  1. Past hour
  2. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me
  3. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me
  4. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me
  5. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me
  6. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me
  7. Kamakshi Money Loan App Customer” Care Helpline” Number♻️-+91)+7894720560-//-91-7894(7205)-60₹_Call Me xh
  8. Jumping PiPe loan Customer Care NuMbeR ][{7894720560 ™️}][ 789-472-0560 Contact nOwJumping PiPe loan Customer Care NuMbeR ][{7894720560 ™️}][ 789-472-0560 Contact nOw
  9. Jumping PiPe loan Customer Care NuMbeR ][{7894720560 ™️}][ 789-472-0560 Contact nOw
  10. Today
  11. Re-reading the thread (because I'm sort of back to square one) there were two points raised that I think are worth further comment because they can now be ruled out. 1. The potential differences between Flex and Leapfrog (and Solution) can probably be ruled out because I think this is a software problem and the ZerOS software is common to all those boards. I guess the hardware drivers might be different but the fact that I can reproduce the problem with PhantomZerOS running on a Windows PC suggests not. 2. Being able to reproduce the problem in PhantomZerOS also tends to rule out the (otherwise plausible) theory that something in the inherited show setup causes it. I think the causes have been explained fairly thoroughly - the colours are designed to either "snap" when triggered or fade in gradually with the fader (or a delay). It's the solution that I'm still struggling with. If I can get it to fade from black instead of white that will probably do it.
  12. Update: Tried this on the real board in the theatre and it didn't work. The board has been upgraded from a Leapfrog 48 to a Solution which might explain that. But what DID work was better - Clear + Submasters. This cleared them all in two button presses, which is great. Except when it doesn't. 😞 It's not reliable - some faders still sometimes had to be cleared manually by cycling through submaster pages, finding active submasters and raising and lowering the fader. It doesn't always happen and I didn't manage to find the crucial difference between the ones that clear and ones that don't in the time available.
  13. Update: Tried the above solution ("Manual fader 1 way") on the real board at the theatre and it didn't work, so I'm back to square one. 😞 The board in the theatre has been upgraded from a Leapfrog 48 to a Solution, so that might explain the difference. I'll try the simulated version of that when I get a chance. I noticed a progress bar along the bottom edge of the LCD display above each of the 10 submaster faders. It takes about 5 seconds to reach all the way across once triggered by raising the fader. The behaviour of the lights is different depending on whether the progress has completed or not - I would like to disable it completely but I couldn't find any setting for it. I set every delay I could find in both the submaster properties and the board settings to zero but it's still there. Does anyone know where it is set or how to disable it completely?
  14. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Dj it
  15. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Ski
  16. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Hii
  17. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Goo
  18. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Dj HD
  19. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Eye
  20. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। She
  21. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। The
  22. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। She
  23. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Why
  24. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Rift
  25. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Full
  26. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Roy
  27. First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा।First कुकू एफएम से रिफंड कैसे प्राप्त करें. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर ( 8603))23~21•25) पर कॉल करना होगा। कुकू एफएम से पैसे कैसे वापस पाएं. इसके लिए आपको ™Kuku Fm™ टोल फ्री नंबर (9163467314 पर कॉल करना होगा। Ride
