Zulu Posted June 7, 2018 Report Share Posted June 7, 2018 I primarily operate in a theatre environment, so a Cue-stack full of pre-recorded lighting states. Is it possible to make tweaks during a performance, and to save them, whilst the cue is in live playback on the stage? Many thanks Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 7, 2018 Report Share Posted June 7, 2018 It looks like you want "Blind" mode, but this article says Blind is not provided on FLX S unfortunately: Quote Link to comment Share on other sites More sharing options...
martin-144 Posted June 7, 2018 Report Share Posted June 7, 2018 Do you want to make the changes "blind" or "live"? In a theater environment and during rehearsals I assume live. After doing your changes you can just press UPD and GO to have the current cue updated with the new state. Don't forget to clear your programmer afterwards 🙂 Martin Quote Link to comment Share on other sites More sharing options...
kgallen Posted June 7, 2018 Report Share Posted June 7, 2018 Good point Martin, thanks for the clarification. Kevin Quote Link to comment Share on other sites More sharing options...
Zulu Posted June 7, 2018 Author Report Share Posted June 7, 2018 yes,live not blind. Thanks , I think that is the answer I need. cheers,Dave Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted June 8, 2018 Report Share Posted June 8, 2018 Hi Zulu, Yes, for FLX S consoles to edit a cue live, go into the cue, and use the channel faders/ attribute controls to create your updated scene. When you're happy, tap UPDATE, and tap your Master Playbacks Go button. Your edits will be stored, and the programmer will be automatically cleared as the console grabs the edited fixtures and puts them into the cue. Hope that helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
EwenA Posted April 30, 2021 Report Share Posted April 30, 2021 Is it possible to edit a single playback live, and exclude other active playbacks from being incorporated into the updated cue? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 30, 2021 Report Share Posted April 30, 2021 Hello, 24 minutes ago, EwenA said: Is it possible to edit a single playback live, and exclude other active playbacks from being incorporated into the updated cue? Yes it is. To do this, when you update the cue, you can disable the “SmartTag” option in the Update options. When SmartTag is disabled, only manual control values will get included, not values form another playback. For information on the SmartTag feature, see here… https://zero88.com/manuals/zeros/cues-playbacks/record-options/snapshot-smarttag#smarttag Hope this helps, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
