  1. Past hour
  2. On a slight tangent from the above... and to add more info for clarification. I have my 3 LED par bars (and 1 LED fresnel bar) set up for colour mixing. Eg, faders 1-3 are RGB from my fresnels, 4-6 are RGB for bar 1, 7-9 RGB for bar 2 and 10-12 are RGB for bar 3. I have set the parameters for each playback to allow fader control of colour as well as intensity, and I have a UDK that sets all RGB values to 0 (rather than 100 when released) This gives me the ability to mix colours across my pars and LED frenels. Using the info above, i have created 3 PB's each with a chase as described in my earlier post. Only this time, each PB / Chase is either R G or B. The idea being, that i can mix the colour of a chase using the 3 PB's and apply this over any current state. My issue now, is that if i were to raise the PB22 (red chase) over PB3,6+9 (red wash) i would expect nothing to happen, you wouldn't see a red chase over a red wash... However the red chase over rides the wash, and the bars not in use (during a step of the chase) go dark. I would have assumed that using HTP, colour as well as intensity are upheld by the highest value, but this only seems to apply to intensity? Is there such as thing as HTP for colour mixing? This only become an issue when running the chase over a colour wash that may be mixed with R at less than 100%, Further to this, if PB22 - 24 are not at full, then the "dark" fixtures in each step are no longer 0, but are scaled as if backwards... I have created a couple of videos using Phantom Zeros to try and show this. The first video show how the chase works over a state using the same colour parameter... Video 1 The second video shows my issue with colour "Scaling" when the PB is not at 100% Video 2 And finally, to make this post even more lengthy... Is there a way to link chases on multiple playbacks, so that the steps match each other? for example, if i set my 3 chases to global tempo, and start playing back my red chase, can i raise my blue chase to make magenta and have the steps align with each other? We used to have a Jester 24/48, and chases seemed to sync as standard, i'm hoping to replicate this? Show file attached if it helps... RGB Chase Example.isf
  3. Hello, I recently installed version 7.9.5. on my Solution console. I could see a bug on the FX. I have no way to access the Fx of my show on version 7.9.4 even starting from a blank show or completely after making a total rest of the console. I compare on the Phantom 7.9.5 that seems to work perfectly. this is really annoying for me and for others I Think. Would it be possible to send me the Beta version 7.9.4.31 for downgrade so I continued to use my show while waiting for a new update of the 7.9.5. Thank you in advance
  4. Today
  5. Edward, thanks again for your reply. What you have suggested would work fine for the chase over a red wash (my stated colour choices were for example sake), however i hoped to be able to apply the same chase (same PB) over another colour wash for the same effect, rather than having to have multiple effect playbacks to cater for different colour washes. I am assuming that this is not possible now having looked deeper into it? The console is used in an education environment, and i am putting together a standard patch / show that can be used by students to busk music events etc... It was my intention to have a few pre programmed chases that could be triggered over any stage wash colour, allowing my "blue"(or any other colour) chase to trigger regardless of the current wash / state on stage. I understand that this inst really normal practise, but in a busking scenario it would be useful.
  6. Yesterday
  7. Hi Olly, For the first step of your chase, select bar 1, set blue to full, set red to 0, and ensure that only the red and blue colour parameters are tagged. Make sure no other fixtures are included in each step of the chase. More can be found on tagging here... http://support.zero88.com/1014189311 Repeat this for the other bars, and you’ll find that you’ll have a blue chase over the top of your red playback, without magenta being mixed. Hope this helps and makes sense, if you have any queries let me know. Edward
  8. Hi Zeus, Thank you for your comments, glad you like the new software. Let us know if you have any questions. All the best, Edward
  9. Hi Edward, thanks for the reply. Ive actually done exactly as you have suggested, however this doesn’t really solve me issue. Having looked closer I’m not sure it’s actually possible... i have programmed my 3 step chase, and using LTP the chase does indeed run over the top of my other playbacks. But what I require is almost in between HTP And LTP. I’m not sure if I’m able to explain this effectively, but I’ll try. My pb1 is a red wash. My pb2 is a blue chase. The chase is programmed with all RGB tagged. When I raise pb2 over the top of pb1 for my chase I get the following... - bar 1 goes blue, bar 2&3 go dark - bar 2 goes blue, bar 1&3 go dark - bar 3 goes blue, bar 1&2 go dark what I want, is the following -bar 1 goes blue, bar 2&3 stay on red from pb1 -bar 2 goes blue, bar1&3 stay red from pb1 -bar 3 goes blue, bar1&2 stay red from pb1 i know I could achieve this by programming the red wash into the chase pb, but ideally I’d like the chase to run over the top of any wash. If I program the chase without G and B tagged, the chase gets mixed with my red wash (making magenta)... does this make sense? Thanks, Olly
  10. ZeuS
    ZerOS 7.9.5 Released
    big thank you for the fire effect and my screen finally not looks broken sometimes
  11. Hi Olly, I would recommend programming a 3 step chase for this, rather than using an effect. The colours of your chase will mix LTP (Latest Takes Precedence) with your other playbacks by default, and so your chase's colours will run over the top of other playbacks, and when the chase is released, the other playing playbacks will take over. Programming a group for each bar will speed up the programming time, as you'll then be able to apply the colours you wish to each bar group. Hope this helps Edward
  12. I'm in a similar situation myself... But I'm not sure the built in effects are the answer for my scenario unless i'm missing the point? My situation is as follows I have a colour wash (say red) on stage using RGB pars across 3 bars. I then want to run a sequential chase changing the colour of single bar at a time. For example, Step 1 would make bar 1 blue (with bars 2+3 still in red from another PB) Step 2 would make bar 2 blue (with bars 1+3 still in red from another PB) Step 3 would make bar 3 blue (with bars 1+2 still in red from another PB) How would i go about doing this? At the moment, if i tag RGB in each step of the chase, i just get a red chase and the previous playback is overwritten. If i just tag blue, then i can get an additive chase where the blue chase will mix with the other playback, but i cant seem to get the chase to momentarily replace the existing playback on a step by step basis. Any help is appreciated. Olly
  13. Hi Simon, To confirm, are you finding Art-Net isn't working on your physical console? Art-Net is working on physical consoles running ZerOS 7.9.5, however not on Phantom ZerOS with an unlock dongle. Edward
  14. Hello, We have logged this software issue as High Priority, reference number ZOS-9327. If you have any queries please do let me know. Edward
  15. Edward- Z88
    Tracking enabled
    Hi Karina, To disable tracking options, tap SETUP -> Settings -> Record & Update -> Tracking Options -> Cue Only. Hope this helps Edward
  16. Hi Eric, Home and Default values can now be configured on FLX S, which will solve this problem for you. For more information, see below... http://support.zero88.com/1011411491 That's correct, SETUP + tapping an attribute button will open the Attribute Settings. You can also access this by tapping SETUP -> System Settings, and then tap any of the Attribute Settings buttons. Edit Fixtures is now simply the Fixture Schedule (tap SETUP to access this), with the ability to customise fixture data, including inverting and swapping for moving fixtures. More information can be found here... http://support.zero88.com/1011707101 Configuring Defaults is now done outside of Setup. More information can be found here... http://support.zero88.com/1011707631 Hope this helps, Edward
  17. Hi Eric, Programmer Time is not changed when performing a "Reset Desk". Reset Desk clears all show-specific information, however leaves operator configuration, such as Programmer Time. A Factory Reset will reset the Programmer Time to disabled, and with a 5 second fade. Hope this helps, Edward
  18. Hello, As Eric says, this is due to the fixture defaults for RGB fixtures having Red, Green and Blue at full, to give white. For information on how to change this to achieve colour mixing, you can use the guide below... http://support.zero88.com/975070091 This guide is for our Solution and ORB consoles, but you'll be able to use the same process. For more information on configuring fixture Defaults, see the article below... http://support.zero88.com/1011707631 Hope this helps, Edward
  19. Hi Eric, Thanks for your comments. The new manual will be coming soon, for all FLX series consoles. If you have any queries let me know. Edward
  20. Hi David, Thanks very much for letting us know. I have logged this issue as reference number ZOS-9325. If you have any queries please let me know. Edward
  21. Karina
    Tracking enabled
    We've updated the latest version. Now is something changed in our settings and we can't get it right: In the right down corner you see: Tracking enabled We want to change this in: Tracking disabled (Because we work with the FLX on filmsets) We can't find it in the settings.... Thanks in advance!
  22. Last week
  23. Hello, Two questions... 1/ French importer have making a translation about FLX S 24 and 48 in French. Do you thing that there will do for the FLX ? 2/ Last update Manuel I was looking about fresh information. What is the last Manuel version ? Still 7.9.1 ? Or having you newer version ? thank
  24. Hello, in fact I thought a lot about this alignment problem. In the facts : 6 projector on a bridge. And two of them are not aligned with others. 1 OK 2 OK. 3Wrong. 4 OK. 5 OK 6 Wrong As mentioned above on some console, this can be corrected to have 6 projectors when the values at 50%, the points of light are all in the right place. (Like Grandma ...) 1 OK 2 OK. 3 -2% tilt. 4 OK. 5 OK 6 + 1% Tilt everything becomes OK But in practice this implies that making a correction at the level of the tilt, when we go on the 6 projectors at + 50% or - 50%, the number 3 and 6 will have a more limited displacement in one direction and more important in the other direction. (Which is logical since the projectors are badly hooked) So this implies either to limit the other projectors so that everyone is aligned or accept the fact that the end of races will not be identical for all. But the advantage of such a correction at the level of ZERO OS and to be able to have in "home position" all the projectors aligned with each other and thus to have something clean. Question 1 : I see somewhere that we can use SETUP + Position (or Colour Or Beam, etc...) for coming different setting... Is it stil working on 7.9.4 ? Question 2 : "Edit Fixture" was also on 7.9.1, .... In 7.9.4, how can we find this different options ? thank for your help Eric
  25. Thank for your help. Just a other question when I using in (Setup, Clear Option ) "Reset Desk", is it clearing Time Programmer in Off ? thank
  26. That makes a lot of sense. I hadn't considered the fixture profile default settings. You suggest that these values can be changed? how would you do this? With the 7.9.5 OS, i have discovered that i can remove the "release" option when a fader is at 0. This prevents the default 100 values returning when the fader is down, however i still need to use a UDK to bring down the RGB values on startup or after programming a PB. Thanks for your reply Erics
  27. Hi Olly, I think that depends on the default fixtures values. In the normal fixture profiles it is programmend that all RGB Values are @ 100%. So when you select a fixture with a fader it will light up white when you moves the fader up. So the normal oparator do not have to select a color when he wants only light on stage. I don't like this behaver, so it is good that i can change the default values on the FLX S desks with ZerOs 7.9.5 now.
  28. First post, so please excuse the naivety... We have recently purchased an FLX for use in a educational performance space. My questions relates to the way the FLX has to be set up for LED RGB Colour mixing. Using the guides above i am able to make this work easily, but my questions is more about why this is necessary... Specifically, the need to use a latch button to ensure intensity is at 100 and the RGB channels are at 0 unless triggered by a programmed PB? For example, I have PB 1-3 recorded as Red, Green, or Blue for a set of LED pars. I have recorded just a single colour parameter (R, G,or B ) and intensity of the fixture to the PB and set the fader to allow for colour control. If i then select all of the fixtures, and bring manually bring down the RGB levels to 0 using the touch screen, I can mix RGB using the PB's. However as soon as a fader hits 0 (<5%) the colour assigned to that playback with defaults to 100. I understand that recording the colour values at 0, and the intensity at 100 to a UDK allows me to work around this, but why is this step necesary? Why do the colour parameters default to 100%? Sorry if this is a daft question. From exhaustive googling, i realise this seems to be t he only way to achieve this, but my mind keeps asking why... Kind Regards Olly
  • Newsletter
    Want to keep up to date with all our latest news and information?
    Sign Up
