![](https://www.zero88.com/forum/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
Uriahdemon
8
Everything posted by Uriahdemon
Hi, I sought help with this issue a few months back and just had another festival last weekend and the same thing is occurring. Ed very kindly had a look through the show file and did not see any issues. It also works just fine on Capture. I had this working without any issue for years on many cues but for some reason there is an issue now. The only thing that has changed since using it successfully on my whole live rig is I am now controlling it via Artnet as opposed to the two DMX desk outputs. I checked this via the DMX outputs before the last event and everything was fine. The exact result is the fixtures I trigger do what I have asked but the remainder do not black out. Any help most welcome please....??
Thanks Kevin, worked a treat and will have a read up on the links a little later. Much appreciated !!
Afternoon all. I have a bunch of movers and have recorded all the attributes (posn, colour, effects etc) on a number of cue stacks. What I would like to do is add and remove some fixtures (movers) so I have groups of them independent of others but can still use the attributes I have recorded on the cue stacks. I have tried updating a single cue by getting it to output selecting the group of fixtures I want to for this example remove, hit remove on the update options but no joy unfortunately. I also cannot fine anywhere to find and read about the 'Update Options' to fully understand what I can and cannot do with them. Thanks again in advance.
Thanks David, every day is a learning day.
Thanks Kevin, much appreciated
Thanks Kgallen, you are absolutely right. I also have been using groups and position palettes for quite some time and never noticed the points you bring up. I just cracked on and used them. Only this time I seem to have got myself into a real tizzy. Thanks for your and Davidmk's help in clearing the fog. I will now go away and lie down in a dark room with a cold cloth. My apologies !
Yes those are the ones although I deleted a whole more to get this fixed first. The problem seems to happen with any spec mover though. I will have a look at the Capture file although it is not really needed for this. When even selecting one single Hybrid all position palettes highlight....??
OK, and thanks...... UnReal Festival 2023 v0-1.c2p UnReal Festival 2023 - V0-3 - MOVERS GROUP ISSUES.zos
Thanks KGallen, I have deleted the groups and palettes and built them again using and not using SmartTag. Same issue I am afraid. It is probably some finger trouble on my behalf (hopefully) and not a bug as I have some programming to do for next weekend. Keith is getting Ed to have a look at this when he comes back from holiday.
Thanks Davidmk, sent you over a message with a Dropbox link to the files.
Davidmk, could I ask a favour please. Can you confirm if the issue I have does not occur with you, or anyone else who reads this. I will then be able to suss out if the issue is down to my finger trouble....??
Morning, I trigger cues via Midi but I am pretty sure you cannot triggers numerous cues in a stack. I will await some more knowledgeable folks to tell me if I am wrong. Here is a link to where this was discussed...... https://www.zero88.com/forum/topic/9029-flx-control-via-midi/
I certainly will
Thanks matey, I knew what you meant. Hopefully Keith will show me the error of my ways pretty soon therefore wont need workarounds 😉
Thanks Keith and sent over.
Hi Davidmk, I have given that a go and I am afraid I still have the same issue. I did as you said and was using Multiple selection in Groups so change to Single. Also when recording both groups and position palettes deselected Snapshot and Smart Tag. I am using Capture as a visualiser. When I select each groups it is clear only what I selected is correct as displayed. Unfortunately when doing entirely different position palettes for them both are illuminated if I use any of the two groups. I have cleared everything out of my movers groups and position palettes until this is resolved. These movers are all the same spec and I have a different make/spec set up in groups and positions with no issues.
Thanks very much Davidmk, I will give it a go this aft
Afternoon all, I wondered if anyone can help e with this please. I have set up two clearly distinct groups for my movers. One on a rear truss set the other on a front truss set. I am setting up position palettes for both separately. Unfortunately if I select a group and a position I have set previously including the fixtures in that group, it also affects the movers in the other group i.e. they move to this position also. Another thing I note when experimenting is that despite saving two groups of movers if I select either when going to the positions palettes both are highlighted. I have no idea why I have hit this issue but any help would be much appreciated. PS..... forgot to add I am using Phantom. Not tried the desk as yet.
Good morning all. I was wondering if there is any way of getting a comprehensive picture of the DMX addressing and associated channels used across all universes. I am aware of the DMX Outputs picture on 'Z' however that does not give me the info I need. Ideally the kind of info you get when adding fixtures i.e. the 512 channels picture colour coded to used and free channels. Thanks in advance.
Evening all, I was wondering if anyone can please let me know if show files built on the FLX are compatible with the S24/48.
So got a hold of some Servisol Super 10 and it seems to have resolved the problems and fingers crossed. The faders do seem a bit sticky but hopefully that will resolve itself. I also took the time to remove the rear of the desk and change the internal battery, again fingers crossed and all good. Thanks very much for the help from everyone, really very much appreciated indeed !!
Thanks very much Ed, I will take your advice and see what happens. Where are the service centres please....?? Rgds Mac
Possible hardware issue, Fader 5 affecting fader 19
Uriahdemon replied to keredyelesob's topic in FLX
Hi, I have a similar issue and am wondering how this played out….. were you able to resolve the issue please ? -
Hi Davidmk, thanks for the info. I had the case open a few years back to replace the battery. Since you had the same symptoms I will give it another look. I will hang on and see what Ed advises. Thanks again.
Hi Ed, I hope this finds you extremely well. As usual I am contacting you again out of the blue only because I continue to have a problem with the desk….. my apologies. The desk has not had much use at all and after using some compressed air and fingers crossed it seemed to clear for a while. However the problem has recurred again and it affected fandom faders i.e. I could be adjusting no fader however other random faders will increase in intensity from Zero. I had a colleague borrow the desk last week and he seen the same thing. He also mentioned he had the same problem with an Orb. Can I please have some advice on how to get this problem finally resolved. I need it sorted pretty soon as there is some work on the horizon. Thanks in advance for your help !!!
