Greenwood LX Posted April 23, 2018 Report Share Posted April 23, 2018 Hi, I am trying to renumber cues in the main playback cue stack, so I go to the cue I need the renumber hit enter, type in the new number then hit enter but nothing happens. Is there any way of doing this? Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted April 24, 2018 Report Share Posted April 24, 2018 Hello, Yes, to renumber a Playback, hold SETUP and tap the Playback's button. Then go to Advanced -> Renumber, and you can choose the start number and increment for the list. You can't renumber individual cues. Tapping enter on a cue number, typing a number and then tapping enter to confirm, allows you to choose which cue is next. For example if you are in cue 1, tap enter, type 10, and tap enter, the next time you tap GO you'll go to cue 10. Hope that helps, any queries let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
kgallen Posted April 24, 2018 Report Share Posted April 24, 2018 1 hour ago, Edward- Z88 said: You can't renumber individual cues. Tapping enter on a cue number, typing a number and then tapping enter to confirm, allows you to choose which cue is next. For example if you are in cue 1, tap enter, type 10, and tap enter, the next time you tap GO you'll go to cue 10. Ahhhhh I seee, this always confused the heck out of me - usually when I accidentally press <enter> on the cue number field, panicking I was renumbering it! Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted April 24, 2018 Report Share Posted April 24, 2018 3 hours ago, Edward- Z88 said: You can't renumber individual cues. However, you can copy individual cues, and then delete the original. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
