve what you are after. With the inhibit playback down, your 4 channels will not function. You would therefore leave your inhibit fader at full, giving you normal full control over your 4 channels, and then if you want to dim all of them together proportionally, you can use your inhibit playback. Any queries let me know. Edward
Hi Harry, OK thanks for trying that. Each version of software is entirely independent from one another, therefore it doesn’t matter what software version you are running and which you are trying to install. If that method didn’t work, then you may want to try modifying the console’s BIOS setting. Only do this if you feel competent to do so, as incorrect BIOS modification could result in the console becoming temporarily unusable. For instructions on how to change this, see the instructions below... http://support.zero88.com/Legacy-products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/1029171021/ORB-Series-Software-Update-Issues.htm If you have any questions regarding this, please contact support@zero88.com, and one of the team will be able to guide you through. If you have any queries let me know. Edward
Hi Nes, To record an intensity master for 4 channels, push those channels to full, tap RECORD, and then tap a flashing playback button you wish to store this too. Double tap CLEAR, make sure your faders are controlling playbacks, and you’ll then be able to fade your playback up and raise the level of the recorded channels. If you hold SETUP and tap the button of the playback you just recorded, you can set the Intensity mixing to be Inhibit. This means these particular channels will no longer come on unless this playback is up- a little bit like a Grand Master just for those channels. Hope that helps and makes sense, any queries let me know. Edward
Hi George, No problem at all thanks for letting me know. Glad it is now working. Edward
Hi George, I haven't seen that before. What operating system are you running on your PC? Have you tried restarting your PC since installing PhantomZerOS? Edward
Hi George, Great thanks for that. After pressing Go and hovering over the tick boxes, if they haven't already become available you should then be able to use them Edward
Hi Harry, OK thanks for letting me know. What size USB storage device are you using? We recommend in the range of 1GB to 8GB. Have you tried a different USB storage device? If that doesn't help, try following the guide below and see if that helps you... http://support.zero88.com/Consoles/ORB-XF/998317101/Advice-when-performing-ZerOS-software-upgrades.htm Any queries just let me know. Edward
Hi George, That sounds odd. Can you confirm you are running PhantomZerOS version 7.9.4? You can find out by clicking About. It is correct that until you press Go, the tick boxes are greyed out, as Phantom ZerOS needs to know which console you are using before showing which windows are available to open. You should find when opening the software, you can choose the desk type from the drop-down, click Go, and then choose which windows you wish to Show or Hide with the tick boxes. Hope this helps, Edward
Hi Harry, Instructions on how to install ZerOS 7.9.4 onto your ORB can be found in the Release Notes, that are available to download with the console software and PhantomZerOS here... https://zero88.com/forum/files/file/17-zeros-794/ Download the USB Install Creator application onto a PC, and after unzipping/extracting run the application. Insert a USB Memory Stick into your Windows PC when prompted and follow the on screen instructions of the USB Install Creator. After a few minutes, the install creator will instruct you to remove the USB Memory Stick, which now contains the software update for the console. Remove the USB Memory Stick from your PC and insert it in one of the console's USB ports, preferably the one next to the Ethernet port. Power on the console and it will automatically boot into the software update application. It is recommended that you have a monitor, keyboard and mouse connected to perform this update. Press the [Install ZerOS] button on the monitor and the software will be installed. Once the update is complete, you can remove the USB Memory Stick and reboot the desk. At this point your desk contains the latest software. As Kevin mentions, future software updates may now be loaded into the console as simply as loading a show file. Hope that helps, any queries let me know. Edward
Hi Kevin, Apologies for my delay in replying. We agree, there are changes that need to be made, and we're planning the best way to make these changes. Currently, it is very much aimed at search, not necessarily navigating the site map. Rather than having an entirely separate "Legacy" section, how about under each Product Type, there is a specific Legacy section for that product type. Then instantly end users will understand if their product isn't listed, it must now be legacy. FLX S manuals have been added to the FLX S article... http://support.zero88.com/995795451 Hope this helps, Edward
Hi both, We've been working on some behind-the-scenes work in ZerOS, that needed to be implemented before ZerOS 7.9.5 can be released. We are certainly still planning this before the end of the year. If you are keen to preview this software as soon as possible, please email support@zero88.com, and one of the team will be able to look to add you to the beta test group if you aren't already part of this. This is very true. ZerOS 7.9.5 will not include the new fixture library to support multi-cell fixtures. We understand the need to implement this as soon as possible with so many fixtures now being multi-cell. We are therefore keen to implement this in the best way possible for ZerOS and the user. Any queries let us know. Edward
Hello, On FLX S, any of the Playbacks be customised to become a Grand Master. Doing so turns the playback's button into a Blackout button for the console. To do this, hold SETUP and tap any empty playback's button. From this menu that opens, you can choose Grand Master, and click OK. This playback's button will then be the console's Blackout button. This can then be customised to flash rather than latch if you wish. Hope that helps, any queries let me know. Edward
Hi both, This is not yet possible on FLX series consoles. You are able to plug ZerOS WINGs in to FLX consoles, which allow the console's faders to be set to one function and the wing to be set to another. Any queries let me know. Edward
USB Problem Solution/LeapFrog48 with SW 7.9.3
Edward Z88 replied to Mathias Boschen's topic in Solution & Solution XL
Hi Mathias, Please send an email to support@zero88.com requesting to be added to the beta test group. Any queries let me know. Edward -
Hi Sven, Internally, yes. We’ve had many internal beta versions that we’ve been testing. There is no release date as of yet. Edward
Hello, To delete multiple cues from a playback, tap DELETE -> Z/Shift -> type the cue number you wish to get rid of. This numpad has Thru and And buttons, which can be used to delete a range or multiple cues. Tap the Playback’s flashing button to complete the command. You can save your show file to USB, which you can then load into PhantomZerOS. PhantomZerOS can be downloaded for free from our website which will emulate FLX S. You can then edit your chase, save your show, and load it back into FLX S using USB. Hope that helps, Edward
