Building own fixture
Carwyn
Hi Guys and Gals
I Need to build a fixture up, it is basically led tape which I've installed on the steps at the venue. controlls need to be RGB and intensity the controller is a 3 channel controller so how would i get the intensity to control the whole unit then HELP
If I understand you correctly, you have RGB LED tape and the driver (not really "controller") is 3 channel.
This is fine, you can have a "virtual intensity" channel - so 4 channels on your lighting desk and 3 DMX channels to the driver.
There will be an RGB+virtual intensity already in the fixture library, or just build one in the Fixture Editor.
Or attached which is one I built myself for RGB LED tape:
led_rgb_vi.ift
