Mostyn
Elara Zero88
We have just been donated a Elara Zero 88 desk and I'm looking help with setting it up. i.e. software and any advise anyone can give would be great.
Hi Mostyn,
What colour is your Elara? If it is Grey, then its a Mk1 version, made from 1998 to 2003. Further information can be found here...
http://support.zero88.com/975528711
If it is Green, then it is a Mk2 version, further information can be found here...
http://support.zero88.com/975528781
Hope that helps you get started, any queries let me know.
Hi Mostyn,
I don't know what your use case is (theatre, busking, etc), but just be aware that the Elara is a "submasters desk" where you programme lighting states to each submaster fader. This is different to a cue stack desk, which is more typical for a theatre use model. The Elara's sister desk, the Alcora, is a cue stack desk.
Kevin
The Elara/Alcora series desks are a cracking little desk - very robust and easy to use once you get a hang of the basics, they're also relatively trouble free in terms of maintenance - generally only needing new faders.
The Mk2 versions have a little more functionality as they allow DMX patching but otherwise there's little difference between the two marks.
18 hours ago, Edward- Z88 said:
Hi Mostyn,
Thank you Edward, it a green one. Will follow the link.
37 minutes ago, iank99 said:
The Elara/Alcora series desks are a cracking little desk.
They certainly are! My first own-purchase lighting desk was an Alcora (Mk1) - and bought from Ian too, way back in 2000. I still have it, and it comes out every now and again when I want something straightforward and light. Also since mine has DMX and analogue outputs it can fit into pretty much any dimmer system.
I specifically bought a second hand Alcora Mk2 to use as a "slave" desk if I needed to loan someone a desk during repair - 24 channels of rock solid DMX and easy to use event after a few years - I can't say that about some of the generic chinese 24 channel desks :)
Create an account
Register a new account
Sign in
