  1. Yesterday
  2. I have a zero 88 light mixer and it had problems with the sliders so I saw on another form on this site how to reset the memories but I accidentally erase everything from the memories and i red that the DMX need a software of some sort on a floppy disk to work on the desk. hopefully you all have that software or another method to get that back because i need this mixer to work asap. hope to hear from someone soon. Rigo
  3. Having checked as you suggest the current software, it is indeed 7.9.4.3. I have downloaded 7.9.5, twice. The first time the file was shown as corrupted. The second time I extracted it to my USB flash drive and tried to install it following instructions. However the installation failed because it apparently could not find the update file? What do I do now?
  4. Romec
    Macros on FLX 7.9.5
    Hi All, I have a question about macro’s. is it possible to record multiple command (lines) in a single macro?
  5. O Thompson
    Odd Behaviour
    🤨 scratch that... started to repatch the desk rather than load an old show, in case there was an issue with the show file... lasted 25 minutes and then the same behaviour resumed. strangly i noticed this time it crashed as soon as i pressed the save button on the show file. now back to intermittent on / off pattern. I will email and post here once i have confirmation from the supplier about a return. Thanks for the help, Keith too. Id be interested to know what the fault is when you get it back... Olly
  6. Edward- Z88
    Odd Behaviour
    Hello, OK thanks for the information. This sounds like it could be an intermittent power issue, however we haven't seen anything like this before. If you have any questions feel free to drop me an email or give us a call. Edward
  7. kgallen
    Odd Behaviour
    As Edward has confirmed for us I don't believe so on FLX. With Frog range, a flat battery caused all sorts of misbehaviour. As a result I asked about the battery in the FLX soon after I bought it, and Jon said that the battery was only there for the RTC and not related to retaining show data in RAM before it's copied to some non-volatile storage.
  8. O Thompson
    Odd Behaviour
    Thanks Edward, I have contacted Hawthorn who have advised they will contact me shortly to arrange a collection. In the mean time i have tried the 7.9.4 boot option and the same issue occurred. I have now gone back to 7.9.5 and on a further test, i can leave the power connected to the unit and the desk switched on. When i do this, the desk will intermittently power up. It will remain powered for between 2 and 5 minutes before crashing back to the same issues stated above. If i still leave the power connected, the unit will then power up again after 10-15 mins of "odd behaviour" and the process will repeat. However... i have left the desk to do this for the past couple of hours, and now i have returned to it, the desk seems stable again. I'm going to monitor the issue for the remainder of the day, and test again tomorrow to see if i can replicate the issue... if not, then im stumped as to why it now functions, although a little apprehensive about it acting up again during a show.
  9. Edward- Z88
    Odd Behaviour
    Hi Olly, Really sorry to hear this. I believe you have spoken to Keith on the phone regarding this. So to confirm, you have created a bootable USB drive with ZerOS 7.9.5. Booting the console boots into the install screen, where you can perform the installation. When complete, power cycle, and the console sometimes boots correctly? Please try repeating this process, however with ZerOS 7.9.4, available here... If this still hasn't solved the problem, please go back to Hawthorn, who if necessary will be able to send it back to us for investigation. The battery shouldn't have anything to do with the issue. Feel free to continue the conversation over email if that's easier. Kind regards Edward
  10. O Thompson
    Odd Behaviour
    No problem Kevin, test mode is a handy little tool. Reverting to the Jester is a PITA, but we'll make it work... we have a predominately LED rig, but not much in the way of moving heads, so with some creative grouping it will be fine. Just as thought, would the behaviour I'm seeing be related to something as simple as a flat BIOS battery?
  11. kgallen
    Odd Behaviour
    Cheers Olly. I hope you get the desk sorted quickly. Don't envy you having to drop back to Jester. I'd have to drop back to Fat Frog and that would be no easy move these days with so much LED and relying on move on dark so much! Kevin
  12. O Thompson
    Odd Behaviour
    While booting, hold down the setup key during the boot process. This gives you a test screen that will show you that all physical faders and buttons are functioning.
  13. kgallen
    Odd Behaviour
    Eeeekkk! Sorry I'm not closer otherwise I'd try to help out! Out of interest, how do you get in to FLX test mode? I feel I should already know this!
  14. O Thompson
    Odd Behaviour
    ***update 3 when the desk has been left, i am able to boot into test mode. Once the desk is shut down, and powered on again within 2 minutes of shutdown, the desk will produce the error described above. I have also tried a fresh install of the OS using a bootable USB drive. The install was successful, but the issue still remains after removing the USB drive. To summarise, the desk will not fully boot normally. After load screen the unit "crashes" and produces the issue above. Since reinstalling OS from a bootable USB, i can boot console successfully, but only after the desk has been left without power for some time. After being "on" for a few minutes (<5) the desk with crash and produce the same issues described above. Powering off the console and trying to reboot will produce the same issues described above. I can get to test mode if the desk has been turned off and left for at least 2 minutes. (all functions test ok). I can boot the desk from USB if the desk has been turned off and left for at least 2 minutes. Desk is currently not functional other than to access test mode or USB boot.
  15. O Thompson
    Odd Behaviour
    **update 2 When left with power disconnected for a period of time, the desk will attempt to boot when powered again. Part way through booting, the desk will revert back to the issue described above. The boot process gets as far as "loading" with the load bar reaching the right of the screen before it crashes
  16. O Thompson
    Odd Behaviour
    *update... The desk has now gone into "melt down"... The desk will not power at all. When connected to power, the page display flashes intermittently and there is a noticeable "click" from within the desk. On the rear of the desk, when powered the DMX, link and data lights flash along with the page display. Link to video of error Im going to contact our supplier (Hawthorn theatrical) but as it stands the desk is no longer functional. help or advice greatly received, as I'm now reverting to a Jester for shows today and tomorrow.
  17. Last week
  18. Edward- Z88
    Odd Behaviour
    Hello, Many thanks for the information regarding the FERAM Write failure. We will take a look into this. I am not sure why your console isn't displaying the U-boot or Q7 information, which in that picture should be lines of text between "Co-Processor Firmware" and "NVR Location". However as your picture shows the serial number I can get this information from there. I have added this to our issue log, as reference number ZOS-8639. If you have any queries let me know. Edward
  19. Hi Hendrik, Sorry to hear this - are you experiencing these issues running ZerOS 7.9.5? All the best, Edward
  20. kgallen
    Odd Behaviour
    In a nutshell, I turned my FLX on to do some more pre-show setup - it had been fine the night before, closed down ok - no front panel LEDs, no DMX output, but buttons and internal screen working. A power cycle did not help, I had to do a factory reset. I was panicing big time...! For the info Edward is after you need to tap some other tab on that screen - not sure if it's System Information, Console or Events - something like that!
  21. O Thompson
    Odd Behaviour
    Thanks for the reply, but i am unable to see the report. Apparently i don't have permission to view it.
  22. O Thompson
    Odd Behaviour
    Yes, I have the following text in green... "FERAM Write failure at 0x00004030, retries remaining : 4" I cant seem to see the info you are refering to. All i get under "desk info" is the following (attachmenet)...
  23. Hi Edward, we recently discovered the same issue with our S48. The DMX indicator on the dimmer goes off for a second and the lights are having a short black out. Before the S48 we used an old Zero88 Frog and never had a problem like this. The desk is still on and all executer buttons are flashing but there is no reboot and after this the desk is fully functional. Its an unpredictable issue, non-periodical and happens after approximately two hours of usage. Maybe it’s a thermal problem? Best, Hendrik
  24. Hi Step, On FLX, cues can be triggered by the Go button, the previous cue, the real time clock, or MIDI. For more information on MIDI triggers, see below... http://support.zero88.com/990063141 BPM speeds can be configured for any chase, or a global BPM can be used. For more information on Global BPM, see the article below... http://support.zero88.com/1011580981 Hope this helps, Edward
  25. stepan s
    Sync Efx on music
    Thanks, Now I try to find possibilities to control BPM. Can I use Midi beat clock from Ableton or protools? Or Only way is trigger cues by timecode and set bpm in playback. step
  26. Edward- Z88
    Odd Behaviour
    Morning, Hmm interesting. I presume after power cycling there was no offer to save a debug file? If you tap Z -> System Information -> System Text, and scroll through the text, are there any error messages/ text that isn't white? If you then tap back to Desk Info, there's a line of text starting with "Q7", and after a "PN", there should be "HW:B_". What is the number here? Kind regards, Edward
  27. kgallen
    Odd Behaviour
    I had something similar with 7.9.4. Does my report here look like what you experienced? In my case a desk reboot didn't help - I had to do a Factory Reset. (My post is in the Beta Test Forum, not sure if you can see that post. However my comments relate to 7.9.4 production software.)
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
