Mr Ed
2,237 profile views
Mr Ed's Achievements
  1. Hi there, we have a problem with the default attributes of our LED Fixtures. Till version 7.___ it was without problems possible to record the defaults atttributes for each fixture with "record" "home" "defaults". Now with version 8 thsi works as well but it happens the following: after each restart even if the values of all attributes are recorded correctly and double checked before switching of the concole, the default attributes are erased and it happens there are random attributes recorded e.g. white 82, red 0, green 18 and blue 2. Can anybody help? One more thought: Perhaps it's only coincidence and has nothing to do with the new version of the ZeroOS and the internal memory of our Console is damaged!? Best, Bernhard
  2. Okay, this becomes clear for me. Thanks. But how can I patch the fixtures which are connected to the radio?
  3. True! Sorry. We connected the Aurora with the FLX via DMX. The Aurora is receiving the DMX signal but I cannot find the Aurora in the settings in the FLX. Do I have to add it as a new fixture or do something else? We have some Apurture Mc pro running. They are connected to the Aurora but how can I patch them in the FLX?
  4. Hi there, I'm trying to connect a Lumenradio Aurora to our FLX, but I can't suceed. Does anybody has a solution for me? Best Tim
  5. Mr Ed
    Touch Screen
    Hi there, we have tried to use the same Asus touch monitor with the FLX but it didn't work either. The box stayed blue. Is there any possibility to fix this? Do you have a list with compatible monitors?
  6. Hi there, we have a new Zero88 FLX Console running here for a few days and will still get this 3 problems not solved: 1. We added the Selecon PL1 and the selecon PLCYC1 with the Patch wizard, both with 8-Bit mode, thats no problem at all, they are running. Now the problem: with the colour picker or the Filter-choice the colours aren`t not all similiar as when we make the same colour choices e.g. with the ETC Colour Source Par. When we use the RGB-Faders we get no primary colours, just pastell colours. E.G. when we try to get Primary red, it looks like scarlet, there is way to much white in all the colours. How can we fix this? 2. Is there any possibility to lock the playbacks? Usually we work with the submasters to run the shows, but sometimes we would like to try out for example how it would look like to vary the brightness of a certain channel during rehearsals or a performance. E.G. we have programmed a playback with channel 2-8 @ 40 %, now we like to look if Channel 4 will look better at 60 %. We switch to Channel Mode, raise it at 60 %, but we don`t like it, so we get the Channel Fader down to 0 %. Now the mistake: the playback has changed its programming, and Channel 4 is now at 0 % but we would like it to stay on 40 %. Is there any possibiliy to get this better working? 3. Is it possible to make a Crossfade from e.g. Playback 1/24 to 2/1? When we switch to Bank 2 to release Playback 25 it doesn’t seam to be possible to make a parallel fadout of Playback 24, isn’t it? And how can I see which Playbacks are active? I have read that the active ones are green shimmed thats nice but there is a problem. For example: I have playback 10 on Page 1 at 100 %, now I turn to Page 2 and do additionally Playback 5 on Page 2 at 100 %. Now in the Playback window, there are two green shimmed playbacks, but: shimmed are Playback 29 and Playback 34. Why? When I want to use simultaneously playbacks from different Pages I will loose the survey. Or is there a possibiliy to view it properly which playback from each page is active? Thanks in advance for your kind help. Best regards, Bernhard
