skippa
Everything posted by skippa
  1. Hi, is it possible to connect a simple USB-MIDI device, for example the well known Korg NanoKey 2, to the Desk for additional action-buttons? Would be perfect :-) skippa
  2. Hello, after singning up here 2006 i have a ne question. will there be a internal fixture-editor in the flx-s series consoles? This (and the current limited numba of fixtures) is the only thing that keeps me away from switching to this console. regards from germany skippa
  3. Hello I use a Demux48. since the last few weeks the device did not start correctly. I think it was caused by the low temperatures in the dimmer room (maybe 0 to 5 °C). When the temperature in the dimmer Rack / Room rises up in the evening i can start the demux48 device normal (starts up with testing all LED-segments, then showing the start-adress). No i changed the battery to a new one (3,6V NiMH, 140mAh), but now the device never starts correctly. i measured the voltage at the battery an detected that the voltage is going slightly down, seems like discharging. I soldered ist aout of the PCB an checked it - the battery seems to be OK, out of the PCB the voltage rises up to its normal 3,6V. Whats wrong with my Demux48?! greetings from germany MArtin Knott, MAxdisco (www.max-kiel.de)
