Lampie Leight
About Lampie Leight
  • Birthday 03/26/1968
Lampie Leight's Achievements
Apprentice
Apprentice (3/14)
  1. Hi Jon, No worries. I know you've been away. Yes MFK's sorry Jon. I'll take a copy tonight. Where shall I send it? L8
  2. One thing I have noticed is that the touch screen doesn't have the same issue. It's just the MFF??? I wonder if the touch screen being plugged in is causing it?
  3. I've also found that it always looks to write onto another programmed MFF and not a blank MFF???
  4. Also just found the same type issues in saving Colour Pallets!!! This is now restricting my use of the desk and need some urgent assistance is needed please! Thanks Leighton
  5. Upgrading to 7.9.2 has now solved this issue. Thank you.
  6. Good afternoon guys, I have upgraded to ZerOS 7.9.2 a week ago so I've not had much time to get used to it but I have found an issue. I wanted to create a new set of Groups on Group Page 1 because I have Desktop 2 on our touch-screen set where it is split into 4 windows. Top left window Groups, Top right window Positions, Bottom left window Beamshapes and Bottom right window Effects. When I moved off Desktop 2 to another Desktop and then moved back to Desktop 2, if you had left the desktop with each of the windows where they had been scrolled down to say page 6 or page 10 for example, when you return the windows will have reset to page 1 again and this is very frustration (is there a way to stop this from happening?). Therefore I wanted to create all my most needed Groups to show on page 1 to help with this reset issue. The main issue is that when you create your Group and attempt to save it to MFF 1 for instance, you get the warning message Group 11 is already programmed. What do you want to do? If you save it saves it to MFF 11? and it happens exactly the same in reverse (if you save to Group 11 it gives you the warning for saving to Group 1)??? So far this has only happens on Groups Page 1 and 2. Leighton
  7. Thank you Edward for all your help. All fixtures up and running. The desk upgrade is next this week so you may get pestered again Thanks again Leighton
  8. Thank you kind Sir. I'll give it a go and report back.
  9. Yes that's correct. I shall try that next time I'm down there. Thanks once again Edward. I have noticed though that I need to add the generic RGB+D or I can't dim the fixture unless I mix the colours to to lower levels which is an issue if I want to fade all fixtures at the same time. If I add 18 x RGB+D that makes 72 channels and not 54? Will that cause me an issue?
  10. Hi Edward, I tried the instructions above last night but with no joy. I get as far as "Select the start address you chose for the fixture, and on the next patch page add the quantity which in this case will be 18" but I don't get asked for a quantity. It just assigns it as a 3 channel fixture I wonder if it's something to do with my desk configuration?
  11. Hi Jon, Should ZerOS 7.9.2 now make my Iiyama Prolite T1531SR usable? Regards Leighton
  12. Hi Edward, Just a quick update. I now have both types of fixtures colour now being controlled via the encoder wheels. I have had to use 4 channel generic to be able to dim but all working fine. Thank you so much for your help. Next week I'll try the individual LED install on the Show Bars and let you know but for now I can use all my fixtures. Thank you
  13. Brilliant! Thanks Edward. I can't wait to try this. I'll let you know how I get on
  14. We have a Solution desk Edward. This information will be a massive help. Thank you Last question. When I start assigning the separate generic fixtures to the individual LEDs in each of the four Show Bars, how do I choose the LED when installing the fixture?
  15. So how do I select the individual LED's? I have four of these so does that mean I need to add 72 fixtures?
