luke1307
Everything posted by luke1307
Hi Jon, Just wondering if there is going to be an option to pixel map on the FLX with sunstrips and LED panels and if so when the option will be released
Hey, Thanks for this, but I have done that, but the other fixtures stay on. Even with the Udks set at latch and not flash. Have also tried changing the htp and ltp setting Oh sorry I read that wrong, I don't have a solo option on mine, and I can't update the desk as the update been taken down
Thank you Jon, much appreciated, what sort of time suits you?
Hi Jon, Sorry to be a pain but could I ring you please about this, as I don't have my desk at the moment and won't be getting it back till Thursday which is when I next need the move on dark, can I ring you today at some time please?
Hi Jon, Sorry I've figured out what it was, it doesn't like the fact that I've copied a cue, is there a way I can copy a cue and it will just fade the movers out?
Hi Jon, Sorry to bother you again, I'm having trouble with the move on dark still, I tried it a couple weeks ago with how you said and it worked fine, now I'm trying to programme for a show and for some reason when I hit the go button my movers are going through all the different gobo wheels till it's a plain spot as it's fading out and not fading straight away, any ideas?
Ok thanks Jon, I will try that in a few days when I get fixtures back, basically the movers are only being used for extra effect on a few songs so won't be used much but like i said before some need to fade straight up already in position and colour and other times they just be moving around. If I still get stuck can I come back to you,
Hi there guys, I'm still learning the FLX and wanting a fixture to move on dark but only on certain cues, some cues we need it to show the beams moving but one or two we need it to move in dark and just appear what's the best way to do this? Any help would be appricated Thanks
That's the ones thank you
Hi Jon, Thats brilliant thank you so much, When you do the fixture update can you please check the qtx smart par 6 channel fixture its the rgbw version. Thank you Luke
Hi Jon, Please see attached showfile as ask for, I have been through all the settings and cant seem to sort them, i have changed the default values on the edit fixture which either makes the led stay on once cleared or removes it from the channel faders Please may you call me and talk through this. 07874001732 Thanks Luke new update showfile.isf
Hi Jon, I have just updated to the new software and I'm having a few issues, I have a qtx smart par patch in, firstly the grand master and blackout button has no effect, if I go over to the channels I slide up and down channel 1 the fader has no effect, I've set the intensity to be on the first wheel in the window but it won't appear, and the normal 1 @@ does not work, only way off get led lit is pressing home
I was using my FLX last night for a couple fixture control, the customer came up to me during the event and asked for me to change something, so I went back into the channels not playback option and the console crashed and came up with a error message so I restarted the console it had a 5 mins with the saved playbacks then started working ok, I didn't get chance to save the crash report as was trying to get lights back on, I also had trouble with my chase creating, even tho they were set to cross fade the colour changes they were snapping. Any ideas
Hi Jon, I have re-loaded the profile, and been through the pallets, picker, faders and even effects and can not get the UV to come on, there doesn't even seem to be a pallet or fader for UV. Any ideas?
Ok thanks, il try re adding the profile and try again
Hi Jon Sorry if this post twice, my internet crashed as I was uploading comment so unsure if it uploaded. Thanks for making the visage VIS0484.1 fixture however you can not turn the UV setting on via the console which should be channel 10, please may you update this
Hi Jon, Thanks for creating the visage VIS0484.1 fixture profile, however you can not turn the UV function on through the FLX console, can you please edit this, thank
Hi All, Does anyone know the best place to get a waterproof dust cover for the FLX? Thanks
