110
Everything posted by kgallen
Yep that's right. Should work well for colour palettes and effects engine - see various posts on things like sunstrip where Edward/Jon have elaborated on using the effect engine across the "multi-fixture". The time when this approach doesn't work so well is with a mover (or any mechanical-based system) because for move on dark to work the desk needs to associate the intensity channel with the other channels i.e. know it's "one fixture".
Hi Ollie, Yes as Erics says unfortunately. I think the subfixture only works for something like lantern+scroller. I had a loosely similar issue with a Showtec Shark Combi which is a combination of LED RGBW wash light and a profile with colour wheel. Edward made me a fixture (posted somewhere here on the forum) to handle this - but as you found the colour picker only works with one part, in my case with the RGBW wash part. The colour wheel is encoder only. Kevin
Here's David's 4-way colour picker as above but without the selected cell aberration in case anyone wants to use these directly. Great work guys!!!
Phew! 👍
Setup + Playback button should be the "global" setting. Above I was referring to the Settings specifically in the cue where I believe you can override the MOD time for that cue. However I'm more used to FLX (rather than FLX S) so sorry if the config is not in exactly the same place or the buttons are different. The 7.9.6 manual is here, see p44: https://zero88.com/storage/downloads/7f906b85-80f1-4646-bd18-d2327d94fc60/FLX-Range-&-ZerOS-Accessories-User-Manual-v7.9.6.pdf
Cue Window -> Options on the Cue
Great thanks Edward, good to know. Cheers, Kevin
Hi Edward: I'm referring to ZOS-8569 (interested when this will be fixed or if it already is and I've missed it in the Release Notes!). Regards, Kevin We discussed 8569 a couple of times, regards GROUP and P/T grid (the second is in Beta - some readers might not be able to see it):
Don't take this at face value, the order selection is a*** backwards sometimes... a bug not yet fixed...
Geez, I've told them so many times - us blokes don't have girls fingers for all of these tiny dialogue boxes, effects selections and teeny weeny narrow scroll bars - and we have fingers as rough as a badger's sitty-down areas after a couple of days up a ladder rigging!!! There're two of us now telling them this, hopefully they'll listen! 😁
Maybe drscoop could tell us which desk lamps and how many. Edward - what current output do the FLX S support? The minimum 100mA? which is still quite a lot and gives 500mW of output and I wouldn't expect an LED desk lamp to draw that much power.) The Adam Hall SLED1 (quad COB) as an example claims to draw 50mA @ 5V, which should be supported easily by any USB output. https://www.adamhall.com/shop/gb-en/stands-tripods/lamps/5491/sled-1-ultra-usb
Brilliant Mark, I like it and will "steal" it for my FLX! Kevin
Guessing now... is there a "fade" time you can apply to the Raise Fader that will do the "gentle introduction" for you?
"Is it true that RDM causes lights to flicker?" You need to include your handy tip which is to address problematic fixtures above a certain address. 6/June/2020 Updating with info from the latest Z88 video series (DMX & RDM): *If* RDM start code interpretation is the issue with the fixture's DMX implementation: Address the fixture above DMX address 32 (90% chance of solving issue) Address the fixture above DMX address 257 (should definately solve the issue) Jon also covers it hear on the Forum. I can never remember the upper number, so let's write these down everywhere!
Cheers Jon, much appreciated for the fast reply! Kevin ps I'll edit the title of this post to reflect Mk1/Mk2 for future reference.
Any chance someone from the team could let me know the dimensions of an Alcora Mk1 (12 channel). The dimensions aren't in the manual (GB/DE or FR). Yes I have one I could in theory measure but it's not accessible to me at the moment and Google has failed me! Thanks, Kevin ps Not in the Mk2 manual either.
"It would be nice" to have the equivalent of the Strand GSX "LOAD x" function, so cue x is stacked ready to press GO. Currently with ZerOS, you have to "GO x" which means you have to be sitting there holding the GO button (having typed the new cue number) until the cue. I realise (on FLX at least) you can step back the Next bar on screen, but this is not always convenient if the new cue is distant. Also I know you can type the cue number and ENTER, but I believe this also does the "GO". Kevin
This link seems to work: https://www.zero88.com/storage/downloads/7f906b85-80f1-4646-bd18-d2327d94fc60/FLX-Range-&-ZerOS-Accessories-User-Manual-v7.9.6.pdf
Hi Edward, Brilliant, thank you, I'll have a play with those ideas! Thanks, Kevin
I have 4 movers hung above. The effect I want to create is beams swinging across the stage. ‘Swinging elephant trunks’ I think is the most visual way of describing this! At one time I might want to phase align all 4 so they move in unison and at other times I will want to have the 4 moving in an arbitrary phase to each other, but the period would be the same. What is the quickest way to achieve this (as a movement effect stored in a palette). I guess I need to use a sine wave on the pan and/or tilt and offset this randomly across the 4 fixtures. Your wisdom please! Thanks, Kevin
7.9.3 seems to be the legacy. Maybe Edward can put 7.9.4 and 7.9.5 on there too. https://zero88.com/forum/files/category/4-legacy/
I think only if they are of the same type of mover. Probably also you need to have programmed the MFFs using groups (which you'd update to add in the new movers) and palettes. I know palettes are referenced, but I'm not sure about groups, so that bit of my sentence above could be a non-starter too... Let's see what Edward says...
Nah, I don't see "GO" on Phantom but I do on the desk button! 😋
Hi Mac, It's ArtNet over Ethernet or sACN over Ethernet. ArtNet and sACN are just two higher layer protocols, for carrying DMX-like numbers, that exploit an ethernet network (and even then I think there might be some network restrictions/implications!). Likewise DMX512 is just a protocol for transporting 512 numbers regularly over a pair of wires!
