                Posts115
Everything posted by Edward
	Yes that will be a good next step in the trouble shooting, be interested to hear the results! Edward
	Although the Jester series consoles can't be networked or remotely controlled using an app, you do have the option of a close-contact remote switch using the Jack port that can be assigned any console button press. Edward
	Hmm that is strange that the MSC signal is passing straight through the console without the console detecting it. We'll have to wait to see what Jon can suggest, I'm a bit flummoxed by this one! Edward
	I agree with all Kevin has said above. Many people will say keep phases seperate, however you couldn't get phases much closer than in 3-phase cable which is just as likely to have a fault as 2 lanterns being fed from different phases, so it's a little pointless on a modern RCD protected system! Also, many large 3-phase dimmers with multi-pin outputs (Socapex) will be wired channels 1 to 6 phases 123123, or 112233, so again it is expected you'll have multiple phases on a bar. Of course when you can and it is reasonably practicable, then it is best practice to seperate out each bar. For your scenario I'd probably put one phase Betapack for FOH, and the other pair of Betapacks on another phase for over stage bars. As long as the electrical installation is RCD protected and regularly tested you're fine. Edward
- 16 replies
		- Betapack3
- power supply
					(and 1 more)
					Tagged with:
	Hmmm interesting. Do the device IDs match on the Orb and the Laptop 1 MSC trigger? Edward
	This would mean that there was no MIDI signal present coming from the interface to the MIDI In port on the console. Edward
	Hi Paul, If all is good with your MIDI interface and the LED is lighting when a trigger is sent, ensre on the ORB in SETUP -> Inputs & Outputs -> MSC Enable -> Set device ID. This will then control Playback 0 in 7.9.2. Just be wary if you are using a cheap MIDI interface... http://www.arvydas.co.uk/2013/07/cheap-usb-midi-cable-some-self-assembly-may-be-required/ Edward
	No I haven't. My first question would be what MIDI interface are you using? Does it have any sort of LED indicator on it to show it is receiving MIDI from your PC. Edward
	No I haven't, however using a decent MIDI interface box such as a MOTU brand will work using MSC. Edward
	Hi Paul, I'm pretty sure Playback 1 is still used for MSC in ZerOS 7.9.2.  EDIT: After the update it is now the Master Playback 0. Edward
	Betapack 2 screw size (security plate)Edward replied to kgallen's topic in Other Discontinued Products Haha will make some enquiries when I'm in the office next Thursday. Edward
	Betapack 2 screw size (security plate)Edward replied to kgallen's topic in Other Discontinued Products I have looked around online and can't seem to find any of the specs for the screws, and I've come across several dimmers with screws missing that I've wanted to replace myself! The exploded diagram doesn't state what they are. 😕 Edward
	Thinking of getting a Zero88 FLX desk..... Thoughts Please....?Edward replied to Uriahdemon's topic in FLX Not personally no, however knowing what Freestyler is like and knowing how user-friendly FLX is, I'm sure you'd find it a pain free and beneficial improvement! Edward
	Hello, Please find the Fixture file for the Light Sky ECL54-415... LightSky ECL54-415.ift and Light Sky ML12003H... LightSky ML12003H1.ift Hope these are ok, any queries let me know. Edward
	Hi Simon, I believe this is not available on FLX at the moment, however is something I'm pretty sure is in the pipeline to be included. Edward
	Thinking of getting a Zero88 FLX desk..... Thoughts Please....?Edward replied to Uriahdemon's topic in FLX Hi Uriah, In my opinion FLX will be the best console out of the product range to suit your gigs. It's hardware is ideal for busking using Playbacks, User Defined Keys and Palettes with Programmer Time. It's certainly going to be a big improvement on Freestyler, and yet still be easy to get to grips with. Edward
	Hi Simon, Ah I understand what you mean. What console are you using? This is currently available for FROG2 and Orb series consoles, by IIRC using the syntax 58 COLOUR COPY 65 will copy 58's colour to 65. Hope this helps Edward
	Hi Simon, I have had a play and see what you mean. The Palette copy function will be returning soon. When selecting Filters, the filter name will appear in the Command Line of the console, and as you say give RGBW values in the Programmer table. Hope this helps Edward
	Hi Adam, What software version are you running on your Orb? I believe this was a bug in ZerOS 7.8.2.36, and so I recommend you using the latest software (ZerOS 7.9.2). Edward
	Yep the showfiles will indeed be compatible, the main difference is the programming process, however the video on the download page will help you when you make the update... http://zero88.com/support/index.php?/Knowledgebase/Article/View/587/ Edward
	Hello, I would advise you updating to the new software (ZerOS 7.9.2) but probably after your exams as there is quite a difference in operation. If you are able to do a hard reset of the console. Do this in Setup -> Clear Options -> press and hold SHIFT + click Reset Desk. Doing this operation will clear any options you have set and reset the desk to factory. If you are happy to go ahead with then reboot the desk and try again. I presume you are using version 7.8.2.39? Let me know how you get on, Edward Is that a touchscreen monitor? Thinking about it further another possibility (you may have already tried this) is that your touchscreen isn't calibrated, so when you click Load Show it's actually pressing Load User Fixtures? Edward
	Hello, The latest software release for OrbXF is ZerOS 7.9.2 and I recommend you upgrading. You can download the software along with update instructions from the link below... http://zero88.com/support/index.php?/Knowledgebase/Article/View/587/ To record a cue in ZerOS 7.9.2 on Orb XF you setup your lighting state, press RECORD, and then press any select button of one of the 60 playback faders. This then records your lighting state to this fader. To make an entirely blank cue don't select any fixtures or change any fixture parameters, and repeat the same process. A blank empty cue will be recorded. Hope this helps Edward
	No worries glad that helped. Edward
	Very true, ideal for if you don't want to use up a fader. Edward
