Uriahdemon
8
Everything posted by Uriahdemon
Hi, this is a problem I have had since upgrading to ZerOS 7.9.6. It is an intermittent problem but one that can happen just when you dont want it to (as is usually the case) It is when 'Paging Up' or Paging Down' I used to be able to do this at speed and most of the time still can but now and then there is quite a lag when changing pages. Has anyone come across this before please....?? Mac
Thanks very much Ed and yes I have your email. I will try things out this evening.
Update...... CH1 controls the mode of the fixture to the following: 0-62 Blackout 62-129 Sound Mode 130-189 Automatic Mode 190-255 DMX Mode When using 11 single channels to test CH1 outputs to 255 it outputs as it should do and the various modes are activated according to the value dialled in. When using the fixture profile - Blackout effective to 50 then sound mode is selected (as opposed to 62) Sound mode effective to 100 then automatic mode is selected (as opposed to 130) Automatic mode effective to 150 then from there no control at all. This is including trying the pattern settings. Seems CH1 has different values assigned to the 4 modes and in addition although the default value is 255 DMX control is not achieved. When using the MFF for CH1 on a single channel it works fine....?? Rgds Mac
Hi Ed, thanks and I will send the manual through immediately. Just for completeness I have attached it here also. Rgds Mac Laserworld_Manual_Club_Series_CS-1000RGB_2000RGB_MKII_web_2015.pdf
Hi, I am trying to get full control of the subject laser. I have loaded the fixture file but on bringing up the MMF which should (I think) initiate an output there is none (checked in DMX outputs in System Info). I set up 11 single channels which operate just fine and show in DMX Outputs. The fixture file seems fine i.e. CH1 at 255 which is within the DMX control mode channel values. First time operating a laser with the FLX so just wondering if I am overlooking something obvious please. I have a show on Thursday and need to get this nailed. Thanks very much in advance... !!
Thanks Ed, I will do a bit of research.......
Thanks very much Ed. The fixture profile for Resolume... is it a complicated beast and is there one available. I have had a look at ZerOS 7.9.6 fixture files but nothing there at this time....?? Also once set up is it quite a basic activity to start and stop video. We have a chap who is providing it for us.....?? Rgds Mac PS.....Notifications for replies to forum threads are not coming through to me despite me selecting it.....??
Hi, I am working towards being able to trigger video via my FLX. The current plan is to use a media server running Resolume Avenue. Any help on the configuration and execution aspects of this would be appreciated. Thanks Mac
Hi Ed, I have been plodding away and now have some sort of control although tenuous. So I have only concentrated on the tracking and Artnet output via the network node with one fixture at the end of it. My addressing is as follows as the network node manual stated Network Node IP to be set to 2.0.0.2 and the Console 2.0.0.1. Using the format you suggested I adjusted them all to the following: Network Node - 2.1.1.2 Console (Artnet Primary) - 2.1.1.1 Tracking Backup (Master) - 2.1.1.10 CITP - 2.1.1.20 Remote - 2.1.1.30 Laptop IP - 2.1.1.40 When operating the console all looks well and outputting to network node with fixture doing as it should. I take control on the laptop but the Artnet IP address chosen is 2.1.1.1 which is marked (Not available) when I change this to 2.1.1.40 I now have control of the fixture. When I take control on the FLX selecting (synchronize with Master) all works fine. I take control on the laptop again but have to change the Artnet IP address again to 2.1.1.40 as 2.1.1.1 was chosen (again) This is repeatedly the case. But on occasions when testing the changeovers the console Primary Artnet IP changes to 2.1.1.40 and I have to change that back to 2.1.1.1. So same type of problem as the laptop with both those addresses causing the confusion. When this happens the Tracking Backup window on the laptop disappears but when I change the IP on the console after a few seconds it initiates again. Any ideas please..... am I not saving and selecting the right option when taking control on either device i.e. choosing Master when it should be Backup or vice versa....?? Rgds Mac
Hi Ed, things not quite going as planned. The IP addresses on PhantomOS are continually changing (when switching desk and Laptop on/off). When I have reset them (on which ones I can i.e. Artnet on Phantom ZerOS to be on the laptops ethernet IP which I have set to 2.1.1.40 it is picking it up but showing as (not Available). I reset the desk and PhantomOS and started from scratch with your instructions but I am afraid there is something else needed/at play which is not helping this. Rgds Mac
Hi Tony, I am relatively new to the FLX but use this mainly for busking bands. Whether there is a better way of doing it I am not sure but I have set up my playbacks to give me a range of options to call upon as I need them. It is not perfect but If this is the sort of thing you are after then happy to help. Rgds Mac
Hi Ed, ArtNet IP - Primary (2.x.x.x) can I put any value in there i.e. 2.5.5.5.....??
Thanks very Ed, that is really appreciated. I will step through it all tonight. Rgds Mac
Hi Ed, I have been reading up on Artnet/Ethernet and understand the basics but what I dont understand are the data flows in relation to the config requirements on Phantom ZerOS and the FLX console. Do I set the same addresses on the console and Phantom ZerOS for all the config elements or not. Sorry I am probably not explaining this very well due to my inexperience in this area so could I please ask for your help on the following. Just for completeness my setup is a laptop running Phantom ZerOS with an unlock dongle and CAPTURE, an FLX console with two wings a Netgear 5 port switch to the Showtec Net8/5 DMX Ethernet node. The set up I would like to achieve is Tracking Backup, CAPTURE being activated by both the Phantom ZerOS and FLX console when either is Master and ZerOS Remote Monitor. If I scrubbed everything back to start what IP addresses would you recommend I set up on all the devices to achieve that please. Again, apologies for being a pain. Rgds Mac
Hi Ed, thanks for pointing this out. The Master is indeed 192.168.1.100. I will re-jig things tonight and see where we go.
Sorry to add on this I have just noticed that the Tracking Backup window that appears when the FLX has control states 192.168.1.100 as Master and 192.168.1.10 as Backup... pic attached....??
Hi Ed, just a little more on this. My apologies its not the 'Tracking Backup' setting it is the 'Artnet4' setting. When I have PhantomZerOS open and the correct Artnet4 IP selected i.e. 192.168.1.10 then all works fine. If I take control on the FLX and then back to the laptop (so still running Phantom ZerOS) the IP address changes and I have to go into it and select 192.168.1.10 again for it to work. In Artnet4 there are 4 IP addresses listed these are 192.168.1.10 (the one I set up and works)/127.0.0.1 (as you mention)/192.168.1.155 and 192.168.1.100 which is marked (Not Available) I set this one up a couple of days ago when I was getting this set up but have everything on 192.168.1.10 now. Any ideas please....?? Rgds Mac
Hi Ed, Jon, Just about there but only one snag remaining. When I open up Phantom ZerOS Tracking Backup always defaults to an old (now unavailable) IP address. Is there any way I can remove those old addresses or ensure the one I need is picked up automatically please...?? Rgds Mac
Excellent, thanks Ed. I will get onto this tonight.
Thanks Ed, much appreciated.
Hi Jon, thanks for the info. I have not got access to the kit until tonight but I will give this a try. I have this laptop set up originally to run Capture. Can I set the same IP address for that within Phantom ZerOS please...... or should I use something different.....??
Hi Ed, so reasonably successful but not entirely. The dongle is recognised by the laptop given the instructions you provided above. When I am using the FLX in control mode all is good and I am successfully getting fixtures to do as they should. Also on the Ethernet Node the Activity lamp indicates signal being received so all good on that front. When I take control on the laptop the Ethernet Node Activity lamp goes from constant to intermittent flashes and I cannot control any fixtures. Cabling has been set up as per the networking guide and I have set the subnet mask on the Ethernet Node to 255.255.255.0 and the IP address 192.168.1.206. Are there any settings required on the actual laptop required for it to output please...?? Rgds Mac
Thanks Ed, I will be having a play this week to set everything up with the FLX for a tracking back up. Fingers crossed . !!
Hi Ed, I have just received the dongle today. Unfortunately there were no instructions with it and I cant find any on the site. Basically I was wanting to know: What needs to be done to unlock Phantom OS is it just a case of plugging the dongle into the laptop running it and it will be picked up Is the use of it restricted to one device only or can I operate it on any number of devices Can I copy the contents just in case I lose the dongle and will it work if copied onto another USB stick Thanks in advance for your help
