  1. Past hour
  2. Re-reading the thread (because I'm sort of back to square one) there were two points raised that I think are worth further comment because they can now be ruled out. 1. The potential differences between Flex and Leapfrog (and Solution) can probably be ruled out because I think this is a software problem and the ZerOS software is common to all those boards. I guess the hardware drivers might be different but the fact that I can reproduce the problem with PhantomZerOS running on a Windows PC suggests not. 2. Being able to reproduce the problem in PhantomZerOS also tends to rule out the (otherwise plausible) theory that something in the inherited show setup causes it. I think the causes have been explained fairly thoroughly - the colours are designed to either "snap" when triggered or fade in gradually with the fader (or a delay). It's the solution that I'm still struggling with. If I can get it to fade from black instead of white that will probably do it.
  3. Update: Tried this on the real board in the theatre and it didn't work. The board has been upgraded from a Leapfrog 48 to a Solution which might explain that. But what DID work was better - Clear + Submasters. This cleared them all in two button presses, which is great. Except when it doesn't. ЁЯШЮ It's not reliable - some faders still sometimes had to be cleared manually by cycling through submaster pages, finding active submasters and raising and lowering the fader. It doesn't always happen and I didn't manage to find the crucial difference between the ones that clear and ones that don't in the time available.
  4. Update: Tried the above solution ("Manual fader 1 way") on the real board at the theatre and it didn't work, so I'm back to square one. ЁЯШЮ The board in the theatre has been upgraded from a Leapfrog 48 to a Solution, so that might explain the difference. I'll try the simulated version of that when I get a chance. I noticed a progress bar along the bottom edge of the LCD display above each of the 10 submaster faders. It takes about 5 seconds to reach all the way across once triggered by raising the fader. The behaviour of the lights is different depending on whether the progress has completed or not - I would like to disable it completely but I couldn't find any setting for it. I set every delay I could find in both the submaster properties and the board settings to zero but it's still there. Does anyone know where it is set or how to disable it completely?
  5. Today
  6. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Dj it
  7. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Ski
  8. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Hii
  9. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Goo
  10. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Dj HD
  11. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Eye
  12. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред She
  13. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред The
  14. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред She
  15. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Why
  16. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Rift
  17. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Full
  18. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Roy
  19. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Ride
  20. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред For
  21. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Ek my
  22. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред That
  23. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Db by
  24. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Dj ke
  25. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Et
  26. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред Rh
  27. First рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛редFirst рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рд░рд┐рдлрдВрдб рдХреИрд╕реЗ рдкреНрд░рд╛рдкреНрдд рдХрд░реЗрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ ( 8603))23~21тАв25) рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред рдХреБрдХреВ рдПрдлрдПрдо рд╕реЗ рдкреИрд╕реЗ рдХреИрд╕реЗ рд╡рд╛рдкрд╕ рдкрд╛рдПрдВ. рдЗрд╕рдХреЗ рд▓рд┐рдП рдЖрдкрдХреЛ тДвKuku FmтДв рдЯреЛрд▓ рдлреНрд░реА рдирдВрдмрд░ (9163467314 рдкрд░ рдХреЙрд▓ рдХрд░рдирд╛ рд╣реЛрдЧрд╛ред
