Uriahdemon
8
Everything posted by Uriahdemon
Brilliant Ed, works a treat thanks !!
Thanks Ed, how would I do that. I have got a separate intensity for the movers on a playback but dont quite understand how to do this for those effects that include intensity data.....?? Rgds Mac
Thanks Ed and looking forward to this fix.
Evening all, I have a number of moving head effects on playbacks and I like to set them up i.e. colour, position, effects before bringing up the intensity so I have the movers intensity on a separate fader (playback). So all the mover attributes are recorded without intensity. I am looking to achieve for example a mover scene with them going through a particular movement pattern but have them offset (so I set the 'Random offset individually') and adjust the encoder wheels as needed for speed and size. Next I would like them to flash on and off randomly so select 'Mark On' and adjust encoder wheel values. Despite recording this with intensity down it is still there and I cant use my independent intensity fader. I was wondering if anyone has any ideas on this please...?? Rgds Mac
Hi Dan, is your touchscreen still good or have you had any problems with it. I am just curious as I got one of these touchscreens after reading your post. It was good for a week but then had problems. Ed has put up a possible fix On a different post) which I have yet to try but was just wondering what your experience has been so far...?? Rgds Mac
Hi Ed, this would be a real bonus if we could print a patch list. Unless I have got something wrong (and that is quite often) using the print screen option will give you an image of black background with white text. I tried this and of course this eats black ink and the white text is pretty hard to read. Rgds Mac
Hi Ed, Thanks for the reply. There has been no changes on the setup at all apart from loading different shows over last weekend. Something I have done quite a bit on the first weeks use. As soon as I get access to my desk I will carry out the advice you provide above and get back to you. Rgds Mac
Hi, I have recently bought a Iiyama ProLite T2452MTS to use with my FLX. It worked absolutely fine for the first week or so and now I cannot get any response from it at all. I can bring up the Calibrate Screen but it is not accepting touch commands. I am using ZerOS 7.9.4. Any help much appreciated please....??
Basic Networking Guide - FLX & ZerOS Remote
Uriahdemon replied to Uriahdemon's topic in General Discussion
Hi Ed, now working a treat, thanks very much for your help. Now for me to get an unlock dongle and set up the laptop as a tracking back up. Best Rgds -
Hi Ed, I am well, hopefully the same with you. OK, I am giving this another go this evening and to start with I made a fatal (numpty) mistake. I had actually plugged the ethernet cable into the internet port in the router. I plugged it into one of the ethernet ports and I now have ZerOS Remote talking to the desk. I did not try Capture at the same time last night but have now configured it as you state above i.e. 'FLX plugged into one Ethernet port of your wireless router, and your PC plugged into another running Capture'. The trouble I have now is that the desk is not talking to Capture. I used a direct connection from the desk to my laptop previously and all worked fine but unfortunately not now. The Network Overview info is as following: DHCP - IP Address - 192.168.0.102 Capture - Transmitting on - 192.168.0.102 Remote - Listening on - 192.168.0.102 - 1 connection active IPAD address when looking at the Router wifi link info - 192.168.0.101 Capture is Enabled and 'Use DHCP Address' is enabled. On FLX - Remote is Enabled as is DHCP Hopefully the end game with this set up is to be able to: When programming use Capture for visualisation so just the FLX console into the router and router connected to laptop. When in live scenario use ZerOS Remote connected to router and laptop running Phantom OS with unlock dongle as a back up just in case. Thanks again for your help, much appreciated. Mac -
thanks anyway. -
Thanks Kevin, much appreciated. On reading this I am pretty sure I have covered off all the recommendations but I still cannot get the FLX to connect to the router. I have the FLX set up to run CAPTURE, would anything done there affect connection to the router. Also if and when I manage to set up the router would any of that set up config affect what I have in place for CAPTURE. Slightly off topic I know none the less important. PS... I have tried 3 different cables -
Hi, I am having quite a bit of trouble trying to get my iPAD running ZerOS Remote to connect to my FLX desk. That is not entirely surprising as I am not too sharp when it comes to networking setups. I was wondering if anyone has or can point in the way of some basic advice on how to do this. I have 'Remote' enabled etc but still no joy at all. I am guessing it is to do with IP addressing but not too sure where to start with it all.
Recording Cue's - Introducing unwanted On/Off effect....??
Uriahdemon replied to Uriahdemon's topic in FLX
Thanks Ed, its sorted now but dont understand what I did to rectify it. I just plodded on trying different approaches and one seemed to work when checking the next day. -
Hi all, I have just updated to V7.9.4 and this evening customising some cues and playbacks. I have an existing playback for moving heads (movements) and am trying to record a couple of other movements I am after. I am using Phantom OS with a visualiser and all looks good. Unfortunately when I record the cue to an existing playback on playing an On/Off effect has been introduced and I cant fathom out why. Does anyone have any ideas please......?? Thanks in advance for your help.
Thanks Ed, all good now !! Rgds Mac
Thanks very much Ed, I will have a look later and see if I can extract what I need. Best Mac
Hi John/Ed, Please bear with me as I probably have this wrong. I was looking to update my software to ZerOS 7.9.4. On the link above, namely - zero88.com/software/zeros I was hoping to download the console software and the Phantom OS 7.9.4 software for my PC. I do a lot of programming away from home on a PC and visualiser hence the requirement for both. I am currently operating 7.9.2 and the two .exe files used for that are Console - ZerOS 7.9.2 (USB Installer - 86MB) and PC - Phantom ZerOS 7.9.2 (PC emulator). Now for the part that is confusing me. When I go to the link both the console and Phantom software is the same link and titled ZerOS_7.9.4.zip (87.6MB). If I try to install this to the PC I get the prompt to load this on a USB device but I want to obviously load it on my 'C' drive. I would be grateful if you can please advise what I am getting wrong please chaps....?? Thanks in advance. Mac
FAT32 or NTFS for USB stick to record and transfer shows
Hi Jon, I have not gone into exactly what is not getting copied but will do this evening. Are you saying that I should ignore the prompt i.e. copying without all properties......?? -
Evening all. It seems my FLX desk will only recognise a FAT32 formatted USB stick. The problem is that my PC (Win7) gives me the bothersome problem of not copying files with all its properties if being copied to a FAT32 formatted USB stick. Has anyone else come across this problem and if so how do you get around it please....??
Offset Attribute - What is it.... what does it do please....?
Thanks Ed, I will have a play with that later. -
Colour Pallettes - Colour Logo's disappearing, not right colour........
Thanks Ed, email sent -
New Effects Pallets - To include position pallet information
Thanks Ed, recording to a playback it is then. -
I have read the manual and it mentions offset however does not explain what it does. Can anyone help please...??
Hi, I am attempting to set up a set of new pallets to include within them various effects and associated sizes and speeds etc. I have a position pallet named 'Home Effects' which brings my movers around to a starting position and I then add an effect and adjust size and speed (I will make a separate post regarding Offset). I was hoping to record this to an effects pallet however on doing that the 'Home Effects' information is discarded so the movers are not operating as required. Am I doing something wrong or is this simply not possible using pallets....??
