- Past hour
hdjsis started following Jumping PiPe loan Customer Care NuMbeR ][{7894720560 ™️}][ 789-472-0560 Contact nOw , Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-vj , Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me nd and 1 other
hdjsis joined the community
Re-reading the thread (because I'm sort of back to square one) there were two points raised that I think are worth further comment because they can now be ruled out. 1. The potential differences between Flex and Leapfrog (and Solution) can probably be ruled out because I think this is a software problem and the ZerOS software is common to all those boards. I guess the hardware drivers might be different but the fact that I can reproduce the problem with PhantomZerOS running on a Windows PC suggests not. 2. Being able to reproduce the problem in PhantomZerOS also tends to rule out the (otherwise plausible) theory that something in the inherited show setup causes it. I think the causes have been explained fairly thoroughly - the colours are designed to either "snap" when triggered or fade in gradually with the fader (or a delay). It's the solution that I'm still struggling with. If I can get it to fade from black instead of white that will probably do it.
