Uriahdemon
8
Everything posted by Uriahdemon
Still for sale.......??
LoL.... not an issue. It may attract some keen buyer !!
Hi Kev, very kind of you and thanks. It certainly was not the Zero88 kit for sure. I think the FLX and ancillary software apps were great pieces of kit. Time moves on and this was never the day job. I had hoped to move into more tranquil LX roles to go alongside retirement but that alas has not come to fruition. I also need to be doing more fishing so something had to go. I will miss the programming, show execution and the challenge. I wont miss the rig & de-rig before and after the candy. Not off as yet but will be less regular so to say.
Good afternoon everyone. I tried to find a more appropriate forum for this but no joy. I have an FLX desk with a wings fo sale. They are in a custom made flight case for tour work which is fitted out for an FLX and plus touchscreen and peripherals. Lastly I have a USB Unlock Dongle for PhantomOS. Any genuine interest then please email me at rtmckie@sky.com Rgds Mac
Apologies on picking up on this so late. Ed was such a great tutor and producer of fantastic reference material I hardly visit the forum now. None the less I would also like to say a huge and genuine thanks to Ed. He even put time aside in the evenings for Skype calls to help me understand and run ZEROs. Good luck Ed in your chosen new direction and thanks again. It was folks like you who fuelled my loyal support for and in Zero 88. All the Best.... Mac
Solution XL - General Views & Lifetime Expectancy
Uriahdemon replied to Uriahdemon's topic in Solution & Solution XL
Thanks Ed, very helpful !! -
Good morning all. I have been using the FLX for quite some time and intend to carry on doing that. I may have an opportunity to introduce a Solution XL into a venue and wondered what I can expect. Are the workflows for the Solution XL the same as those for the FLX given they are using the same software. Any good/bad points and given the desk is now a legacy product what is the lifetime expectancy for ongoing support on it please. TIA
Unable to Get Solo Attribute Working - I did previously
Uriahdemon replied to Uriahdemon's topic in FLX
Just to clear this up. I was trying to trigger the SOLO cues via MiDi which did not work. All other cues on the MiDi work fine but just not SOLO. They trigger fine when using the desk. Thanks Ed for your time and effort on this -
Changing Effects Attributes and recording to Palettes
Thanks Ed. I will read through this and have a play, much appreciated. Good luck with the production you are working on. Sounds pretty complex !! -
PS.... just tried the Chase 1/2 effect and adjusted the size and achieved 100%. Unfortunately on recording it is showing 50% in yellow in the Output Window. -
Thanks for the help Kgallen, much appreciated. I will have a play with the size on the Chase effects and see if I can get the intensity as needed. I have had a look through the effects attributes and cannot see anything right away that allows me to adjust the effect intensity. Thanks again !! -
Good morning all. I am trying to use 'Effects' i.e. Chases, Ballyhoo etc i.e. featuring intensity effects. I would like to then record them at various selected speeds to palettes. The problems I am having are: A. The intensity defaults to 50 as opposed to the desired 100 B. Selection of the palette results in the effect immediately being applied as opposed to me wishing to do it via an intensity MFF i.e. gradual introduction as opposed to immediate. As usual really grateful for any help please....??
Updating Groups & All associated playbacks/cues using the group
Hi Ed, thanks for the reply. They are replacement fixtures for some of mine that are nearing the end. Unfortunately the fixture file for them is different as they jigged the DMX channels around quite a bit. I was just looking at the quickest way to replace them with the minimum of re-programming. -
Afternoon all, I have a number of cue stacks built using groups. I would like to add some additional fixtures to the cues and thought if I just update the group that would then work. Unfortunately it did not. I was wondering if this is possible or not and how to go about it please if it is.....??
Recording Intensity on MFF without any attributes for movers
Good morning Ed, I had a play last night and it does what it says on the tin. Thanks very much again for the help !!! -
Good evening Ed, what are you doing working at this time on a Saturday night my friend. I was really surprised to get a reply. I will have a look at your guidance in the morning and thanks very much !! -
Evening all. My programming and show execution approach for movers until now has been to record cue stacks of attributes, select each cue and then increase intensity. I am looking to be able to now select those attributes from palettes then increase intensity as needed. Unfortunately the intensity playback cancels all the other attributes (well the way I have it configured) and I have to set them all again once raised. Can anyone please suggest anyway of recording an intensity MFF which is entirely neutral and allow the attributes selected from palettes to remain...??
Hi iank99, do these desks work as efficiently as the FLX with the latest ZerOS software please. I am assuming the down side may be the outputs i.e. numbers of universes they are capable of controlling. Would you recommend any of them above the others to home in on please. As a back up and spare I would make do with 2U output....???
And far more eloquently put as opposed to my drivel 😁
Thanks Ed, I guessed this would be a bit of a headscratcher as you say. I certainly will pursue the fault finding as you suggest with a video. I did power cycle but made no difference unfortunately. -
Thanks Ed, very reassuring and I will persevere with getting one.
Thanks Kgallen, much appreciated. I will pursue the link but there does seem to be a lack of options to buy them unfortunately. Zero88 do not indeed have any other product in that class and I am wondering if the various company changes over recent times have influenced the availability.
