Sign in to follow this
Jürg
Delete a fixture in an existing submaster
Hi, I operate a Zero 88 Solution. How can I delete a fixture in an existing submaster without deleting the submaster? - When I dim a fixture to zero there is still a red "O" in the program window. Thanks for your advice. :)
Hi Jürg,
I believe I have already helped you with this over Facebook. However just to write it here too. The easiest way to remove a fixture from a Playback/ Submaster when in Tracking mode, is to select the fixture you no longer need, tap HOME -> UPDATE -> Choose Remove -> Tap the Playback's button. If in Non-Tracking, push your Playback/ Submaster up, select the fixture and bring it to 0%, tap UPDATE -> Tap the Playback's button.
Hope that helps,
Create an account
Register a new account
Sign in
