AlRamsay
Everything posted by AlRamsay
  1. Hi, I've got a Sirius 24 that is not outputting the correct voltage at the analogue output. On a working desk, I am reading 0.23V-10.08V on the analogue output. On the faulty desk, I am reading 0.82V-2.80V, this is also reflected in the output LED being significantly dimmer than it should be at full output. This fault is common to all channels on the desk. Can you give me any guidance on how the output voltage is derived, is there a voltage regulator I should be looking at? Kind regards Alasdair
  2. Hi Keith, Can you cast your memory back..... I've got a Sirius that has developed the same problem as described above. I've also got a donor desk that I'm swapping IC's with. I have removed the 32K memory chip and replaced it with no effect, I've also swapped the processor IC25 and the two eproms IC22 and IC23 and stil have the same problem. Which chips are the address decoders? Kind regards Alasdair
  3. Thanks Jon That's exactly what I was looking for. Al
  4. Hi, I've had a good look through several web sites and price lists looking for a rack mounting kit for the Jester ML. Surely given it's size you must supply them somewhere... can I have a part number and supplier please? Best Regards Al
