kgallen
Everything posted by kgallen
  1. Understood, and makes sense! I converse with Edward so much these days, and he uses my real name we forget that might be too "open" on the Internet. Unless I'm being blind or stupid or both (and both likely), I couldn't see a way to add "real name" into my profile. (Sorry tbarden for hijacking your post - hope we've answered your question!)
  2. 🙄 Forgotten my name already... must've had a long day. Me still working too... Regards, Kevin
  3. Click "Download this file" on the page below and then the box that comes up allows you to download "PhantomZerOS_7.9.4.zip" (7.53MB).
  4. Is the USB plugged directly to the back of the console (not via a hub). Is the monitor on the "supported" list (yes it is). Compatible-touchscreen-monitors-with-ZerOS-consoles Which console? (FLX, FLX-S48, Solution etc) If FLX try "Factory Reset" from Setup -> Clear If FLX under Z -> System Information can you see the touchscreen listed?
  5. Thanks Jon - working ok again now (just like Ian's Demux48)! 😎
  6. Thanks Ian, at least I'm not going mad. Work have been locking down a bit recently - can't listen to BBC radio online any more for example (miserable s*ds). Hoped that wasn't also affecting Z88 Forum access!!! Kevin ps Is that a "new" Demux-48 in your profile photo>?!!! 🙂
  7. Sorry I'm having trouble navigating the Forum at the moment to find a past topic on this, but it will be something like: - Tag the parameter to remove - Turn off Smart Tag - In the Update window, click Remove - OK the Update This is what it is on FLX (full model), not sure how the UI differs on the S24/S48. Hope this gives you something to try. Kevin
  8. Is it just me... On the Forum at the moment I can only get to page 1 of a topic. I can't get to page 2 etc of e.g. the FLX forum by any means: - click "2", "3" etc -> No - click "Next" -> No - click ">>" (last page) -> No -click "Go to page", type number or use arrows -> No - do a search and in the search results try and move pages -> No It always just brings me back to page 1. Strange... anyone else having this? Kevin
  9. ... that is, press the Update key on the console...
  10. It's a problem I have too and I don't have a good answer, other than putting some kind of version number in the profile name (say v1,v2,v3 etc) on the end so you can find the "old" ones. Then really all you can do is reassign the fixture then do this: I've requested an enhancement to support this requirement sometime in the past.
  11. Hi Franck I think the 4 wheel group setting is only for the Illusion series consoles (and the 3 wheel group for Frogs). Which console are you using? I'm not sure how you associate colours with particular encoders on say FLX: on the fixtures I make they just come up in the order I declare them! Kevin
  12. Setup plus fader button probably.
  13. Have you programmed the UDK first? <Hazer> @@ RECORD <press UDK> Press hold Setup. Press UDK. Release Setup.
  14. Reset your desk. Follow the article I referenced. Reproduce their example. Understand tagging/SmartTag a bit. Go back to your original requirement with that new knowledge and programme it and configure the playbacks with the recipe you've learned.
  15. I think you should if it's convenient. As it was like that from new I think that's what Edward would say!
  16. Looks broken to me.
  17. The cue colour fade time defaults to 3 seconds and are LTP at 5% fader, whereas intensity will be HTP. Does that explain what you're seeing? Did you try the approach in the Knowledgebase article substituting your colours for their RGB?
  18. Maybe depends how you recorded the playbacks - what information was recorded. Some of the concepts explained in this Knowledgebase article might be relevant (such as you might need to be turning off SmartTag when you record your colour setup playbacks). Have a read and a play with your more specific colour setup and see if it resolves the conflicts: http://support.zero88.com/Consoles/FLX/1014413041/RGB-Colour-Mixing-on-faders-FLX-Series.htm Kevin
  19. Show off! 😆👍
  20. I was gonna say, if Ian can't help you with a Sirius, no-one can... 👍
  21. Battery. See here:
  22. I guess for a variable fade chase you could keep your cue stack and use Auto Trigger to cycle through the cues. In the cue list, choose the Settings button (or select the Cue Options cell and press enter).
  23. Edward. That will be the critical ‘right click’ bit... 🤦‍♂️Doh.
  24. Hi Edward, So these are the instructions in the KB: To set the IP address of a PC as per Windows 10: Right click Start, and choose "Network Connections", to open Control Panel Double Click on "Ethernet" Double click “Internet Protocol Version 4 (TCP/IPv4)”, and click “Use the Following IP Address” then set the IP to 2.1.1.10 and the subnet to 255.0.0.0, and click OK. The sequence is a little longer than the list above - I've finally found it. I guess if you do this every day, then you know where it is! Start, "network connections" just gets me some useless web searches. Start "Control Panel" gets me of course to control panel app, but it's not at all clear how to then get to somewhere to set a fixed IP address (rather than say DHCP). I know the form you refer to but can't for the life of me find where the darn thing is in Win 10. Of course, they try to hide this kind of low level stuff more and more - it's comparable to Jon not wanting us to be able to access DMX values on the console! 😋 So finally I've found it: So once at Control Panel, we take "Network and Internet" then "View Network status and tasks"? Then "Connections: Local Area Connection" Then "Properties". Then select "Internet Protocol Version 4", Then "Properties". Then At last "Use the following IP address". 😆 One other question - I tried to use Phanton ZerOS with Capture - is that possible, or does it only work with a real desk? Thanks, Kevin
  25. Edward - the Windows 10 PC IP setting instructions aren't correct (certainly not as April 2018). Can you elaborate/update in the article? Thanks.
