hafashah
About hafashah
  • Birthday 06/05/1981
hafashah's Achievements
  1. in cant locate the (Edit Fixture ) in the setup menu , were can i find it , or if there is a method that i can change the Home attributes for the fixtures ?
  2. I’m trying to write a Fixture for chines’ moving head using the Fixture type editor, I managed to do it all but I couldn’t find a way to write the lamp off, on reset macros It’s available on the moving head and it’s on channel 21, help pleazzzzzzzzzzzzzzzzz
  3. Jon , So yes done that , worked all day on it , turned it off and today tune it back on there were 1 hour delay , the console was turned off 12 hours , I notes that after updating to the latest software , but I’m not sure
  4. As far as I know the disk saves shows will , and runs them will , the disk is still new a doubt that it might be a battery thing !
  5. good day to all , my solution keeps changing the clock every time I turn it off and comes bake in the next day , Any ideas ?
  6. that is exactly what i'm looking for , thank you so much
  7. Have same problem different case, if you have dimer faders up , let’s say 1,2,3,4 to 50% and you are using these faders with a submaster they do not respond to the submaster , Is there a button to hit so you can control them? I’m trying to run live and recorded scenes .
  8. that worked well , thank you
