Uriahdemon
Everything posted by Uriahdemon
  1. Thanks Ed, I will have a play with that.
  2. Hi, When setting up the movers in fly in/out (pre-recording) they work just fine i.e. the vertical movement timing and intensity on/off points are just right. On recording these to a playback the timings are different i.e. intensity comes on/goes off midway through the movement. I have had this problem previously but never posted. This is probably a lack of knowledge on my part but just wondering if anyone has come across this before please.
  3. Thanks Ed
  4. Hi folks, I had a bit of a glitch tonight when programming. I was programming movers and using effects (lightning in this particular case). I got a windows prompt telling me Zero88 had stopped working and will be shut down. I did that and re-started .... all seems to be OK. File attached. debug_10-9-2020_16-59-50.zdb
  5. Thanks Ed, I have been playing with palettes for some time now and not come across this issue. I have set them up separately but they are not being able to be selected independently from the palette. Baffling me......?? From the point of just adding the new fixtures they appeared in the original palettes when selected.
  6. Hi, I wondered if I can get some help please as I am obviously doing something wrong. I had a number of position palettes set up for my original 6 movers. I am now setting up an additional 4 and regardless of just recording them onto a separate position palette the originals are also moving. The movers (original and new) are the same type with the same fixture profile.
  7. I have 6 movers programmed on my FLX but looking to get 4 more. I have all the fixture profile attributes added to cue lists so full control of every aspect of them. Is there a quick way to add identical fixtures. I understand I will have to adjust the positioning palettes but was hoping there is a quick way to get them to respond to the programming already set up.....??
  8. Thanks for this. On the main issue for me i.e. the lag when selecting various playback pages. All seems good although I have only used PhantomZerOS at this stage. On the fixtures turning red i.e. legacy. What would be the drawbacks of just sticking with the fixture files I have currently please....??
  9. Excellent, thats the one. Thanks very much Kay !!!!!
  10. Hi, I was wondering if there is a way of doing the following on a cue stack. I have a number of cues on a stack for the control of moving heads and as I flick through I just raise the intensity when I like. I was wondering if there is a way of reducing the fader intensity to 0 without the cue re-setting i.e. it stays active and all mover attributes remain the same....?? Thanks in advance as always.
  11. Thanks Ed I will give it a go tomorrow.
  12. Thanks both, much appreciated. So as I read it the desk I have is capable of outputting 4 universes to physical output 1 or 2. The thing is how do I actually do that. I went into setup>universes and tried what I thought was a logical change but it stayed as was.....??
  13. Hi, on reading the manual it states 'each of the outputs can be mapped to any of the DMX universes'. Has anyone done this and how did you do it. Also am I correct to assume you need to get the Universe Upgrade applied before being able to do so. Thanks in advance.
  14. Hi David, how did you get on.... has 7.9.7 resolved the issue for you...??
  15. Hi Ed, I will give 7.9.7 a go. on the release notes ZOS-9615 refers to rigsync speed of discovery and not page selection lag....? Rgds Mac
  16. Hi Ed, just updated the desk to Beta version and programming over the next couple of weeks. I will let you know how things go. PS.... I am assuming V7.9.7 does not include all the current Beta fixes/updates. Not mentioned on the release notes anyway. Rgds Mac
  17. Thanks very much Ed
  18. Hi Ed, thanks for the reply and apologies for the delay. Yes I would be happy to try out the beta version to see if it makes any difference. It seems I do not have permission to see the link so I will send you an email for the access as requested. Rgds Mac
  19. Hi, I need to use a number of 'Solo' effects on my current show run. Is there any way of introducing the 'Solo' function on a cue in a stack please....??
  20. Hi Ed, I have just done a show run and this problem came up on numerous occasions. Unfortunately it spoiled a couple of moments. Are there any thoughts on why this may be and any fixes ahead please. For info it is happening on my PC too....???
  21. Hi Ed, it mainly seems to be on the Playbacks. Mac
  22. Hi, this is a problem I have had since upgrading to ZerOS 7.9.6. It is an intermittent problem but one that can happen just when you dont want it to (as is usually the case) It is when 'Paging Up' or Paging Down' I used to be able to do this at speed and most of the time still can but now and then there is quite a lag when changing pages. Has anyone come across this before please....?? Mac
  23. Thanks very much Ed and yes I have your email. I will try things out this evening.
  24. Update...... CH1 controls the mode of the fixture to the following: 0-62 Blackout 62-129 Sound Mode 130-189 Automatic Mode 190-255 DMX Mode When using 11 single channels to test CH1 outputs to 255 it outputs as it should do and the various modes are activated according to the value dialled in. When using the fixture profile - Blackout effective to 50 then sound mode is selected (as opposed to 62) Sound mode effective to 100 then automatic mode is selected (as opposed to 130) Automatic mode effective to 150 then from there no control at all. This is including trying the pattern settings. Seems CH1 has different values assigned to the 4 modes and in addition although the default value is 255 DMX control is not achieved. When using the MFF for CH1 on a single channel it works fine....?? Rgds Mac
  25. Hi Ed, thanks and I will send the manual through immediately. Just for completeness I have attached it here also. Rgds Mac Laserworld_Manual_Club_Series_CS-1000RGB_2000RGB_MKII_web_2015.pdf
