swordfish
swordfish's Achievements
Newbie
Newbie (1/14)
  1. I've got a suggestion for a new softwareversion. Is it possible, that you integread a function in the run mode so that you can change the output level of each channel also when the memorys are active. Maybe be pressing shift and the fader of the channel you want, so that you can grab the output of the channel which is programmed in the memory and fade it down. At the moment it's only possible, because of HTP, to rise the outputlevel higher than it's programmed in the memory. If you change the memory, everything should be putted out how it is programmed in the memory. Sorry for this bad english, I hope you understand it. Greetings Heiko Bruggner
