Lufferov
Everything posted by Lufferov
  1. I've done this in the latest firmware 7.8, but I'm having a problem. When I record the R, G, B values in seperate faders it doesn't mix them correctly. As I increase Red it fades out Blue and Green, as I fade up Green it fades Red and Blue out. It seems to be recording the value of all three parameters (RBG) in the sub, so the Red sub has Red recorded at 100% Green and Blue stored at 0%. Green sub is Green at 100% but Red and Blue are at 0%. Smart Tag is disabled, the submaster controls is set to colour and I'm in tracking mode. I've also set "keep colour parameters sperate" to "Yes"... so how do I make the sub ONLY store the value for the individual colour? I've been at this for days with no success! Regards.
  2. Thanks Jon, this worked a treat, though when you are using 16 of them, that means you have to keep track of 64 fixtures!
  3. I have a Pulse LED block that has 4 cells, it's a 13 channel unit with the following attributes: 1 - Red 1 2 - Green 1 3 - Blue 1 4 - Red 2 5 - Green 2 6 - Blue 2 7 - Red 3 8 - Green 3 9 - Blue 3 10 - Red 4 11 - Green 4 12 - Blue 4 13 - Intensity How should I configure the fixture for use with the Leap Frog 48? I need control of each cell individually with I'm assuming virtual intesity? Is it also possible to use the colour picker? Basically, I'd like to have access to as much of the effects palette as possible so I can generate colour chases along the cells etc...
