Uriahdemon
8
Everything posted by Uriahdemon
Evening all, I was wondering if anyone can please let me know if show files built on the FLX are compatible with the S24/48.
So got a hold of some Servisol Super 10 and it seems to have resolved the problems and fingers crossed. The faders do seem a bit sticky but hopefully that will resolve itself. I also took the time to remove the rear of the desk and change the internal battery, again fingers crossed and all good. Thanks very much for the help from everyone, really very much appreciated indeed !!
Thanks very much Ed, I will take your advice and see what happens. Where are the service centres please....?? Rgds Mac
Possible hardware issue, Fader 5 affecting fader 19
Uriahdemon replied to keredyelesob's topic in FLX
Hi, I have a similar issue and am wondering how this played out….. were you able to resolve the issue please ? -
Hi Davidmk, thanks for the info. I had the case open a few years back to replace the battery. Since you had the same symptoms I will give it another look. I will hang on and see what Ed advises. Thanks again.
Hi Ed, I hope this finds you extremely well. As usual I am contacting you again out of the blue only because I continue to have a problem with the desk….. my apologies. The desk has not had much use at all and after using some compressed air and fingers crossed it seemed to clear for a while. However the problem has recurred again and it affected fandom faders i.e. I could be adjusting no fader however other random faders will increase in intensity from Zero. I had a colleague borrow the desk last week and he seen the same thing. He also mentioned he had the same problem with an Orb. Can I please have some advice on how to get this problem finally resolved. I need it sorted pretty soon as there is some work on the horizon. Thanks in advance for your help !!!
Thanks Ed and email inbound.
Hi Ed, quite a bit of time has passed since I looked at this given the urgency being removed for obvious reasons. I am now starting to have a look at this seriously again and sussing things out as best I can before committing to licenses. I have had a look on the Resolume website and indeed you are right. Arena will be the software version I need for this. Regarding the Resolume fixture file. I cannot see anything that relates to a channel map that you mentioned to build the fixture file. It is probably due to my low level of knowledge right now so will continue to look for this. Am I right in saying that effectively when I have a cue stack set up on the FLX I can basically select Resolume as a fixture and depending on how I have Resolume configured when I execute a cue it will execute the video also. So two pars on plus video on and same two pars off and video off triggered from the cue....??
I have got to say I love the PhantomOS interface. Much easier to work on. Thanks folks !!.
Morning all. Looking to use another external monitor (perhaps using a laptop) with my desk (FLX). Unfortunately the link is now dead...... Is anyone aware of a new/updated one please.....??
USB Stick for back ups - Any particular specs.....??
Uriahdemon replied to Uriahdemon's topic in FLX
Hi Ed, I reformatted the stick and it is now currently working fine. A bit weird as I always have to USB drives both mirroring each other (just in case). I have used this loads of times in the past. Hey ho.... at least it works now. Thanks for your help. -
Thanks Ed, I have formatted the stick but will try again. I will also have a look at the system info you mention this evening and get back to you. -
Morning folks. I was doing a bit of setting up last night and took a couple of USB sticks with me to load on the desk. One worked i.e. the desk seen the contents, the other did not work i.e. no contents at all seen. They are both Sandisks one 8GB the other 4GB and both formatted to FAT32. The one that did work (which I have had no issue with since first use) was the 8GB stick. Does anyone have any idea why the 4GB stick would not work. It is basically a back up for the other and contained a full copy of the 8GB stick........???
S48 - Position Effects - Speed, Size and Offset
Uriahdemon replied to Uriahdemon's topic in FLX S24 & FLX S48
Indeed and thanks John. I am that used to the FLX and using a mouse with PhantomOS. It never crossed my mind. Keith was also very kind to respond to a support email I submitted. All good now !! -
It seems to be my LCD Display on S48 Phantom. The tabs I can see only go up to mid way through the Pan/Tilt Grid. I have tried resizing the LCD window and also Win10 Display Settings but nothing helping me get the full picture including the 'Effects' tab.......?? I have provided a link to a screenshot which will explain it better. https://www.dropbox.com/s/dvovscojiox8p77/S48 Phantom LCD Screen Shot.jpg?dl=0 -
Hi Dimitri, I have an issue you may be able to help me with please. I posted on it yesterday but some of your post here helps. I see in one of your images that the top of the S48 window you have an effects tab which brings in speed, size, offset and rotation encoder parameters. I am using S48 Phantom and my tabs only show over to Pan/Tilt Grid i.e. no Effects tab. Can you help on how to get this to show please....??
Or indeed is there the capability to do this on the S48...?? -
Hi, Can anyone please let me know how you can get to the effects, speed, size and offset parameters on the S48....?? Unfortunately I cant seem to get them up on the encoders at all. TIA
Thanks KGallen
How is this done please Ed. I can connect up my IPAD to the desk via wifi and use ZerOS remote to trigger playbacks. I am not sure how to do this....?? What is the difference between a palette and an auto palette....??
Thanks Ed, thats the stuff I need and seems I have plenty of homework now. No doubt there will be more questions once I have had a read and a play. I look forward to the training session.
Thanks for the info Ed and I have just registered for the training. What is the workflow you use to program i.e. pallets and groups what and when etc....?
Thanks KGallen, yes I dont know as yet but interested in trying it out. I have a visualiser so will have a try with that first to see how it maps across. I really dont know what movers I will come across when this is up and running so need to find some way to changeover quickly and efficiently.
Hi,I have a Zero88 FLX control desk with two wings.I have been using it for a few years now with my own rig. In preparation for some potential work next year I need to set it up for maximum flexibility and capability. There is a chance the venues will be bigger and I will be using a small ground package and hooking into the house rig. I have done this in smaller venues and coped by getting fixture specs , positioning and DMX addressing info. Some venues were really good with a tech spec some not.So the info I need some help on would be to help in a situation when you get to a venue with no tech spec info at all. How do you set your desk up, what are the work flows used for fixture selection groups, positioning etc.
Hi Ed, I tried your suggestion and the 'Test' Mode showed no issue with the faders. I did visit Mr Screwfix yesterday for the can of air duster and applied that afterwards also Fingers crossed it has not occurred again. I really dont know what this was.... very weird but hopefully that is it now. Thanks very much again for your help (especially at the weekend) hugely appreciated. Rgds Mac
