Kirkup_xp
Zero 88 Alumni-
Hi Irisse, Unfortunately it's not possible to copy a state from one show file to another. The best I can suggest is copying the values to paper, and then re-setting those values. Sorry about that. Peter
Hi Piero We've now resolved this issue. It turned out to be a small bug in the Compulite tool - they don't add a carriage return after the end of the ENDDATA in the ASCII file, which the file format requires. We've fixed these files for you, so you should be able to load them into ZerOS. In the next version of ZerOS, we will be tollerant of this requirement for the carriage return, so you won't see this problem. You should be aware that in the show files, the Compulite tool has added a 4 second delay time to almost every fade up time on the show file - this might have been in the original file, but it seems unlikely. You can see this in the text file: CUE 4.2 UP 4.0 , 4.0 DOWN 0.0 , 0.0 You may want to perform a find and replace on this file, to remove these delay times - you can do this in Notepad or any other text editor. FIND UP 4.0 , 4.0 REPLACE WITH UP 4.0 , 0.0 Hope this helps, Peter Compulite Files Converted.zip
Submasters not remembering Position Palettes
Kirkup_xp replied to CBMatt's topic in Leap Frog 48 & 96
Hi Matt Can you send me a show file with your patch and some submasters that aren't updating correctly? This mechanism should be working fine. Also, how are you updating the palettes? Do you re-record and merge, or use the Update function? Thanks, Peter -
Hi archie, Unfortunately, there's no easy way to do this. What you could do is program a sub which overrides the values HTP (so pull all the values to full), but of course that's going to be quite bright compared to the normal chase. Hope this helps,
Hi archie Unfortunately, the chase speed is fixed on the Jesters to work just on the range of the modifier... there's no hidden faster range. On our ZerOS consoles, you can go upto 600 beats per minute. Sorry about that, Peter
Hi Piero There's a utility on the Compulite website to convert from Spark (or any 4D) showfiles into ASCII. This outputs with a file .cpl - if you rename this to .txt, you can import them into ZerOS. However, there appears to be a problem bringing those files into Version 7.4 of ZerOS - i've just tried the whole process here and it's giving me some errors, which we'll need to fix. I'll let you know once these are fixed, and we can export a show file for you. I've attached the converted ASCII files to this message, incase those are helpful to you (you can view them in Notepad or any text editor). Peter
Hi Ferg We've looked into this and it's a small bug with ZerOS which worked in older versions of Capture. Capture changed their software to modify the behaviour when it saw that bug, in version 2.7, which stopped it being able to see the desk. We'll get the bug fixed in the next version of ZerOS, which is nearing completion. The bug reference is ZOS-4864. I hope this helps, Peter
Hi Ferg, We're looking into this at the moment - I should have some more news for you later today. Sorry for the delay with this, Peter (null)
Hi Matt Do you have SmartTag enabled? What fixtures are you using? Thanks, -
LeapFrog hardware upgrade for remote?
Kirkup_xp replied to CreativeThree's topic in Leap Frog 48 & 96
Hi there, You don't need a hardware upgrade to enable the ZerOS Remote app. What type of router do you have? D-Link have a large product range, so it's worth checking the exact model number. Most importantly, we need to know if this router is acting as a DHCP server. Is your iPhone connected to the router, and does it have an IP address allocated from that router? What are the IP addresses of the two devices? If you're using DHCP on both devices, and the DHCP server (router) is allocating sequential addresses, you should see something like 192.168.0.4 and 192.168.0.5 for the two devices. If you try connecting a PC to the same router, does the ZerOS Remote Monitor application allow you to connect to the console? -
Hi Dan The effects engine in ZerOS only applies to the first Red Green Blue segment in a fixture, at the moment. To get around this, I generally patch it as multiple fixtures (one for each segment) plus a base fixture. I hope this helps, Peter
Hi cycy, Sorry for the delay with this. Please find attached the profiles for all 3 types. cycy.ift I hope this helps,
Hi there cycy Do you have the user manuals for these fixtures? I've had a look online but can't seem to find a user manual for these. We need to know the layout of each channel for the fixtures, for example: 1- Red 2 - Green 3 - Blue If you have a copy of these, please post it here and i'll get the fixture profiles made for you. Peter
Hi bvanenk, You can adjust the programmed speed of the chases individually, by selecting the submaster and pushing EDIT, then making the adjustment required. For live adjustment on the fly, all chases will be adjusted together. I hope this helps to clear it up, Peter
Hi Jake As you can see above, we actually released Phantom Jester back in 2008. This is available for download from the support pages: http://zero88.com/support/index.php?/Knowledgebase/Article/View/381/32/phantom-jester---offline-editor-for-jester-range---version-31-win2k---win7 I hope this helps, Peter
Hi there, We have actually enabled the Effects Window now for the Leap Frog 48 & 96 consoles - hold down SHIFT and push EFFECTS to open the Effects Palette window, then push the 'Effects Window' button in the top left, or use the 'Other Windows' dropdown in the Output Window to open it. Hope this helps, Peter
Hi Carl Please find attached the profile for the Mac Aura. macaura.ift Let us know how you get on with it - it'll be added to the next release of the fixture library. Peter
In celebration of 40 years of Zero 88, Cooper Controls are running a competition to reward loyal Zero 88 users with a chance to win a new lighting desk. To win a console, users simply submit a photograph of them with their Zero 88 product, from past or present. Pictures can be submitted via the Zero 88 facebook page (http://facebook.com/zero88) or by email to mamz88@orbdesk.com, and should feature the user themselves alongside any Zero 88 product. If users don’t have their Zero 88 product to hand, a photograph in a Zero 88 t-shirt at an interesting location is also acceptable. The competition runs until Thursday 6th September 2012, and the lucky winner will be announced at the PLASA Show the following week. Full details on this competition can be found at http://zero88.com/mamz88 together with terms and conditions.
Hi Jack It's probably easiest to give us a call at the office tomorrow on +44 (0)1633 838088 and we'll be able to talk you through fault finding this. If you don't have a memory playing back inside the dimmer, and it's not responding to DMX control on those channels, it's possible there is a hardware fault inside the dimmer. Peter
Hi Ben This sounds like it could have been down to a congested WiFi environment. Try downloading the Network Ping app (http://mochasoft.dk/iphone_ping.htm) and use the Ping function to see what sort of latency you get from the network (I use the 'lite' edition, and the 'ping forever' function). It could well be that your response time across the network is being slowed by additional wifi traffic, causing the remote to drop out. Peter
Hi Codebone, If you double click on the 127.0.0.1 in Phantom ZerOS, you should be able to select from other IP ranges on the PC - Phantom allows you to route the IP traffic from any of the Network Cards within the PC it's running on. 127.0.0.1 is the local loopback IP (also known as 'localhost') - it implies that the network card you have selected hasn't had it's IP address configured (maybe it's set to be allocated it's IP by DHCP, and no DHCP server is present on the network? or maybe it's disconnected from the network?) Phantom ZerOS, unlike the real desks, doesn't allow configuration of the IP address of the device itself - you'll need to use the Windows control panel tools to alter the IP configuration, then restart Phantom ZerOS. Note that in order to connect to a visualiser, you do need an Ethernet connection active - you can't just use the loopback, even if Capture is running on the same PC. I hope this helps, Peter
Hi Kalamaku The ports 4, 10 and 11 relate to the internal serial ports used on the PC104 main board inside the desk. Due to the design inside the desk, the WARN errors are normal - it's an advisory that it's trying other port numbers, nothing to worry about. I'm not sure of any dealers in Hawaii who can service the desks at the moment - if you let us know the problems, we may be able to suggest fixes that you could fit yourself, though? Peter
Android Remote on XPERIA X8 not useable
Kirkup_xp replied to Licht360.de's topic in General Discussion
Hi Jo, We've resolved the crashing issue when the app is rotated, in the latest version. The support for smaller screen resolutions is still in development, but you can download the latest version of the app from GooglePlay now. Peter -
Hi Tim, We've just released a new version of the Android App (version 1.4.13) which resolves a number of issues. Please download this and give it a go - it should be available in Google Play now. Let us know how you get on, Peter
Common Fixture Editor not saving any .cft files
Kirkup_xp replied to Gemini's topic in General Discussion
Hi Morn Sorry about this - you spotted a problem with the import of our downloads to the new website. This has now been resolved, so you can download Fixture Tools 2.6 from any of the product pages. Sorry for any confusion this might have caused - hopefully this will resolve your problems.
