kgallen
Everything posted by kgallen
  1. Oh, the old "I just changed the battery but magically the DIP switch settings (on the fader PCBs nowhere near the main-board PCB) got changed" issue. DIP switches are hard enough to change when you deliberately want to change them, I've never figured how the DIP switches inside Frog consoles get accidentally changed and I've done the battery inside mine 4 or 5 times... 😏 Anyway, glad you're sorted!
  2. Download the ZerOS OS Creator USB - v7.9.5 17-5-2019 MD.zip file to your PC, unzip it and copy to the root of a USB stick. Then Setup->Load and load the new software like you'd load a showfile.
  3. kgallen
    My stupid questions
    Good tip using HOME to tag all parameters -> one for a knowledgebase and User Manual FAQ please as it's guaranteed by next week I won't be able to find this thread when I'm looking for this top-tip!
  4. kgallen
    Update issue
    Does this help?
  5. Your word - "holiday"... Ummm, I'm not familiar with that concept 😞 - and judging by the amount of activity on the forum recently, that seems to be a common theme for many! 😆
  6. kgallen
    My stupid questions
    Agree. Best I can think of is to use Preview in the Output Window. Then I think the colouring should show which fixtures have data in the cue or which track. This is at the fixture level though, so to see it at parameter level you'd need to select the fixture (not sure if you can in Preview) in order to get the "detail line". The colours are documented here: http://support.zero88.com/Legacy-Products/Legacy-Consoles/Legacy-ZerOS/ORB-XF/1011707591/What-does-the-Output-Window-show.htm
  7. kgallen
    My stupid questions
    I'm really bad at this (as is evident from the number of times I ask "how do I get this fixture out of the cue" on this forum!)... But it will be along the lines of: Select the Group (to select the fixtures in the group) Update (and hold to get the Options window) SmartTag off Remove OK
  8. kgallen
    My stupid questions
    If you do Setup+Position or Setup+Effect then you should get an options box that says what the Encoder does and what Shift+Encoder does. The reference fixture (or "zero point") will depend on the fan type - fan middle etc. But you're right, you don't get the values anywhere - although the value above the Encoder is going to be for the "master" or selected fixture.
  9. UK (South West England/South Wales). Bought October 2015, so a relatively early adopter. FLX bare sometimes. More usually FLX+Touch Monitor+Mouse+Keyboard. Eric - to answer your question on "why a mouse", well because from my experience unless you are a 10 year old child, or you have points for fingers, things like the scroll bars or Effects Waveform tab are virtually impossible to use with adult/man-sized fingers. Hence needing to use the mouse! No wings. Theatre. Cue-stack based rather than busked. Musicals, pantomimes, some plays, some concerts. Conventionals (Source 4, Prelude, Minuette, PAR64), LED PAR/flood, LED mover, smoke machines/hazers. Sometimes DMX-controlled props. In flight case, mobile. 3-4 productions per year. Each production 7 or so performances. Amateur hobby, not paid unfortunately! I don't know any but there should be plenty around here... Zero88 head office is less than an hour drive from home! Well documented on this forum when I have! Kevin
  10. (Cough) Yes, I can see the release notes are possibly a bit imprecise... I believe you will only get these on an external monitor -> so not FLX S24 which doesn't have an external monitor port. The release notes should probably say "FLX & FLX S48 now include four desktop layouts on an external monitor...". Sorry 😞
  11. Congratulations! I hope you achieved what you were aiming for! Kevin
  12. I don't believe so. ABTT was the other week. I think they're just hiding this week. Edward is maybe busy at Uni.
  13. Hmm bit of a smoking gun there it seems - existing data works as expected, but the latest version (at least 7.9.5) is not internally populating the database correctly from what the UI is telling us. Especially keen to here back from Z88 now on what their take on this is.
  14. OK, interesting. I wonder if your example is an extension to a similar problem I've been having with recording palettes. What you report looks good. Zero88 chaps need to take a look at your situation too then...
  15. You’re recording too much. You need to not record the things you don’t want to change. So in your colour playback, don’t record position or beamshape. Likewise in your position playback don’t record colour or beamshape. Don’t use Snapshot, that records everything. In Record Options (hold Record button til the form comes up) turn off Snaphot and SmartTag and make sure only the attribute you want recording had the red stripe.
  16. The theory is you just record the tagged parameters. For intensity this should be easy as if you just alter the brightness of a fixture that’s the only thing recorded and all other parameters will track. Make sure in Record Options both Snapshot and SmartTag are off i.e. blue
  17. Assuming I was currently outputting cue 1 (green bar) I click on "cue 3" with the mouse (external monitor) to move the next (orange) bar to cue 3 then "try" the up arrow to get to cue 2 for next. I found the master go would sequence the stack as expected (hence I didn't spot this issue) although as described the arrow keys didn't have control of the next bar.
  18. I'm through this show, but I have another production in a few weeks. Are we anywhere with triaging this report viz a fix? Thanks!
  19. Since this was flagged here and I took notice, I pretty sure I'm in the "always on 7.9.5" - but if I think back to some of my 7.9.4 posting (which version had been on my desk for around a year), I did have some cue-stack-focus "snags" but I think that ended up being user-induced. I've been doing a show this past week or so, and I've have a full setup with mouse/keyboard/monitor, and I've been running the master cue stack from the start - so didn't initially realise this issue until it was raised here, after which point I always made sure I used the mouse to set the focus to the cue stack! However I sometimes have a "bare" config using just the console. I hope Z88 can see this easily and sort it out!
  20. kgallen
    Save Show?
    You might be able to get them to file an enhancement request for this - although I've not know this feature on any Zero88 console. It depends on how much non-volatile storage they have on the board - I think they're using some relatively expensive (hence relatively small) FeRAM rather than flash for the ongoing active show image. I think there's a good lump of flash in there too so maybe it's feasible to retain multiple show images as you suggest. Anyway, one for the Z88 guys to comment on rather than me blindly reverse-engineering their product! Hope your FLX is otherwise treating you well! Kevin
  21. kgallen
    Save Show?
    The desk implicitly saves the show internally all of the time, you don't need to do this manually. The Save function is just to save to a USB stick if you want to - you don't have to (although this is wise!). The desk can only hold one (the current) show. There is no internal "USB drive" for saving multiple shows inside the desk. You need to use USB stick for that. Kevin
  22. Have you got the fixture in the same mode as the fixture definition you’re using on the desk? What is the make/model of the light?
  23. kgallen
    UDK lights?
    They don't. You can "test" them by putting a change in the programmer (say 0@@) then when you hit RECORD then any empty playback or UDK buttons should flash (they won't if they are programmed).
  24. Useful to know... I must try some macros... (other thank triggering playback chases).
  25. Hi Philp, For the second part of your question this will be because SmartTag is not recording your fixture requirements because intensity is at zero. When you want to record that cue using the fixture macro programmes, hold RECORD, tap SmartTag (so it is blue) then OK. Remember that for the next cue when you record, you probably want to hold RECORD again and tap SmartTag back to red as probably you want to use SmartTag for building the rest of your cue stack. Kevin
