JB97
Everything posted by JB97
Stupid question, but is the FLX going to just have roman numerals (as I have seen advertised) or will the FLX still be available with the 0-9 buttons? Cheers, James
Hi All (Specifically Jon as I know he likes these products) I recently got a new laptop (macbook pro) and wondered how I would best use phantom zeros to transmit data over art net? Any advice/help? Thanks James
Yes, Jon can this be logged as a request, as I can agree with the want to be able to lock the console fully down, possibly to "freeze" the DMX outputs, so you can do your walk-in lighting but have the desk not respond to controls. An issue I can see is the operator forgetting the unlock code and panicking... James
I saved it as V2 of the show, when I load up my memory stick on phantom it detects V1 and Blank (which is just a blank file I use for training etc)
Hi All, When saving to a memory stick on our jester the desk correctly saved and I took the drive out. When I plugged the stick into my laptop to open on phantom the most recently saved file was an older version of the show, any ideas why? Thanks, James
Just to give a quick response, and it's worth checking the manual and getting other news but I think there is an option to change between LTP and HTP. LTP would give the effect you're describing HTP would be the dimmer mix Again, kinda just guessing xD
Sorry for the long delay, the LCD just says "TEST MODE, DMX:OK" the keyboard is working fine
Hi Ollie, For Gobo 3 to have a start value of 24 my guess is something else is before it, ending at 23. Select the items before it in the list, add the images and click replace, hopefully that will help. Cheers, James
Proposal: "Ask the Expert" online chat sessions?
JB97 replied to Jon Hole's topic in General Discussion
I love the idea, honestly if they were at manageable times for me I'd join each session, even just to see the discussions. The only thing I'd add would be the live publish of logs of these chats that we can view at a later date. James -
I think it's a very sensible idea, it means operators would be able to transfer skills across consoles more easily.
What is the make of the screen and keyboard?
I agree, always just keep a memory stick backup. Although to ensure extra safety, I make sure the backup is on my spare pyro keyring, never getting lost
Can you explain the issue in greater detail? James
Do you need all the modes for each light? Or can I only make one mode per Lights? I'm sorry they aren't done yet, i haven't had time, I'll get them done tomorrow XD James
If you could get the manual for each light, I'll make the fixture profiles James
Probably a stupid question, but does "GROUP 1 AND 2 ENTER" Select Group 1 and Group 2 or Group 1 and Fixture 2? Thanks, James
Kevin, I can try to give it a go today. James
Hi Guys, Doing some programming on our jester earlier, I had a usb keyboard plugged in to name cues, and it worked for the first 3 cues, then the keyboard stopped responding. When I unplugged the keyboard the shift was locked in place, which obviously messed with the cues. Turning the desk on an off again fixed the problem, but the keyboard didn't respond again. Any ideas? Cheers, James
I'll give it a go now, but I might have to defer as I'm not amazingly confident xD Edit - I couldn't see how to best do the split for 8/13 channel mode... Or how to do pan and tilt fine.. Sorry :/
I have the manual. I'll try to get the file made. Kevin, here's the manual if you get the time to make it :-) http://www.farnell.com/datasheets/1869759.pdf
In the data sheet for the chilli 24-10i it says " Control Input: DMX via terminal block accepts DMX 512-1990. Start address set via front panel controls DMX termination may be switched in or out internally" Could someone explain what that means? Thanks, James
