kgallen
Everything posted by kgallen
  1. Indeed. I had a long discussion with Edward about conflicting and inconsistent terminology around ‘channel’ a couple of years back (when he was doing his vast set of ZerOS videos). Just as you state above.
  2. You should read up the manual because as @Davidmk eludes you can already use it. In its most basic form you could put out the same universe on both connectors - I do that with my FLX to send one cable to dimmers/flown LED fixtures and the other to groundrow LED fixtures. But even your 1U S24 you can spread those 512 channels across two or more universes, don’t have to use them all on one universe - although probably that’s the most usual method, but FLX/S doesn’t constrain you to. Manual link: https://www.zero88.com/manuals/zeros/patching/available-channels Note @Jon Hole I think the manual text has an error, I think it should say: ‘The total number of used channels across the 64 universes must not exceed the number of ->channels<- your console is licensed to output.’
  3. FLX S doesn’t allow user macros and no UDKs either to put one on. But good lateral thought!
  4. It did work. Programmed the show on my FLX with syntax bish-bash-bosh no problem. Loaded the showfile into their S24, worked like a charm. Sat with the op last night during the dress rehearsal, he drove, I stood by to help. He made a decent fist of it given it was his first time ever. Jumped a few cues - double tapped GO or was a bit eager. Was a bit of a pain going back a cue or two as S24 doesn’t have arrow keys and no USB keyboard attached. I set shift-go as pause but the ‘go back’ doesn’t work unless you’re running a cue, pause then step back. Chap kept going into Z screen as wasn’t using that button as a shift key. In the end I suggested he use the touch screen carefully to back step cues or bring in a keyboard. Let’s see if the phone rings later in the week… ‘Hello… he hasn’t turned up, can you…’ Thanks to @Davidmk and @Jon Hole for help and support on this endeavour.
  5. @Davidmk you may well be right but I think default FLX S24 come as 1U/512 unless they specifically bought the 2U version (or FLX S48). Maybe that changed over time (like the 3-pin became a 5-pin) but Stage Electrics still list a 1U FLX S24.
  6. Yes but wait for ZerOS 8.0 to come out (few weeks maybe) when your S24 will become 4 universe for free. As announced here:
  7. Select fixtures. Make the colour however you want. You could start with an existing palette then modify with the encoder wheels. Then RECORD and touch an empty palette location on the Colour screen. Same process for position, beam, shape (but on those generally parameters are separate). This is in the manual. https://www.zero88.com/manuals/zeros/palettes/recording-palettes @van den abbeele Eric can help you with a French manual.
  8. They were on 7.14 so not too bad..! I think the console is pretty new though, so might have come with 7.14 on it! (I realise I've been typing 17.x rather than 7.x! Idiot...)
  9. My fear too... [chap doing LX op is a (potentially unreliable) shift worker, never done it before - the guy doing the sound is a Year 9 school kid, who seems perfectly fine, but... he's 13 - ergo there is no-one in tech FOH with any notable experience]. I've updated their FLX S24 to 7.14.3 the same as my FLX, so in theory we're good to go...
  10. It’s in their manual page so I hope so! My email to that address hasn’t bounced at least!
  11. @van den abbeele Eric Eric, you must know the process by now surely, you're an experienced/established FLX user. Just email (below) Zero88 the PDF manuals, with the DMX map, for each fixture and ask them to build a fixture profile and add to the next library. If you've got one you've built for your own use, then let them know they just need to build for the library release. If you need one building for you for an immediate need then let them know you'd like them to email back to you (and add to the library for the future). I've done this recently for a fixture - I built it myself for immediate use, but sent them the manual and asked them to build "properly" for the next library release. I sent them my ITF file from the Fixture Tools in case that gave them a head start. https://www.zero88.com/manuals/zeros/patching/add-fixtures/missing-fixtures FixtureSupport@zero88.com
  12. I had a meeting with the director last night to put together a lighting cue list (I’m panic called in as they’ve been let down last minute and nothing is prepared!). The cue list is pretty long. I think I’m going to chicken out and programme on my full FLX - because I know I can be faster with syntax and I’ve access to eg Lee Filters - than I would be on an FLX S where I’ll feel like I’m programming with an arm tied behind my back. Jon has confirmed that the FLX showfile should run perfectly well on the S24 (obviously staying within the S24’s capabilities) because some other chap will actually op the shows using their S24 after I’ve done a handover at the dress rehearsal. Let’s hope that actually works otherwise I’ll be in double trouble!
  13. 1. Check you are using the software for the console not PhantomZerOS and not the "USB Creator". 2. Download again and transfer again to the USB stick or try a different USB stick (I've had one occassion where the upgrade started but would not complete - using a different USB stick fixed it).
  14. You can check the list of current library fixtures in the list below. If it's not there, request it using the instructions posted on your other thread. https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/ZerOS-Library-4.5-List-of-Fixtures.csv You can find this list for each release by following the ‘ZerOS Software’ link at the top of this Forum (or in the Forum menu if on a phone).
  15. See: https://www.zero88.com/manuals/zeros/patching/add-fixtures/missing-fixtures
  16. Hi Charlie - sorry for my earlier flippancy! You could email support@zero88.com and ask. There are ‘rules’ for beta testers about console experience, feedback and forum activity. This is because Zero88 don’t want to grant beta access to casual users or inexperienced users who can’t effectively engage in the beta testing process and could otherwise become a support burden. You're a relatively new user - and of course very welcome - but you might have to argue your case so early on to get beta access unless you’re otherwise an established customer known to Zero88 folk. Hope that’s more helpful!
  17. Here: https://www.reddit.com/r/lightingdesign/s/aZnhvIMl8Q Hopefully they’ll get in contact…
  18. By special invitation 😉
  19. Hi, Move on Dark is not directly related to the use of SmartTag, more what information is recorded in each cue. However SmartTag enabled can be useful to support Move on Dark when the console is in the Tracking enabled mode. When your programming becomes more advanced, you can disable SmartTag entirely or for certain Record operations. Move on Dark relies on lights not having an instruction in certain cues, when the console can perform the Move on Dark action.
  20. Ah useful, thanks! The ‘Z’ window is where the daemons live so I don’t go in there that often 🤣
  21. That’s my challenge! I’m so tempted to take my FLX in so I can bash syntax then load the showfile into the S24 for their op to run the show. But I’m going to bite the bullet and use the S24 - especially as I’m aiming to get my local community hall to get an S24 and I’ll have to support users on it, so I’d better learn it! Thanks for the palette name info - found this along with how to delete a cue in the manual this morning. It seems Setup isn’t always used for naming (for cues you tap the name box) and for Delete cue you have to hit the Z key to get up a number pad - not tapping the cue in the cue list as I was trying! I think I need to create some additional labels for both the desk and keyboard! I was surprised ‘N’ on an external keyboard doesn’t do Name as it does on FLX. Given the FLX is now discontinued maybe some of the ‘advanced’ features will creep onto the Sxx - processor power and UI allowing Still haven’t found a syntax line coming up in any window so I guess you have to type it blind and see what happens! 😆 I’m getting there…! Cheers!
  22. Thanks David. I guess that’s a good possibility - I had engaged Programmer Time (at 5s) when playing around with it. I guess I’ve never noticed my own FLX doing this! Today I put 7.14.3 onto it and the Clear LED seems to go off straight away. But that could well be because Programmer Time is now off after the effective factory reset! Had a decent session with the S24 tonight. But still need to hit the manual to find out how some things are performed compared to the FLX! At least I had a USB keyboard plugged in which helped and I did resist using syntax - mostly! Whilst I can name Cues, I’ve not worked out yet how to name palettes or how to Delete individual cues without using the keyboard!
  23. First time using FLX S, I own for many years the "full" FLX myself so that's what I'm used to, syntax, external monitor and all that. I'm helping another group out at short notice (isn't that always the way), they have an FLX S24 running 7.14. It looks like newer desk hardware as it has the two 5-pin XLR DMX sockets (I believe initially the FLX S had one 5-pin and one 3-pin). I'm having an issue where the LED in the CLEAR button is staying lit, even when I've done CLEAR-CLEAR and there is nothing shown selected. Sometimes after a while (maybe 10 seconds) the LED will go out on its own but not always. Is it that these lower-end consoles are already really laggy on their UI? If I go into SETUP and come out again the CLEAR LED will extinguish. I don't see this listed as a bug fix in the 7.14.1/.2/.3 release notes. Is this a known issue still? It's not a big issue but I'm in to educate their folk on programming the desk and this issue is kinda annoying... I'm going to propose loading 7.14.3 onto it - and hoping this doesn't brick their desk otherwise I'll be in big trouble! Otherwise, if any of the experienced folk on here have hints and tips or gotchas for a full-FLX syntax user moving over to the "baby" console, they would be much appreciated! Yes I've grabbed a USB keyboard and will try and learn more of the syntax keys that are supported, but probably I can't use that for tutoring their folk! I don't see syntax lines coming up on any internal monitor desktop, is that expected? Rigging an external Monitor over a small LAN isn't going to be practical. Yes I've been watching Edward's FLX S specific videos! It's payback time folks 😉 Cheers, Kevin
  24. e.g. in FLX S24 Hardware Introduction
  25. Hi and welcome! I'll have a bash at this question, but other users who do "busking" will likely have other tips. The FLX consoles are fully capable of what you want to do. The key to your requirement is for the programming process to only record in a given playback/cue, those parameters you want it to control. This allows other playbacks, say colour or position, to be triggered on top and to only affect those you desire. Your programming style will need to use the "Tracking" mode of the console and for you to avoid using Snapshot during record. SmartTag enabled will be the most useful setting to start, but as you become a more advanced user of the console, you might start setting SmartTag disabled for some record operations. I realise you have programmed a show, but your requirements are best explored by starting off with some basic programming whilst you get the hang of it. From a programming perspective, colour, beam, position are all interchangable. Any examples you do with colour should work using the same procedure when applied to position. Let's assume you have a baseline show recorded on your master playback (the one the GO button steps through). Say on one other playback, say Playback 1, you want that fader to change some lights to red. Clear the programmer with CLEAR-CLEAR Select the lights you want to change to red with the fixture select buttons. Turn them on to some reasonable brightness so you can see what you're doing. Say 80%. Change their colour to red using colour palettes or the colour picker. Don't change anything else on these fixtures, otherwise you will "Tag" other parameters you didn't want to change. Tap Record and then the Playback 1 button. Since you want this playback to control colour only, press Setup and tap the Playback 1 button. Select the option "Fader Controls:" to Colour. There are other settings that we should check, like Release on Lower is enabled, but I am going to assume they are still at the desk default. Do CLEAR-CLEAR and then get your master playback controlling the lights (GO) so you have lights lit. If you then push up Playback 1 fader (remember to change the faders to Playback mode) then those lights (if they are already lit) should crossfade to red. When you pull Playback 1 fader back down to zero, those lights should go back to the colour they were as programmed in that cue of the master playback. Note that since we set Playback 1 to "Fader Controls: Colour", pushing up this fader won't light lights that were not on from your master playback. If you want that, then Fader Controls: Intensity is what you want for that setting. Then the fader will control the intensity but the lights will snap to red at about 5% fader position (although you can change this time in the Playback settings). Hopefully that is enough to get you going... and hopefully I got most of the above right and didn't forget an important step. The manual is here, probably this section is most applicable: https://www.zero88.com/manuals/zeros/cues-playbacks Edward has done lots of training videos and there is at least one that will cover this. I'll see if I can find the most appropriate one and come back here and link it for you... This is probably the specific one I was thinking of, but it's possible you will need to do some of the others to get an understanding of wider console a little more and maybe the terminology: Lots of FLX training videos here: https://www.youtube.com/@zero88/videos
