- Past hour
Thanks for your help. I don't get there until the last minute and I won't have time before the show. I'm hoping to be able to get some things ready beforehand. here's what I received. If you could do this for me, you would be doing me a great favour. Thanks in advance.
kgallen started following Under my radar
Yea I just saw that too…
I’m not sure if some of David’s links are working. This page effectively gives a flow chart: https://www.zero88.com/manuals/zeros/patching/add-fixtures/missing-fixtures If you’re really stuck and can post a link to the pdf manual for each fixture, I’m sure I could make you fixture files tonight.
Davidmk started following FOS and Under my radar
Just noticed this under Missing Fixtures in the manual Didn't see any news about that. Thought I should bring it to the everyone's attention.
Too complicated to explain here but Search & Filtering and Fixture Creator should help. There is also the Windows Fixture Editor and you can also look into the Generic fixtures already in the library where, for example, an LED PAR where ch1 is red, ch2 is green, ch3 is blue and ch3 is intensity will be listed as RGBI. All of his does, of course, rely on you knowing what parameters your fixtures use (i.e. having access to the manual for the specific model). If you don't have the manual then proceed as follows... With an empty patch, assign some dimmers (more than the number of parameters you think the fixture has got) and starting at the fixture's address. With the fixture powered up, try all the "dimmers" and see what happens. Bear in mind that, to get output, you may need at least two parameters (intensity and colour) up at the same time. You may need three if there is a "shutter" parameter that isn't open at zero. Try to be methodical but it does involve some trial and error. Good luck!
Those don’t look fancy, likely pretty basic fixtures. Your easiest options: - Ensure you have ZerOS 8 on it and check that library. - Use the fixture patch to search for other fixtures with the same or a usable DMX map. - Write your own with the on-console fixture editor.
Hello everyone. I'm having trouble because I've just arrived in a room equipped with this equipment and I can't find the fixtures in the library. If anyone could help me it would be great. -Fos profile 25/50 200W led -Fos tv mini fresnel tw -Fos cob par 200 (rgbw 4in1 cob led) Thanks in advance. Jeansté
RonaldTom started following server tracking backup
Solution desk randomly shutting down.
Worcester RGSTech replied to Worcester RGSTech's topic in Solution & Solution XL
Thank you Thierry, I have updated it to 7.14.4 and we will see what happens. - Earlier
That's the trouble with answering queries on a forum - where between noobs and "actually they know more than me" should you pitch your reply. On a full FLX I'd use an MFK but a playback (as described in my last post) should work as well.
Thank you, I know, and I am making use of playbacks a lot these days, designed and touring for 3 months a theatreshow which is a combination of theatre/comedy and songs by a 6-head band. I use my master playback for all the (main) cues , and also for the songs I have (a) cue(s) in the master playback. In combination with that I busk with the other playbacks. (over the master playback cue) Works very very nice, I programmed some position FX, some beam , some position playbacks and chases under the playbackfaders. Great setup, like on the old Avo's. But with the addition (on top of) of the master playback. Super. I always use inhibit faders for my houselights and my hazer,(patched as dimmers) which are present in all my master playback cues, so I never need to think about them while programming, or in panic situations. Just no-brain fader up, or down to control those. Very convenient, specially during rehearsals and programming and setting up the show. So I quite well know how to program playbacks. The only problem is (for another theatre piece) my collegue asked me if it were possible to make an inhibit for the beam of some fixtures. Which I'm trying to figure out now. for that piece is also my lighting design and running on one of my other zero88 desks.
But that's the thing with LTP. When the playback is released, the "last" value (from before the playback) is the one that takes precedence. Your playback needs to set the beam parameter to zero, have release on lower set and should (maybe) have trigger level set to 1% instead of the default 5% https://www.zero88.com/manuals/zeros/cues-playbacks/playback-settings/raise-and-lower#level The snag is that the release is a snap not a fade. I think there's a setting somewhere to fix that but I've never looked it up.
Ed75 started following inhibit beam fader? FLX(S)
Could indeed be it only works on intensities. Hope somebody here can clarify this. Normal playbacks I also use for manipulating beam sizes , but I need an inhibit for the reason I can take all beams back regardless of the value they're in. (I mean: one fix is at 75% and another is at 50% and a third on 25% for example) I want them to go back in value in ratio, if you see what I mean. With an intensity inhibit this works very well. I do not want all of them to go to the same beam value as if you were using a normal beam fader. Anyway thanks for your reply! And maybe we get to know the solution, if there is one.... Edit: just went though the manual again. Inhibit seems to belong to the "intensity" mixing part of a playback. It is not literally mentioned it shouldn't work on other attributes, but I start having my doubts if it is...
Davidmk started following Phantom 8.0 compatibility and inhibit beam fader? FLX(S)
Double check whether you have accidentally included intensity (I'm always doing that!). If you have then you can update with remove (or just set it up again). If you haven't made that mistake then maybe inhibit only works on intensities. It's what it is intended for after all. I've never tried it for anything else. Intensity is HTP of course (hence the need for inhibit). Other parameters are LTP so you don't really need inhibit. A normal playback with the beam at 0 should do it.
Maybe a stupid one this time....I m trying to fix me an inhibit beam fader . Which can take all the beam sizes down at once. But somehow it doesn't work. I select the fixtures, set beam at 100%, tag beam, record it on a playback, set fader controls beam, and inhibit. In my main list I go to a cue, (fixtures intensity at certain level , and beams at a certain level) and from the moment I make my beam fader an inhibit, it set all intensities of the fixtures to 0 ....... and the inhibit doesn't work.....what am I overlooking? I use inhibits a lot for intensities , and it alway works flawlessly. But this I can't seem to figure out. Any ideas??
Phantom ZeroOS is ZeroOS with a Windows "wrapper" - unlike a hardware desk, you don't/can't load ZeroOS onto it. So Phantom ZerOS version is ZeroOS v8. If you want ZeroOS v7.14.3 then you need to download Phantom ZerOS v7.14.3 which should be in the 7.14.3 zip file under legacy software on the downloads page.
Klaus joined the community
Will Phantom 8.0 work with ZerOS 7.14.3 ? System requirements for Phantom 8.0 ? Thank you Klaus
thierry replied to Worcester RGSTech's topic in Solution & Solution XL
Hi, firstable try to update ZerOs to 7.14.4, and change the CR2032 battery coin inside the desk. I don't know but hope this help. Thierry -
I have written a FLXS48 User Booklet as a basic guide on how to do specific tasks on a FLXS48, mainly for new users. I am trying to word a section on controlling mini LED movers with colour and gobo wheels, as the initial Tab selection screen does not provide control, you need to use the encoder wheel button to access any selection. Any comments on this wording please ? Using Colour Wheels and Gobo Wheels on Mini Movers If you have selected an LED Mini Mover that has a Colour Wheel or a Gobo Wheel, after you select the Colour or Shape Tab on the top of the internal touch screen, you then need to press the centre button of the first encoder wheel for the selection screen to appear, which shows the colours or gobos that are available to select. To return to the main window, press the centre button of the encoder wheel again. FLXS48 USER BOOKLET 24 March 2025 ZerOS 8.pdf
Our Solution Desk decided to randomly shut itself down immediately before a show. Monitor went blank and DMX output stopped. Then the windows started showing 'loading' and 'solution' We turned off the power, waited and then restarted it and it seemed stable for the show.It is running ZerOS 7.9.4. It stays in a control room and is not moved around between venues/spaces, although it can be quite cold overnight. Any ideas? Thank you
No at all. Valid correction.
Ah ok gotcha, makes sense. Sorry wasn't trying to be hostile or anything just wanted to provide all the options
