jonny.solution
jonny.solution's Achievements
  1. Hi the manual is here: https://images5.static-thomann.de/pics/atg/atgdata/document/manual/c_307515_v2_r2_en_online.pdf Ideally if should have it in 8 channel mode please Many Thanks Jonny
  2. Hi, could i possibly have the fixture file for the Stairville Quad Par Profile 5x8W RGBW so that i can run it on my zero 88 solution. I need to run it for an event on friday so any help would be much appreciated Thanks Jonny
  3. Thanks for that
  4. Hi can you send me the fixture settings for the freq5 strobe please Thanks
  5. Thanks, that all seems to be fine, I will check when i put it into the actual desk tomorrow, seems to be fine on Phantom Thanks Jonny
  6. Hi, I was wondering whether you could produce a fixture for Zeros for: Eurolite ML-56 QCL RGBW/RGBA 18x8W Thanks Jonny
  7. Hi I was wondering whether anybody has created an RGB value list for the basic colours so that is is easy to enter them into a solution because the generators online make the RGB top value of 255 whereas the solution only goes up to 100. Many Thanks Jonny
